Hi, I’d appreciate some help with this. I’m trying to use the “relation” widget for the collection “projects tags” but I can’t get the input to show the tags that I have stored in the collection (projects tags)… Always show “no options”.
Try creating a project tag through the cms and see if its format matches the tags you already have stored. I don’t see anything wrong with your config at least…
Okok, at least my config is ok. But the tags that I have stored were created in the cms. That’s why I don’t understand why they don’t show in the relation widget.
Ok I fix the error and tried to use the script that I told you before, just to see if the problem was the property name, but no, with the script with the custom id widget doesn’t work.
In theory my problem is solved. Thank you very mucho bro, but any suggestion on how I could add an id to the projects collection? cause now I can’t use that custom widget id
I switched from ncw-file-relation widget to the latest relation widget that has been recently extended to support folder to file collections relationship. Before the switch the performances were acceptable even with big JSON files as per mfi indicator crypto. The new relation widget, instead, stays in waiting state forever.
Hi @joliyasmith , welcome to the forums and thanks so much for reaching out. Can you share your site name so we can look into this and specifically what your issue is?
