Site keeps redirecting to a particular URL and images not showing
We use github actions to run all our deploys now. I have two issues:
  1. All our deploy previews work fine but the branch deploy on development branch doesn’t work fine. Here is the branch -https://development--trace-client-v2.netlify.app/, it keeps redirecting to https://account-verification/. Yet the counterpart deploy link for the last build - https://66ae95943cf2b4ddc3b521e7--trace-client-v2.netlify.app/ works fine without any issues.
  2. Some of the images linked from /public/assets folder no longer load.
Here is the workflow file that deploys to development branch
name: Deploy Development
on:
push:
branches:
  • development
    workflow_dispatch:
    inputs:
    branch:
    description: “Branch to deploy”
    required: true
    default: “development”
jobs:
deploy:
runs-on: ubuntu-latest
strategy:
matrix:
app: [client, admin]
steps:
  • uses: actions/checkout@v4
    with:
    ref: ${{ github.sha }}
  • name: Setup Node.js
    uses: actions/setup-node@v4
  • name: Setup pnpm
    uses: pnpm/action-setup@v4
    with:
    version: 9.1.3
  • name: Get pnpm cache directory path
    run: echo “dir=$(pnpm store path)” >> $GITHUB_OUTPUT
  • uses: actions/cache@v4
    with:
    path: {{ steps.pnpm-cache-dir-path.outputs.dir }} key: {{ runner.os }}-pnpm-{{ github.sha }}-{{ hashFiles(‘**/pnpm-lock.yaml’) }}
    restore-keys: |
    ${{ runner.os }}-pnpm-
    with:
    path: apps/{{ matrix.app }}/.next key: {{ runner.os }}-next-{{ github.sha }}-{{ hashFiles(‘**/pnpm-lock.yaml’) }}
  • name: Install dependencies
    run: pnpm install -w
  • name: Set netlify build variables
    run: |
    if [ “{{ matrix.app }}" == "client" ]; then echo "NETLIFY_SITE_ID={{ secrets.NETLIFY_TRACE_CLIENT_SITE_ID }}” >> $GITHUB_OUTPUT
    echo “NETLIFY_PREVIEW_URL=https://development–trace-client-v2.netlify.app” >> GITHUB_OUTPUT elif [ "{{ matrix.app }}" == “admin” ]; then
    echo “NETLIFY_SITE_ID=${{ secrets.NETLIFY_TRACE_ADMIN_SITE_ID }}” >> $GITHUB_OUTPUT
    echo “NETLIFY_PREVIEW_URL=https://development–trace-admin-v2.netlify.app” >> $GITHUB_OUTPUT
    fi
  • name: Set Deploy Context
    run: echo “DEPLOY_CONTEXT=dev” >> $GITHUB_OUTPUT
  • name: Get last merged PR
    run: |
Fetch merged PRs
pr_data=$(gh pr list --state merged --base development --json number,title,mergedAt --limit 100)
Extract the last merged PR by sorting by mergedAt
pr_number=$(echo "pr_data" | jq -r 'sort_by(.mergedAt) | last | .number') pr_title=(echo “$pr_data” | jq -r ‘sort_by(.mergedAt) | last | .title’)
echo “number=$pr_number” >> $GITHUB_OUTPUT
echo “title=$pr_title” >> GITHUB_OUTPUT env: GITHUB_TOKEN: {{ secrets.GITHUB_TOKEN }}
  • name: Build and Deploy the app
    env:
    NETLIFY_AUTH_TOKEN: {{ secrets.NETLIFY_AUTH_TOKEN }} NETLIFY_SITE_ID: {{ steps.netlify-config.outputs.NETLIFY_SITE_ID }}
    MESSAGE: “Merge pull request #{{ steps.get_pr.outputs.number }}: {{ steps.get_pr.outputs.title }}”
    DEPLOY_CONTEXT: {{ steps.deploy-context.outputs.DEPLOY_CONTEXT }} run: | netlify deploy --build --filter {{ matrix.app }} --context DEPLOY_CONTEXT --dir apps/{{ matrix.app }}/.next --auth $NETLIFY_AUTH_TOKEN --site $NETLIFY_SITE_ID --alias development --message “$MESSAGE”
  • name: Notify Slack on Success
    if: success()
    run: |
    curl -X POST -H ‘Content-type: application/json’ --data ‘{
    “text”: “:white_check_mark: Deployment Successful! :tada:\n\nApp: '”{{ matrix.app }}"'\n*Environment:* 'development'\n*Details:* <'"{{ steps.netlify-config.outputs.NETLIFY_PREVIEW_URL }}"’>"
    }’ ${{ secrets.SLACK_WEBHOOK_URL }}
  • name: Notify Slack on Failure
    if: failure()
    run: |
    “text”: “:x: Deployment Failed! :scream:\n\nApp: '”{{ matrix.app }}"'\n*Environment:* 'development'\n*Details:* <'"{{ github.server_url }}/{{ github.repository }}/actions/runs/{{ github.run_id }}/jobs"’|View Job>"
I’m not being redirected. I see the same content on both those URLs.
The image doesn’t load because your auth is not allowing access for /assets/* path.
