Error Debug Log: Netlify
I’m trying to set up a site with continuous deployment through github so I can run my serverless functions. I’ve had the site working fine, but after I transitioned over to a new pc build I’ve needed to re-install nodeJs and for some reason I keep getting this error.
Setting up the Edge Functions environment. This may take a couple of minutes.Error: Could not read downloaded binary
at DenoBridge.downloadBinary (file:///C:/Users/Darkskittlz/AppData/Roaming/npm/node_modules/netlify-cli/node_modules/@netlify/edge-bundler/dist/bridge.js:33:19)
at async DenoBridge.getBinaryPath (file:///C:/Users/Darkskittlz/AppData/Roaming/npm/node_modules/netlify-cli/node_modules/@netlify/edge-bundler/dist/bridge.js:116:32)
at async Module.serve (file:///C:/Users/Darkskittlz/AppData/Roaming/npm/node_modules/netlify-cli/node_modules/@netlify/edge-bundler/dist/server/server.js:53:5)
at async prepareServer (C:\Users\Darkskittlz\AppData\Roaming\npm\node_modules\netlify-cli\src\lib\edge-functions\proxy.js:146:22)
C:\Users\Darkskittlz\AppData\Roaming\npm\node_modules\netlify-cli\node_modules\netlify-redirector\lib\redirects.js:116
throw ex;
abort({}) at Error
at jsStackTrace (C:\Users\Darkskittlz\AppData\Roaming\npm\node_modules\netlify-cli\node_modules\netlify-redirector\lib\redirects.js:1070:13)
at stackTrace (C:\Users\Darkskittlz\AppData\Roaming\npm\node_modules\netlify-cli\node_modules\netlify-redirector\lib\redirects.js:1087:12)
at process.abort (C:\Users\Darkskittlz\AppData\Roaming\npm\node_modules\netlify-cli\node_modules\netlify-redirector\lib\redirects.js:8502:44)
at process.emit (node:events:527:28)
at processEmit [as emit] (C:\Users\Darkskittlz\AppData\Roaming\npm\node_modules\netlify-cli\node_modules\signal-exit\index.js:199:34)
at emit (node:internal/process/promises:140:20)
at processPromiseRejections (node:internal/process/promises:274:27)
at processTicksAndRejections (node:internal/process/task_queues:97:32)
(Use `node --trace-uncaught ...` to show where the exception was thrown)
The dev server will spin up in the browser but after the error is thrown the terminal session shuts down. I believe this has to do with my netlify-redirector file in node_modules. Just wanted to get some advice. Thanks in advance.
Darkskittlz
