This is a very recent error I encountered when running puppeteer on a deployed draft site. I don’t claim this is a Netlify issue, but maybe I can get pointed in the right direction.
Full error text is below:
ERROR! Error: Could not find Chromium (rev. 1108766). This can occur if either 1. you did not perform an installation before running the script (e.g.
npm install) or 2. your cache path is incorrectly configured (which is: /home/sbx_user1051/.cache/puppeteer). For (2), check out our guide on configuring puppeteer at Configuration | Puppeteer.
and the draft site is:
https://642f3487fd33ef0a93ae06c3--pgnfen3.netlify.app/; go to Import PGN Files (this calls a lambda function, which uses puppeteer to access a web site)
Things I’ve tried:
- set AWS_LAMBDA_JS_RUNTIME to
nodejs18.x - disabled cache in puppeteer:
await page.setCacheEnabled(false) - cleared the browser cache
- cleared the build cache:
yarn cache clear --force - deployed with --skip-functions-cache
Did the cache path become invalid? It used to work with a simple netlify deploy
Here’s the build log:
Netlify Build
❯ Version
@netlify/build 29.5.8
❯ Flags
dry: false
offline: false
❯ Current directory
/home/jlowery2663/pgnfen3
❯ Config file
/home/jlowery2663/pgnfen3/netlify.toml
❯ Context
production
1. build.command from netlify.toml
$ react-scripts build
Creating an optimized production build...
Compiled successfully.
File sizes after gzip:
605.7 kB build/static/js/main.7a5a1832.js
2.55 kB build/static/css/main.56d686b3.css
1.78 kB build/static/js/787.ffec13a5.chunk.js
The bundle size is significantly larger than recommended.
Consider reducing it with code splitting: https://goo.gl/9VhYWB
You can also analyze the project dependencies: https://goo.gl/LeUzfb
The project was built assuming it is hosted at /.
You can control this with the homepage field in your package.json.
The build folder is ready to be deployed.
You may serve it with a static server:
yarn global add serve
serve -s build
Find out more about deployment here:
https://cra.link/deployment
(build.command completed in 19.8s)
2. Functions bundling
Packaging Functions from netlify/functions directory:
- testgql.js
- pgnfen/pgnfen.js
❯ The following Node.js modules use dynamic expressions to include files:
- yargs
- yargs-parser
Because files included with dynamic expressions aren't bundled with your serverless functions by default,
this may result in an error when invoking a function. To resolve this error, you can mark these Node.js
modules as external in the [functions] section of your `netlify.toml` configuration file:
[functions]
external_node_modules = ["yargs", "yargs-parser"]
Visit https://ntl.fyi/dynamic-imports for more information.
(Functions bundling completed in 7.4s)
Netlify Build Complete
