I am trying to create my own plugin but I get this error when I want to test
Netlify Build
❯ Version
@netlify/build 27.1.3
❯ Flags
dry: false
offline: false
❯ Current directory
C:\Users\Jarri\Documents\GitHub\v3\storefront
❯ Config file
C:\Users\Jarri\Documents\GitHub\v3\netlify.toml
❯ Context
production
Configuration error
Error message
Plugin could not be found using local path: .plugins/netlify-plugin-reflect-run
Cannot find module '.plugins/netlify-plugin-reflect-run'
Require stack:
- C:\Users\Jarri\AppData\Roaming\nvm\v16.14.0\node_modules\netlify-cli\node_modules\@netlify\build\src\utils\resolve.js
Resolved config
build:
base: C:\Users\Jarri\Documents\GitHub\v3\storefront
command: yarn build
commandOrigin: config
publish: C:\Users\Jarri\Documents\GitHub\v3\storefront\dist
publishOrigin: config
plugins:
- inputs: {}
origin: config
package: .plugins/netlify-plugin-reflect-run
│ Please update netlify-cli to its latest version. │
│ If netlify-cli is already the latest version, │
│ please update your dependencies lock file instead. │
Environment Info │
System:
OS: Windows 10 10.0.22000
CPU: (16) x64 AMD Ryzen 7 4800H with Radeon Graphics
Binaries:
Node: 16.14.0 - C:\Program Files\nodejs\node.EXE
Yarn: 1.22.19 - C:\Program Files\nodejs\yarn.CMD
npm: 8.5.2 - C:\Program Files\nodejs\npm.CMD
Browsers:
Edge: Spartan (44.22000.120.0), Chromium (102.0.1245.44)
netlify-cli/10.5.1 win32-x64 node-v16.14.0
