I have been having a problem with the installation of my SSL certificate in my domain librerianacional.com but it has been impossible because I get the error: Certificate Private key not match certificate.
Does this have to do with the conversion of the .crt and .pem files?
It is not the same situation, I have 3 files, one .crt, another .pem and the bundle.crt
If I put the private key with which the certificate was generated in GoDaddy next to my .crt or .pem file, it appears that the certificate does not match the Private key.
OK, you’ll need to work with godaddy on that - we don’t know anything about their certs and we can’t change them for you or help you debug conversions you’ve done or what format they have sent you What I know is that you need what is described here: HTTPS (SSL) | Netlify Docs
and you will want these things (with example formats shown :))
the certificate itself, in X.509 PEM format (usually a .crt file)
This should start with something like:
-----BEGIN CERTIFICATE-----
MIIGbDCCB
and end with something like:
....A==
-----END CERTIFICATE-----
the private key you used to request the certificate
Should start with something like:
-----BEGIN PRIVATE KEY-----
MIIEvQIBADANB
and end with:
....nQjRDxA=
-----END PRIVATE KEY-----
a chain of intermediary certificates from your Certificate Authority (CA)
This should be a single file, but may be several certificates concatenated together in the file, looking like:
MIIE
and ending with
E4f97Q=
(note there may be many similar stanzas in the same file, or only one; both ways can be valid).
I just wanted to follow up here and let you know that as a result of your question, we have written a support guide outlining tips for bringing your own custom SSL certificates to Netlify. Thanks for starting this conversation back in February. Hopefully future Forums members who find themselves in a similar situation will find this useful!
