Hi, I’m having issues building a rust wasm project.
My site name is: mr-nugget.netlify.app
When running the following build script:
rustup toolchain install nightly
rustup override set nightly
rustup target add --toolchain nightly wasm32-unknown-unknown
cargo build --release --target-dir=public --target=wasm32-unknown-unknown
I get the following error:
12:31:12 PM: Build ready to start
12:31:14 PM: build-image version: 3bcb38c35508b42e9121d4badfe6d8c66fd7a3f0
12:31:14 PM: build-image tag: v4.3.2
12:31:14 PM: buildbot version: f76d0586731616514ae5f22a8e90e34a01fbd211
12:31:14 PM: Fetching cached dependencies
12:31:14 PM: Starting to download cache of 88.4KB
12:31:14 PM: Finished downloading cache in 55.63149ms
12:31:14 PM: Starting to extract cache
12:31:14 PM: Finished extracting cache in 7.60686ms
12:31:14 PM: Finished fetching cache in 63.626017ms
12:31:14 PM: Starting to prepare the repo for build
12:31:14 PM: Preparing Git Reference pull/5/head
12:31:15 PM: Parsing package.json dependencies
12:31:16 PM: Starting build script
12:31:16 PM: Installing dependencies
12:31:16 PM: Python version set to 2.7
12:31:17 PM: Downloading and installing node v16.11.0...
12:31:17 PM: Downloading https://nodejs.org/dist/v16.11.0/node-v16.11.0-linux-x64.tar.xz...
12:31:17 PM: Computing checksum with sha256sum
12:31:17 PM: Checksums matched!
12:31:20 PM: Now using node v16.11.0 (npm v8.0.0)
12:31:21 PM: Started restoring cached build plugins
12:31:21 PM: Finished restoring cached build plugins
12:31:21 PM: Attempting ruby version 2.7.2, read from environment
12:31:22 PM: Using ruby version 2.7.2
12:31:22 PM: Using PHP version 8.0
12:31:22 PM: Started restoring cached go cache
12:31:22 PM: Finished restoring cached go cache
12:31:22 PM: go version go1.16.5 linux/amd64
12:31:22 PM: Installing missing commands
12:31:22 PM: Verify run directory
12:31:24 PM:
12:31:24 PM: ────────────────────────────────────────────────────────────────
12:31:24 PM: Netlify Build
12:31:24 PM:
12:31:24 PM: ❯ Version
12:31:24 PM: @netlify/build 18.13.12
12:31:24 PM:
12:31:24 PM: ❯ Flags
12:31:24 PM: baseRelDir: true
12:31:24 PM: buildId: 616458c099c48c0007cedac8
12:31:24 PM: deployId: 616458c099c48c0007cedaca
12:31:24 PM:
12:31:24 PM: ❯ Current directory
12:31:24 PM: /opt/build/repo
12:31:24 PM:
12:31:24 PM: ❯ Config file
12:31:24 PM: No config file was defined: using default values.
12:31:24 PM:
12:31:24 PM: ❯ Context
12:31:24 PM: deploy-preview
12:31:24 PM:
12:31:24 PM: 1. Build command from Netlify app
12:31:24 PM:
12:31:24 PM: $ bin/build-netlify
12:31:24 PM: info: syncing channel updates for 'nightly-x86_64-unknown-linux-gnu'
12:31:24 PM: info: latest update on 2021-10-11, rust version 1.57.0-nightly (41dfaaa3c 2021-10-10)
12:31:24 PM: info: downloading component 'cargo'
12:31:24 PM: info: downloading component 'clippy'
12:31:24 PM: info: downloading component 'rust-docs'
12:31:25 PM: info: downloading component 'rust-std'
12:31:25 PM: info: downloading component 'rustc'
12:31:26 PM: info: downloading component 'rustfmt'
12:31:26 PM: info: installing component 'cargo'
12:31:27 PM: info: installing component 'clippy'
12:31:27 PM: info: installing component 'rust-docs'
12:31:30 PM: info: installing component 'rust-std'
12:31:34 PM: info: installing component 'rustc'
12:31:40 PM: info: installing component 'rustfmt'
12:31:40 PM: nightly-x86_64-unknown-linux-gnu installed - rustc 1.57.0-nightly (41dfaaa3c 2021-10-10)
12:31:40 PM: info: default toolchain set to 'nightly-x86_64-unknown-linux-gnu'
12:31:40 PM: info: checking for self-updates
12:31:40 PM: info: using existing install for 'nightly-x86_64-unknown-linux-gnu'
12:31:40 PM: info: override toolchain for '/opt/build/repo' set to 'nightly-x86_64-unknown-linux-gnu'
12:31:40 PM: nightly-x86_64-unknown-linux-gnu unchanged - rustc 1.57.0-nightly (41dfaaa3c 2021-10-10)
12:31:41 PM: info: downloading component 'rust-std' for 'wasm32-unknown-unknown'
12:31:41 PM: info: installing component 'rust-std' for 'wasm32-unknown-unknown'
12:31:45 PM: Updating crates.io index
12:32:09 PM: Downloading crates ...
12:32:10 PM: Downloaded maybe-uninit v2.0.0
12:32:10 PM: Downloaded bytemuck v1.7.2
12:32:10 PM: Downloaded color_quant v1.1.0
12:32:10 PM: Downloaded png v0.16.8
12:32:10 PM: Downloaded miniz_oxide v0.3.7
12:32:10 PM: Downloaded strum_macros v0.22.0
12:32:10 PM: Downloaded unicode-xid v0.2.2
12:32:10 PM: Downloaded quote v1.0.10
12:32:10 PM: Downloaded cfg-if v1.0.0
12:32:10 PM: Downloaded num-derive v0.3.3
12:32:10 PM: Downloaded toml v0.5.8
12:32:10 PM: Downloaded num-integer v0.1.44
12:32:10 PM: Downloaded proc-macro2 v1.0.29
12:32:10 PM: Downloaded unicode-segmentation v1.8.0
12:32:10 PM: Downloaded num-traits v0.2.14
12:32:10 PM: Downloaded hashbrown v0.9.1
12:32:10 PM: Downloaded serde_derive v1.0.130
12:32:10 PM: Downloaded serde v1.0.130
12:32:10 PM: Downloaded glam v0.19.0
12:32:10 PM: Downloaded macroquad_macro v0.1.7
12:32:10 PM: Downloaded miniquad v0.3.0-alpha.37
12:32:10 PM: Downloaded sapp-wasm v0.1.26
12:32:10 PM: Downloaded sapp-linux v0.1.13
12:32:10 PM: Downloaded num-rational v0.3.2
12:32:10 PM: Downloaded syn v1.0.80
12:32:10 PM: Downloaded strum v0.22.0
12:32:10 PM: Downloaded smallvec v0.6.14
12:32:10 PM: Downloaded ttf-parser v0.12.3
12:32:10 PM: Downloaded quad-rand v0.2.1
12:32:10 PM: Downloaded adler32 v1.2.0
12:32:10 PM: Downloaded quad-snd v0.2.2
12:32:10 PM: Downloaded libc v0.2.103
12:32:10 PM: Downloaded macroquad v0.3.10
12:32:10 PM: Downloaded lewton v0.9.4
12:32:10 PM: Downloaded fontdue v0.5.2
12:32:10 PM: Downloaded bitflags v1.2.1
12:32:10 PM: Downloaded image v0.23.14
12:32:10 PM: Downloaded quad-alsa-sys v0.3.2
12:32:10 PM: Downloaded ogg v0.7.1
12:32:10 PM: Downloaded ahash v0.4.7
12:32:10 PM: Downloaded hound v3.4.0
12:32:10 PM: Downloaded glam v0.14.0
12:32:10 PM: Downloaded dasp_frame v0.11.0
12:32:10 PM: Downloaded dasp_sample v0.11.0
12:32:10 PM: Downloaded bumpalo v3.7.1
12:32:10 PM: Downloaded audrey v0.3.0
12:32:10 PM: Downloaded deflate v0.8.6
12:32:10 PM: Downloaded num-iter v0.1.42
12:32:10 PM: Downloaded crc32fast v1.2.1
12:32:10 PM: Downloaded heck v0.3.3
12:32:10 PM: Downloaded byteorder v1.4.3
12:32:10 PM: Downloaded autocfg v1.0.1
12:32:10 PM: Compiling autocfg v1.0.1
12:32:10 PM: Compiling proc-macro2 v1.0.29
12:32:11 PM: error: linker `/usr/bin/clang` not found
12:32:11 PM: |
12:32:11 PM: = note: No such file or directory (os error 2)
12:32:11 PM: error: could not compile `proc-macro2` due to previous error
12:32:11 PM: warning: build failed, waiting for other jobs to finish...
12:32:11 PM: error: build failed
12:32:11 PM:
12:32:11 PM: ────────────────────────────────────────────────────────────────
12:32:11 PM: "build.command" failed
12:32:11 PM:
12:32:11 PM: Error message
12:32:11 PM: Command failed with exit code 101: bin/build-netlify
12:32:11 PM:
12:32:11 PM: Error location
12:32:11 PM: In Build command from Netlify app:
12:32:11 PM: bin/build-netlify
12:32:11 PM:
12:32:11 PM: Resolved config
12:32:11 PM: build:
12:32:11 PM: command: bin/build-netlify
12:32:11 PM: commandOrigin: ui
12:32:11 PM: environment:
12:32:11 PM: - REVIEW_ID
12:32:11 PM: publish: /opt/build/repo/public
12:32:11 PM: publishOrigin: ui
12:32:11 PM: Caching artifacts
12:32:11 PM: Started saving build plugins
12:32:11 PM: Finished saving build plugins
12:32:11 PM: Started saving pip cache
12:32:11 PM: Finished saving pip cache
12:32:11 PM: Started saving emacs cask dependencies
12:32:11 PM: Finished saving emacs cask dependencies
12:32:11 PM: Started saving maven dependencies
12:32:11 PM: Finished saving maven dependencies
12:32:11 PM: Started saving boot dependencies
12:32:11 PM: Finished saving boot dependencies
12:32:11 PM: Started saving rust rustup cache
12:32:16 PM: Finished saving rust rustup cache
12:32:16 PM: Started saving rust cargo registry cache
12:32:17 PM: Finished saving rust cargo registry cache
12:32:17 PM: Started saving rust cargo bin cache
12:32:17 PM: Finished saving rust cargo bin cache
12:32:17 PM: Started saving go dependencies
12:32:17 PM: Finished saving go dependencies
12:32:19 PM: Build failed due to a user error: Build script returned non-zero exit code: 2
12:32:19 PM: Creating deploy upload records
12:32:19 PM: Failing build: Failed to build site
12:32:19 PM: Failed during stage 'building site': Build script returned non-zero exit code: 2
12:32:19 PM: Finished processing build request in 1m5.532674069s
I tried installing clang but the error persists, for some reason is not looking for it in the right location.
