i am deploying my site buiderwppage.com site with netlify, i want to design my site using static code, i have to add my folder folder is santanu.html ,but not open.
To start with, that domain doesn’t resolve. And we need to check your folder and not just its name.
ok, how to check my folder? how can i help you?
Aren’t you uploading it to Netlify? Just upload the same thing as a zip file to some cloud storage and share the link.
how to submit cloud storage? and create zip file of html file?
i am a new be person.
Google Drive, Dropbox, etc. are examples of cloud storage. You upload files there just like you’d typically upload files online. Upload the file there and share the link.
Creating a zip depends on what operating system you’re using. I don’t know about macOS, but on Windows, it’s as simple as a right click > send to > compressed folder.
I’d suggest you to find online resources that would help you.
Also note, a new user has some daily post limit I guess, to prevent spam. You might soon run out of that. Then, you might not be able to reply for the next few hours.
compress my folder then what i do?
Upload the file somewhere from where you can share it for others to download and check.
Kindly turn link sharing on, so people can access it. Here’s how: Share files from Google Drive - Computer - Google Drive Help
i shared
It’s still the same.
please check with link
As I can see, you’re uploading a shortcut (probably copied from your Desktop). There’s no index.html inside this. You’ve named the folder index.html instead.
What you need to do it create a folder with any name > create a file named index.html inside that folder and add your HTML code in it. Then you need to upload that folder to Netlify.
