hi folks,
I’m putting the netlify-cms admin under /admin. This works fine except when using netlify Identity, it sends admin users to the root to verify/setup their admin account, rather than /admin, and I can’t modify that Identity template unless I move up a plan. I also use Large Media, so I can’t put the admin functionality under a different sub-domain and link to the same repo. Long and short: /admin is where it lives.
This works except for setup, when netlify Identity send setup links such as /#invite_token=some_token. I would like to use redirects to change that, such as:
/#invite_token=:invite_token /admin/#invite_token=:invite_token 301!
or
[[redirects]]
from = "/#invite_token=:invite_token"
to = "/admin/#invite_token=:invite_token"
status = 301
force = true
however, this doesn’t seem to work; after some local and remote testing, I’m starting to strongly suspect that the underlying proxy/redirect engine can’t handle #. Escaping # doesn’t seem to work either.
I can add JS into the landing page to do this redirect based upon the anchor tag, but I would prefer to do it at the redirect level. Suggestions?
