I have a monorepo setup and this is what my project structure looks like this
api/
app/
website/
├─ src/
├─ netlify.toml
netlify.toml
package.json
yarn.lock
I have two netlify.toml files, one at the project root which looks like this:
[build]
base = "website/"
ignore = "git diff --quiet $COMMIT_REF $CACHED_COMMIT_REF -- ."
[build.environment]
NETLIFY_USE_YARN = true
YARN_VERSION = "1.22.19"
YARN_WORKSPACES = true
[[redirects]]
from = "https://xxxxxxxx.netlify.app"
to = "https://xxxxxxxx.com"
status = 301
force = true
and another one place inside the subdirectory website/ which looks like
[build]
command = "yarn build"
publish = "build"
Problem is that these aren’t working and are not even being processed, i checked the generated _redirects file inside build folder and it didn’t contain the redirect it just had
* /.netlify/functions/render 200
Am i doing something wrong?
Only 1 netlify.toml is processed. If you’ve set a base path in your site settings, Netlify will read the netlify.toml from there.
Which one? and can you tell me how can i fix this
If i get rid of the root netlify.toml, move all settings to website/netlify.toml and set base path to website/ in site settings like you said i get build error
Failed during stage 'Reading and parsing configuration files':
cannot unmarshal bool into Go struct field BuildConfig.Config.build.environment of type string
After fixing build environment variable thing by wrapping boolean values under [build.environment] in double quotes i’m now getting a different error
7:42:23 PM: Error: Redirects are not supported in netlify.toml. Use _redirects instead. For more details consult the readme's troubleshooting section.
Could you share your current toml? That error doesn’t seem from us. Actually, your site name would be more helpful.
Ahh, i think this error is coming from netlify adapter by sveltekit [111843a]
My current netlify.toml looks like this btw
[build]
base = 'website'
publish = "build"
[build.environment]
NETLIFY_USE_YARN = "true"
YARN_WORKSPACES = "true"
[[redirects]]
from = "https://xxxxxx.netlify.app"
to = "https://xxxxxx.com"
status = 301
force = true
So based on this, is it resolved, or do you still need help?
Yeah, bit hacky but i managed to fix it by committing my _redirects file inside build folder containing redirect rules
https://xxxxxx.netlify.app https://xxxxxx.com 301!
