Please, I need some help; I keep getting two errors, one is [exit-code-2], and the second is [exit-code-255].
I tried running my website with config.toml, and it didn’t work, but once I switched to the config.yaml, it started working but not deploying.
- Netlify site name:
https://thee-a-team.netlify.app
- my GitHub:
https://github.com/sussmanbu/ma4615-fa22-final-project-the_a_team
3:38:23 PM: build-image version: 524714d1a66d1a967316f5c39465e22c77fdd56c (focal)
3:38:23 PM: build-image tag: v4.16.0
3:38:23 PM: buildbot version: 2956156cff73cc91029b26e56f43b4bf895eefff
3:38:23 PM: Fetching cached dependencies
3:38:23 PM: Starting to download cache of 266.6MB
3:38:26 PM: Finished downloading cache in 2.789838683s
3:38:26 PM: Starting to extract cache
3:38:27 PM: Finished extracting cache in 1.299843988s
3:38:27 PM: Finished fetching cache in 4.129945234s
3:38:27 PM: Starting to prepare the repo for build
3:38:27 PM: Preparing Git Reference refs/heads/master
3:38:33 PM: Parsing package.json dependencies
3:38:33 PM: Section completed: initializing
3:38:33 PM: Starting build script
3:38:33 PM: Installing dependencies
3:38:33 PM: Python version set to 2.7
3:38:34 PM: Started restoring cached node version
3:38:35 PM: Finished restoring cached node version
3:38:35 PM: v16.19.0 is already installed.
3:38:35 PM: Now using node v16.19.0 (npm v8.19.3)
3:38:35 PM: Enabling node corepack
3:38:35 PM: Started restoring cached build plugins
3:38:35 PM: Finished restoring cached build plugins
3:38:35 PM: Attempting ruby version 2.7.2, read from environment
3:38:36 PM: Using ruby version 2.7.2
3:38:36 PM: Using PHP version 8.0
3:38:36 PM: Installing Hugo 0.90.1
3:38:36 PM: hugo v0.90.1-48907889+extended linux/amd64 BuildDate=2021-12-10T10:56:41Z VendorInfo=gohugoio
3:38:36 PM: Started restoring cached go cache
3:38:36 PM: Finished restoring cached go cache
3:38:36 PM: Installing Go version 1.17 (requested 1.17)
3:38:41 PM: unset GOOS;
3:38:41 PM: unset GOARCH;
3:38:41 PM: export GOROOT=‘/opt/buildhome/.gimme/versions/go1.17.linux.amd64’;
3:38:41 PM: export PATH=“/opt/buildhome/.gimme/versions/go1.17.linux.amd64/bin:${PATH}”;
3:38:41 PM: go version >&2;
3:38:41 PM: export GIMME_ENV=“/opt/buildhome/.gimme/env/go1.17.linux.amd64.env”
3:38:41 PM: go version go1.17 linux/amd64
3:38:41 PM: Detected 1 framework(s)
3:38:41 PM: “hugo” at version “unknown”
3:38:41 PM: Installing missing commands
3:38:41 PM: Verify run directory
3:38:42 PM:
3:38:42 PM: ────────────────────────────────────────────────────────────────
3:38:42 PM: Netlify Build
3:38:42 PM:
3:38:42 PM: ❯ Version
3:38:42 PM: @netlify/build 29.1.1
3:38:42 PM:
3:38:42 PM: ❯ Flags
3:38:42 PM: baseRelDir: true
3:38:42 PM: buildId: 639b85a656cd400008254dbf
3:38:42 PM: deployId: 639b85a656cd400008254dc1
3:38:42 PM:
3:38:42 PM: ❯ Current directory
3:38:42 PM: /opt/build/repo
3:38:42 PM:
3:38:42 PM: ❯ Config file
3:38:42 PM: /opt/build/repo/netlify.toml
3:38:42 PM:
3:38:42 PM: ❯ Context
3:38:42 PM: production
3:38:43 PM: Creating deploy upload records
3:38:42 PM:
3:38:42 PM: 1. build.command from netlify.toml
3:38:42 PM:
3:38:43 PM: Failed during stage ‘building site’: Build script returned non-zero exit code: 2 (Search results for '"non-zero exit code: 2"' - Netlify Support Forums)
3:38:42 PM: $ hugo
3:38:42 PM: Start building sites …
3:38:42 PM: hugo v0.90.1-48907889+extended linux/amd64 BuildDate=2021-12-10T10:56:41Z VendorInfo=gohugoio
3:38:43 PM: Error: Error building site: TOCSS: failed to transform “ananke/css/main.css” (text/css): resource “css/ananke/css/main.css_af7eae7717e76be05924f27bac629e80” not found in file cache
3:38:43 PM: Total in 104 ms
3:38:43 PM:
3:38:43 PM: ────────────────────────────────────────────────────────────────
3:38:43 PM: “build.command” failed
3:38:43 PM:
3:38:43 PM: Error message
3:38:43 PM: Command failed with exit code 255: hugo (Search results for '"non-zero exit code: 255"' - Netlify Support Forums)
3:38:43 PM:
3:38:43 PM: Error location
3:38:43 PM: In build.command from netlify.toml:
3:38:43 PM: hugo
3:38:43 PM:
3:38:43 PM: Resolved config
3:38:43 PM: build:
3:38:43 PM: command: hugo
3:38:43 PM: commandOrigin: config
3:38:43 PM: environment:
3:38:43 PM: - NETLIFY_GRAPH_TOKEN
3:38:43 PM: - ONEGRAPH_AUTHLIFY_TOKEN
3:38:43 PM: - HUGO_VERSION
3:38:43 PM: - HUGO_ENV
3:38:43 PM: publish: /opt/build/repo/public
3:38:43 PM: publishOrigin: config
3:38:43 PM: Caching artifacts
3:38:43 PM: Started saving build plugins
3:38:43 PM: Finished saving build plugins
3:38:43 PM: Started saving pip cache
3:38:43 PM: Finished saving pip cache
3:38:43 PM: Started saving emacs cask dependencies
3:38:43 PM: Finished saving emacs cask dependencies
3:38:43 PM: Started saving maven dependencies
3:38:43 PM: Finished saving maven dependencies
3:38:43 PM: Started saving boot dependencies
3:38:43 PM: Finished saving boot dependencies
3:38:43 PM: Started saving rust rustup cache
3:38:43 PM: Finished saving rust rustup cache
3:38:43 PM: Started saving go dependencies
3:38:43 PM: Finished saving go dependencies
3:38:43 PM: Build failed due to a user error: Build script returned non-zero exit code: 2
3:38:43 PM: Failing build: Failed to build site
3:38:43 PM: Finished processing build request in 20.684075575s
