Build has succeeded and when I download files from the latest deploy and open index.html, there is just a redirect url to the correct homepage (overview.html).
Is there more configuration required for an automatic redirect from index.html to overview.html?
Hi @angelas, thanks for the feedback and sharing the repository.
I can see you are using Antora as your static-site generator.
First of all since you want to deploy the sub-folder called docs in your repository, when you are deploying from GitHub in your Netlify UI dashboard, you have to specify the below as your build settings.
Base directory: docs Build command: npm run build Publish directory: docs/docs
Since you specified --to-dir docs, it means that the site will be generated into a sub-folder called docs in the base directory called docs. Hence the Publish directory must be docs/docs. docs/docs will contain the html files and assets which will be served by Netlify.
Kindly try the suggestions above and then redeploy again. Your site should display as expected.
