Problem deploying Website "Build failed due to a user error: Build script returned non-zero exit code: 2"
9:29:34 AM: Build ready to start
9:29:36 AM: build-image version: 122b31996ccaffd45d820a452d6227f8312110cc (focal)
9:29:36 AM: build-image tag: v4.5.3
9:29:36 AM: buildbot version: 45faaf324677495f3400b572da79977ab3212265
9:29:36 AM: Fetching cached dependencies
9:29:36 AM: Failed to fetch cache, continuing with build
9:29:36 AM: Starting to prepare the repo for build
9:29:36 AM: No cached dependencies found. Cloning fresh repo
9:29:36 AM: git clone https://github.com/lmssr/notionProtfolioBLog
9:29:40 AM: Preparing Git Reference refs/heads/master
9:29:41 AM: Parsing package.json dependencies
9:29:42 AM: Starting build script
9:29:42 AM: Installing dependencies
9:29:42 AM: Python version set to 2.7
9:29:43 AM: v16.13.2 is already installed.
9:29:43 AM: Now using node v16.13.2 (npm v8.1.2)
9:29:43 AM: Started restoring cached build plugins
9:29:43 AM: Finished restoring cached build plugins
9:29:43 AM: Attempting ruby version 2.7.2, read from environment
9:29:45 AM: Using ruby version 2.7.2
9:29:45 AM: Using PHP version 8.0
9:29:45 AM: Started restoring cached yarn cache
9:29:45 AM: Finished restoring cached yarn cache
9:29:46 AM: No yarn workspaces detected
9:29:46 AM: Started restoring cached node modules
9:29:46 AM: Finished restoring cached node modules
9:29:46 AM: Installing NPM modules using Yarn version 1.22.10
9:29:47 AM: yarn install v1.22.10
9:29:47 AM: warning package-lock.json found. Your project contains lock files generated by tools other than Yarn. It is advised not to mix package managers in order to avoid resolution inconsistencies caused by unsynchronized lock files. To clear this warning, remove package-lock.json.
9:29:47 AM: [1/4] Resolving packages...
9:29:47 AM: [2/4] Fetching packages...
9:30:06 AM: info @next/swc-darwin-arm64@11.1.3: The platform "linux" is incompatible with this module.
9:30:06 AM: info "@next/swc-darwin-arm64@11.1.3" is an optional dependency and failed compatibility check. Excluding it from installation.
9:30:06 AM: info @next/swc-darwin-arm64@11.1.3: The CPU architecture "x64" is incompatible with this module.
9:30:06 AM: info @next/swc-darwin-x64@11.1.3: The platform "linux" is incompatible with this module.
9:30:06 AM: info "@next/swc-darwin-x64@11.1.3" is an optional dependency and failed compatibility check. Excluding it from installation.
9:30:06 AM: info @next/swc-win32-x64-msvc@11.1.3: The platform "linux" is incompatible with this module.
9:30:06 AM: info "@next/swc-win32-x64-msvc@11.1.3" is an optional dependency and failed compatibility check. Excluding it from installation.
9:30:06 AM: info fsevents@2.3.2: The platform "linux" is incompatible with this module.
9:30:06 AM: info "fsevents@2.3.2" is an optional dependency and failed compatibility check. Excluding it from installation.
9:30:06 AM: [3/4] Linking dependencies...
9:30:06 AM: warning " > @chakra-ui/icons@1.1.1" has unmet peer dependency "@chakra-ui/system@>=1.0.0".
9:30:06 AM: warning "@chakra-ui/icons > @chakra-ui/icon@1.2.1" has unmet peer dependency "@chakra-ui/system@>=1.0.0".
9:30:06 AM: warning "@emotion/styled > @emotion/babel-plugin@11.7.2" has unmet peer dependency "@babel/core@^7.0.0".
9:30:06 AM: warning "@emotion/styled > @emotion/babel-plugin > @babel/plugin-syntax-jsx@7.16.7" has unmet peer dependency "@babel/core@^7.0.0-0".
9:30:06 AM: warning "next > styled-jsx > @babel/plugin-syntax-jsx@7.14.5" has unmet peer dependency "@babel/core@^7.0.0-0".
9:30:06 AM: warning "eslint-config-next > @typescript-eslint/parser > @typescript-eslint/typescript-estree > tsutils@3.21.0" has unmet peer dependency "typescript@>=2.8.0 || >= 3.2.0-dev || >= 3.3.0-dev || >= 3.4.0-dev || >= 3.5.0-dev || >= 3.6.0-dev || >= 3.6.0-beta || >= 3.7.0-dev || >= 3.7.0-beta".
9:30:14 AM: [4/4] Building fresh packages...
9:30:14 AM: success Saved lockfile.
9:30:14 AM: Done in 27.65s.
9:30:14 AM: NPM modules installed using Yarn
9:30:15 AM: Started restoring cached go cache
9:30:15 AM: Finished restoring cached go cache
9:30:15 AM: go version go1.16.5 linux/amd64
9:30:15 AM: Installing missing commands
9:30:15 AM: Verify run directory
9:30:16 AM: ​
9:30:16 AM: ────────────────────────────────────────────────────────────────
9:30:16 AM:   Netlify Build
9:30:16 AM: ​
9:30:16 AM: ❯ Version
9:30:16 AM:   @netlify/build 26.2.2
9:30:16 AM: ​
9:30:16 AM: ❯ Flags
9:30:16 AM:   baseRelDir: true
9:30:16 AM:   buildId: 61f3a96e1b85077432a255d6
9:30:16 AM:   deployId: 61f3a96e1b85077432a255d8
9:30:16 AM: ​
9:30:16 AM: ❯ Current directory
9:30:16 AM:   /opt/build/repo
9:30:16 AM: ​
9:30:16 AM: ❯ Config file
9:30:16 AM:   No config file was defined: using default values.
9:30:16 AM: ​
9:30:16 AM: ❯ Context
9:30:16 AM:   production
9:30:16 AM: ​
9:30:16 AM: ❯ Installing plugins
9:30:16 AM:    - @netlify/plugin-nextjs@4.2.1
9:30:28 AM: ​
9:30:28 AM: ❯ Loading plugins
9:30:28 AM:    - @netlify/plugin-nextjs@4.2.1 from Netlify app
9:30:29 AM: ​
9:30:29 AM: ────────────────────────────────────────────────────────────────
9:30:29 AM:   1. @netlify/plugin-nextjs (onPreBuild event)
9:30:29 AM: ​
9:30:29 AM: No Next.js cache to restore.
9:30:29 AM: Netlify configuration property "build.environment.NEXT_PRIVATE_TARGET" value changed.
9:30:29 AM: ​
9:30:29 AM: (@netlify/plugin-nextjs onPreBuild completed in 25ms)
9:30:29 AM: ​
9:30:29 AM:   2. Build command from Netlify app
9:30:29 AM: ​
9:30:29 AM: $ CI = npm run build
9:30:29 AM: bash: CI: command not found
9:30:30 AM: ​
9:30:30 AM: ────────────────────────────────────────────────────────────────
9:30:30 AM:   "build.command" failed
9:30:30 AM: ​
9:30:30 AM:   Error message
9:30:30 AM:   Command failed with exit code 127: CI = npm run build
9:30:30 AM: ​
9:30:30 AM:   Error location
9:30:30 AM:   In Build command from Netlify app:
9:30:30 AM:   CI = npm run build
9:30:30 AM: ​
9:30:30 AM:   Resolved config
9:30:30 AM:   build:
9:30:30 AM:     command: CI = npm run build
9:30:30 AM:     commandOrigin: ui
9:30:30 AM:     environment:
9:30:30 AM:       - NEXT_PRIVATE_TARGET
9:30:30 AM:     publish: /opt/build/repo/.next
9:30:30 AM:     publishOrigin: ui
9:30:30 AM:   plugins:
9:30:30 AM:     - inputs: {}
9:30:30 AM:       origin: ui
9:30:30 AM:       package: '@netlify/plugin-nextjs'
9:30:30 AM: Caching artifacts
9:30:30 AM: Started saving node modules
9:30:30 AM: Finished saving node modules
9:30:30 AM: Started saving build plugins
9:30:30 AM: Finished saving build plugins
9:30:30 AM: Started saving yarn cache
9:30:33 AM: Finished saving yarn cache
9:30:33 AM: Started saving pip cache
9:30:33 AM: Finished saving pip cache
9:30:33 AM: Started saving emacs cask dependencies
9:30:33 AM: Finished saving emacs cask dependencies
9:30:33 AM: Started saving maven dependencies
9:30:33 AM: Finished saving maven dependencies
9:30:33 AM: Started saving boot dependencies
9:30:33 AM: Finished saving boot dependencies
9:30:33 AM: Started saving rust rustup cache
9:30:33 AM: Finished saving rust rustup cache
9:30:33 AM: Started saving go dependencies
9:30:33 AM: Finished saving go dependencies
9:30:35 AM: Build failed due to a user error: Build script returned non-zero exit code: 2
9:30:35 AM: Creating deploy upload records
9:30:35 AM: Failing build: Failed to build site
9:30:35 AM: Failed during stage 'building site': Build script returned non-zero exit code: 2
9:30:35 AM: Finished processing build request in 59.562515808s
I tried to deploy my website, but for some reasons, it returns the error message β€œBuild failed due to a user error: Build script returned non-zero exit code: 2”.
Everything work properly in local machine, but when i deploy on netlify, it is not.
What could be the issue? Can someone guide?
Hi @lmssr
The issue is the space between the CI and the =. The correct command is
CI= npm run build
however, in my situations, npm run build would work equally as well.
Hello @coelmay,
thanks for your answer !
I tried your solution, but I have axactly the same problem (it looks like the build stop further but with the same problem …)
10:27:06 AM: Waiting for other deploys from your team to complete. Check the queue: https://app.netlify.com/teams/lmssr/builds
10:28:57 AM: Build ready to start
10:28:58 AM: build-image version: 122b31996ccaffd45d820a452d6227f8312110cc (focal)
10:28:58 AM: build-image tag: v4.5.3
10:28:58 AM: buildbot version: 45faaf324677495f3400b572da79977ab3212265
10:28:59 AM: Building without cache
10:28:59 AM: Starting to prepare the repo for build
10:28:59 AM: No cached dependencies found. Cloning fresh repo
10:28:59 AM: git clone https://github.com/lmssr/notionProtfolioBLog
10:29:02 AM: Preparing Git Reference refs/heads/master
10:29:03 AM: Parsing package.json dependencies
10:29:04 AM: Starting build script
10:29:04 AM: Installing dependencies
10:29:04 AM: Python version set to 2.7
10:29:05 AM: v16.13.2 is already installed.
10:29:05 AM: Now using node v16.13.2 (npm v8.1.2)
10:29:05 AM: Started restoring cached build plugins
10:29:05 AM: Finished restoring cached build plugins
10:29:06 AM: Attempting ruby version 2.7.2, read from environment
10:29:07 AM: Using ruby version 2.7.2
10:29:07 AM: Using PHP version 8.0
10:29:07 AM: Started restoring cached yarn cache
10:29:07 AM: Finished restoring cached yarn cache
10:29:08 AM: No yarn workspaces detected
10:29:08 AM: Started restoring cached node modules
10:29:08 AM: Finished restoring cached node modules
10:29:08 AM: Installing NPM modules using Yarn version 1.22.10
10:29:09 AM: yarn install v1.22.10
10:29:09 AM: warning package-lock.json found. Your project contains lock files generated by tools other than Yarn. It is advised not to mix package managers in order to avoid resolution inconsistencies caused by unsynchronized lock files. To clear this warning, remove package-lock.json.
10:29:09 AM: [1/4] Resolving packages...
10:29:09 AM: [2/4] Fetching packages...
10:29:30 AM: info @next/swc-darwin-arm64@11.1.3: The platform "linux" is incompatible with this module.
10:29:30 AM: info "@next/swc-darwin-arm64@11.1.3" is an optional dependency and failed compatibility check. Excluding it from installation.
10:29:30 AM: info @next/swc-darwin-arm64@11.1.3: The CPU architecture "x64" is incompatible with this module.
10:29:30 AM: info @next/swc-darwin-x64@11.1.3: The platform "linux" is incompatible with this module.
10:29:30 AM: info "@next/swc-darwin-x64@11.1.3" is an optional dependency and failed compatibility check. Excluding it from installation.
10:29:30 AM: info @next/swc-win32-x64-msvc@11.1.3: The platform "linux" is incompatible with this module.
10:29:30 AM: info "@next/swc-win32-x64-msvc@11.1.3" is an optional dependency and failed compatibility check. Excluding it from installation.
10:29:30 AM: info fsevents@2.3.2: The platform "linux" is incompatible with this module.
10:29:30 AM: info "fsevents@2.3.2" is an optional dependency and failed compatibility check. Excluding it from installation.
10:29:30 AM: [3/4] Linking dependencies...
10:29:30 AM: warning " > @chakra-ui/icons@1.1.1" has unmet peer dependency "@chakra-ui/system@>=1.0.0".
10:29:30 AM: warning "@chakra-ui/icons > @chakra-ui/icon@1.2.1" has unmet peer dependency "@chakra-ui/system@>=1.0.0".
10:29:30 AM: warning "@emotion/styled > @emotion/babel-plugin@11.7.2" has unmet peer dependency "@babel/core@^7.0.0".
10:29:30 AM: warning "@emotion/styled > @emotion/babel-plugin > @babel/plugin-syntax-jsx@7.16.7" has unmet peer dependency "@babel/core@^7.0.0-0".
10:29:30 AM: warning "next > styled-jsx > @babel/plugin-syntax-jsx@7.14.5" has unmet peer dependency "@babel/core@^7.0.0-0".
10:29:30 AM: warning "eslint-config-next > @typescript-eslint/parser > @typescript-eslint/typescript-estree > tsutils@3.21.0" has unmet peer dependency "typescript@>=2.8.0 || >= 3.2.0-dev || >= 3.3.0-dev || >= 3.4.0-dev || >= 3.5.0-dev || >= 3.6.0-dev || >= 3.6.0-beta || >= 3.7.0-dev || >= 3.7.0-beta".
10:29:38 AM: [4/4] Building fresh packages...
10:29:39 AM: success Saved lockfile.
10:29:39 AM: Done in 30.46s.
10:29:39 AM: NPM modules installed using Yarn
10:29:39 AM: Started restoring cached go cache
10:29:39 AM: Finished restoring cached go cache
10:29:39 AM: go version go1.16.5 linux/amd64
10:29:40 AM: go version go1.16.5 linux/amd64
10:29:40 AM: Installing missing commands
10:29:40 AM: Verify run directory
10:29:41 AM: ​
10:29:41 AM: ────────────────────────────────────────────────────────────────
10:29:41 AM:   Netlify Build
10:29:41 AM: ​
10:29:41 AM: ❯ Version
10:29:41 AM:   @netlify/build 26.2.2
10:29:41 AM: ​
10:29:41 AM: ❯ Flags
10:29:41 AM:   baseRelDir: true
10:29:41 AM:   buildId: 61f3b6ea96a7cd8253618111
10:29:41 AM:   deployId: 61f3b6ea96a7cd8253618113
10:29:41 AM: ​
10:29:41 AM: ❯ Current directory
10:29:41 AM:   /opt/build/repo
10:29:41 AM: ​
10:29:41 AM: ❯ Config file
10:29:41 AM:   No config file was defined: using default values.
10:29:41 AM: ​
10:29:41 AM: ❯ Context
10:29:41 AM:   production
10:29:41 AM: ​
10:29:41 AM: ❯ Installing plugins
10:29:41 AM:    - @netlify/plugin-nextjs@4.2.1
10:29:53 AM: ​
10:29:53 AM: ❯ Loading plugins
10:29:53 AM:    - @netlify/plugin-nextjs@4.2.1 from Netlify app
10:29:55 AM: ​
10:29:55 AM: ────────────────────────────────────────────────────────────────
10:29:55 AM:   1. @netlify/plugin-nextjs (onPreBuild event)
10:29:55 AM: ​
10:29:55 AM: No Next.js cache to restore.
10:29:55 AM: Netlify configuration property "build.environment.NEXT_PRIVATE_TARGET" value changed.
10:29:55 AM: ​
10:29:55 AM: (@netlify/plugin-nextjs onPreBuild completed in 24ms)
10:29:55 AM: ​
10:29:55 AM:   2. Build command from Netlify app
10:29:55 AM: ​
10:29:55 AM: $ CI= npm run build
10:29:55 AM: > blion@1.0.0 build
10:29:55 AM: > next build
10:29:57 AM: info  - Using webpack 5. Reason: Enabled by default https://nextjs.org/docs/messages/webpack5
10:29:57 AM: warn  - No build cache found. Please configure build caching for faster rebuilds. Read more: https://nextjs.org/docs/messages/no-cache
10:29:57 AM: info  - Checking validity of types...
10:29:57 AM: info  - Creating an optimized production build...
10:30:45 AM: warn  - Compiled with warnings
10:30:45 AM: ./src/pages/404.js
10:30:45 AM: export 'getInitialProps' (reexported as 'getInitialProps') was not found in '../components/chakra' (possible exports: default, getServerSideProps)
10:30:45 AM: info  - Collecting page data...
10:30:49 AM: Client warn: request fail { code: 'unauthorized', message: 'API token is invalid.' }
10:30:49 AM: > Build error occurred
10:30:49 AM: Error [APIResponseError]: API token is invalid.
10:30:49 AM:     at Object.buildRequestError (/opt/build/repo/node_modules/@notionhq/client/build/src/errors.js:79:20)
10:30:49 AM:     at Client.request (/opt/build/repo/node_modules/@notionhq/client/build/src/Client.js:206:43)
10:30:49 AM:     at processTicksAndRejections (node:internal/process/task_queues:96:5)
10:30:49 AM:     at async getPosts (/opt/build/repo/.next/server/chunks/493.js:23:20)
10:30:49 AM:     at async getStaticPaths (/opt/build/repo/.next/server/pages/post/[slug].js:209:17)
10:30:49 AM:     at async buildStaticPaths (/opt/build/repo/node_modules/next/dist/build/utils.js:472:31)
10:30:49 AM:     at async /opt/build/repo/node_modules/next/dist/build/utils.js:615:119
10:30:49 AM:     at async Span.traceAsyncFn (/opt/build/repo/node_modules/next/dist/telemetry/trace/trace.js:60:20) {
10:30:49 AM:   type: 'APIResponseError',
10:30:49 AM:   code: 'unauthorized',
10:30:49 AM:   status: 401,
10:30:49 AM:   headers: {
10:30:49 AM:     date: 'Fri, 28 Jan 2022 09:30:49 GMT',
10:30:49 AM:     'content-type': 'application/json; charset=utf-8',
10:30:49 AM:     'content-length': '87',
10:30:49 AM:     connection: 'close',
10:30:49 AM:     'set-cookie': [
10:30:49 AM:       'notion_browser_id=4bf7c956-1853-4a17-baad-be13bd35dcb2; Domain=www.notion.so; Path=/; Expires=Sat, 28 Jan 2023 09:30:49 GMT; Secure',
10:30:49 AM:       'notion_experiment_device_id=b8c6c8b9-d6a8-4a77-9e50-2a748b43afc9; Domain=www.notion.so; Path=/; Expires=Sat, 28 Jan 2023 09:30:49 GMT; Secure',
10:30:49 AM:       'notion_check_cookie_consent=false; Domain=www.notion.so; Path=/; Expires=Sat, 29 Jan 2022 09:30:49 GMT; Secure'
10:30:49 AM:     ],
10:30:49 AM:     'x-dns-prefetch-control': 'off',
10:30:49 AM:     'x-frame-options': 'SAMEORIGIN',
10:30:49 AM:     'strict-transport-security': 'max-age=5184000; includeSubDomains',
10:30:49 AM:     'x-download-options': 'noopen',
10:30:49 AM:     'x-content-type-options': 'nosniff',
10:30:49 AM:     'x-xss-protection': '1; mode=block',
10:30:49 AM:     'referrer-policy': 'same-origin',
10:30:49 AM:     'content-security-policy': "script-src 'self' 'unsafe-inline' 'unsafe-eval' https://gist.github.com https://apis.google.com https://cdn.amplitude.com https://api.amplitude.com https://hkfxbbdzib.notion.so https://widget.intercom.io https://js.intercomcdn.com https://logs-01.loggly.com https://cdn.segment.com https://analytics.pgncs.notion.so https://o324374.ingest.sentry.io https://checkout.stripe.com https://js.stripe.com https://embed.typeform.com https://admin.typeform.com https://public.profitwell.com js.sentry-cdn.com https://js.chilipiper.com https://platform.twitter.com https://cdn.syndication.twimg.com; connect-src 'self' https://msgstore.www.notion.so wss://msgstore.www.notion.so ws://localhost:* ws://127.0.0.1:* https://notion-emojis.s3-us-west-2.amazonaws.com https://s3-us-west-2.amazonaws.com https://s3.us-west-2.amazonaws.com https://notion-production-snapshots-2.s3.us-west-2.amazonaws.com https: http: https://cdn.amplitude.com https://api.amplitude.com https://hkfxbbdzib.notion.so https://api.embed.ly https://js.intercomcdn.com https://api-iam.intercom.io wss://nexus-websocket-a.intercom.io https://logs-01.loggly.com https://cdn.segment.com https://api.segment.io https://analytics.pgncs.notion.so https://api.pgncs.notion.so https://o324374.ingest.sentry.io https://checkout.stripe.com https://js.stripe.com https://cdn.contentful.com https://preview.contentful.com https://images.ctfassets.net https://www2.profitwell.com https://tracking.chilipiper.com https://api.chilipiper.com https://api.unsplash.com https://boards-api.greenhouse.io https://api.statuspage.io https://pgncd.notion.so https://api.statsig.com; font-src 'self' data: https://cdnjs.cloudflare.com https://js.intercomcdn.com; img-src 'self' data: blob: https: https://platform.twitter.com https://syndication.twitter.com https://pbs.twimg.com https://ton.twimg.com; style-src 'self' 'unsafe-inline' https://cdnjs.cloudflare.com https://github.githubassets.com https://js.chilipiper.com https://platform.twitter.com https://ton.twimg.com; frame-src https: http:; media-src https: http:",
10:30:49 AM:     'x-content-security-policy': "script-src 'self' 'unsafe-inline' 'unsafe-eval' https://gist.github.com https://apis.google.com https://cdn.amplitude.com https://api.amplitude.com https://hkfxbbdzib.notion.so https://widget.intercom.io https://js.intercomcdn.com https://logs-01.loggly.com https://cdn.segment.com https://analytics.pgncs.notion.so https://o324374.ingest.sentry.io https://checkout.stripe.com https://js.stripe.com https://embed.typeform.com https://admin.typeform.com https://public.profitwell.com js.sentry-cdn.com https://js.chilipiper.com https://platform.twitter.com https://cdn.syndication.twimg.com; connect-src 'self' https://msgstore.www.notion.so wss://msgstore.www.notion.so ws://localhost:* ws://127.0.0.1:* https://notion-emojis.s3-us-west-2.amazonaws.com https://s3-us-west-2.amazonaws.com https://s3.us-west-2.amazonaws.com https://notion-production-snapshots-2.s3.us-west-2.amazonaws.com https: http: https://cdn.amplitude.com https://api.amplitude.com https://hkfxbbdzib.notion.so https://api.embed.ly https://js.intercomcdn.com https://api-iam.intercom.io wss://nexus-websocket-a.intercom.io https://logs-01.loggly.com https://cdn.segment.com https://api.segment.io https://analytics.pgncs.notion.so https://api.pgncs.notion.so https://o324374.ingest.sentry.io https://checkout.stripe.com https://js.stripe.com https://cdn.contentful.com https://preview.contentful.com https://images.ctfassets.net https://www2.profitwell.com https://tracking.chilipiper.com https://api.chilipiper.com https://api.unsplash.com https://boards-api.greenhouse.io https://api.statuspage.io https://pgncd.notion.so https://api.statsig.com; font-src 'self' data: https://cdnjs.cloudflare.com https://js.intercomcdn.com; img-src 'self' data: blob: https: https://platform.twitter.com https://syndication.twitter.com https://pbs.twimg.com https://ton.twimg.com; style-src 'self' 'unsafe-inline' https://cdnjs.cloudflare.com https://github.githubassets.com https://js.chilipiper.com https://platform.twitter.com https://ton.twimg.com; frame-src https: http:; media-src https: http:",
10:30:49 AM:     'x-webkit-csp': "script-src 'self' 'unsafe-inline' 'unsafe-eval' https://gist.github.com https://apis.google.com https://cdn.amplitude.com https://api.amplitude.com https://hkfxbbdzib.notion.so https://widget.intercom.io https://js.intercomcdn.com https://logs-01.loggly.com https://cdn.segment.com https://analytics.pgncs.notion.so https://o324374.ingest.sentry.io https://checkout.stripe.com https://js.stripe.com https://embed.typeform.com https://admin.typeform.com https://public.profitwell.com js.sentry-cdn.com https://js.chilipiper.com https://platform.twitter.com https://cdn.syndication.twimg.com; connect-src 'self' https://msgstore.www.notion.so wss://msgstore.www.notion.so ws://localhost:* ws://127.0.0.1:* https://notion-emojis.s3-us-west-2.amazonaws.com https://s3-us-west-2.amazonaws.com https://s3.us-west-2.amazonaws.com https://notion-production-snapshots-2.s3.us-west-2.amazonaws.com https: http: https://cdn.amplitude.com https://api.amplitude.com https://hkfxbbdzib.notion.so https://api.embed.ly https://js.intercomcdn.com https://api-iam.intercom.io wss://nexus-websocket-a.intercom.io https://logs-01.loggly.com https://cdn.segment.com https://api.segment.io https://analytics.pgncs.notion.so https://api.pgncs.notion.so https://o324374.ingest.sentry.io https://checkout.stripe.com https://js.stripe.com https://cdn.contentful.com https://preview.contentful.com https://images.ctfassets.net https://www2.profitwell.com https://tracking.chilipiper.com https://api.chilipiper.com https://api.unsplash.com https://boards-api.greenhouse.io https://api.statuspage.io https://pgncd.notion.so https://api.statsig.com; font-src 'self' data: https://cdnjs.cloudflare.com https://js.intercomcdn.com; img-src 'self' data: blob: https: https://platform.twitter.com https://syndication.twitter.com https://pbs.twimg.com https://ton.twimg.com; style-src 'self' 'unsafe-inline' https://cdnjs.cloudflare.com https://github.githubassets.com https://js.chilipiper.com https://platform.twitter.com https://ton.twimg.com; frame-src https: http:; media-src https: http:",
10:30:49 AM:     etag: 'W/"57-QCRLT3IovYEW+CkwyJQlFtiXiG8"',
10:30:49 AM:     vary: 'Accept-Encoding',
10:30:49 AM:     'cf-cache-status': 'DYNAMIC',
10:30:49 AM:     'expect-ct': 'max-age=604800, report-uri="https://report-uri.cloudflare.com/cdn-cgi/beacon/expect-ct"',
10:30:49 AM:     server: 'cloudflare',
10:30:49 AM:     'cf-ray': '6d4934490f9d8133-ORD'
10:30:49 AM:   },
10:30:49 AM:   body: '{"object":"error","status":401,"code":"unauthorized","message":"API token is invalid."}'
10:30:49 AM: }
10:30:49 AM: ​
10:30:49 AM: ────────────────────────────────────────────────────────────────
10:30:49 AM:   "build.command" failed
10:30:49 AM: ​
10:30:49 AM:   Error message
10:30:49 AM:   Command failed with exit code 1: CI= npm run build
10:30:49 AM: ​
10:30:49 AM:   Error location
10:30:49 AM:   In Build command from Netlify app:
10:30:49 AM:   CI= npm run build
10:30:49 AM: ​
10:30:49 AM:   Resolved config
10:30:49 AM:   build:
10:30:49 AM:     command: CI= npm run build
10:30:49 AM:     commandOrigin: ui
10:30:49 AM:     environment:
10:30:49 AM:       - NEXT_PRIVATE_TARGET
10:30:49 AM:     publish: /opt/build/repo/.next
10:30:49 AM:     publishOrigin: ui
10:30:49 AM:   plugins:
10:30:49 AM:     - inputs: {}
10:30:49 AM:       origin: ui
10:30:49 AM:       package: '@netlify/plugin-nextjs'
10:30:49 AM: Caching artifacts
10:30:49 AM: Started saving node modules
10:30:49 AM: Finished saving node modules
10:30:49 AM: Started saving build plugins
10:30:49 AM: Finished saving build plugins
10:30:49 AM: Started saving yarn cache
10:30:53 AM: Finished saving yarn cache
10:30:53 AM: Started saving pip cache
10:30:53 AM: Finished saving pip cache
10:30:53 AM: Started saving emacs cask dependencies
10:30:53 AM: Finished saving emacs cask dependencies
10:30:53 AM: Started saving maven dependencies
10:30:53 AM: Finished saving maven dependencies
10:30:53 AM: Started saving boot dependencies
10:30:53 AM: Finished saving boot dependencies
10:30:53 AM: Started saving rust rustup cache
10:30:53 AM: Finished saving rust rustup cache
10:30:53 AM: Started saving go dependencies
10:30:53 AM: Finished saving go dependencies
10:30:55 AM: Build failed due to a user error: Build script returned non-zero exit code: 2
10:30:55 AM: Creating deploy upload records
10:30:56 AM: Failing build: Failed to build site
10:30:56 AM: Failed during stage 'building site': Build script returned non-zero exit code: 2
10:30:56 AM: Finished processing build request in 1m57.281946148s
hi there Imssr,
the problem is now located in the code section mentioned above. Are you sure your API token is correct and in the right place?
Hi @perry,
Thanks for your answer !
The problem was effectively with the API. I changed everything, and it worked. But I don’t really understand why it worked loaly ahah
