Hello I’m just reaching out for some support
I have a NextJS 14 solution on a monorepo, when trying to use the Netlify CLI to do a build I am getting the below error which I am struggling to debug. I have had to explicitly install the Netlify/plugin-nextjs as without this was always reverting to the v4 runtime. It is working fine when using the v4 Runtime. Can anyone point me in the right direction please
PS D:\DevrootArco\Arco\Commerce-Frontend> netlify build
We've detected multiple sites inside your repository
? Select the site you want to work with (Use arrow keys or type to search)
> frontend apps\frontend --filter frontend
@remkoj/optimizely-dxp-cli packages\remkoj\optimizely-dxp-cli --filter @remkoj/optimizely-dxp-cli
@remkoj/optimizely-dxp-nextjs packages\remkoj\optimizely-dxp-nextjs --filter @remkoj/optimizely-dxp-nextjs
@remkoj/optimizely-dxp-react packages\remkoj\optimizely-dxp-react --filter @remkoj/optimizely-dxp-react
@remkoj/optimizely-dxp-react-server packages\remkoj\optimizely-dxp-react-server --filter @remkoj/optimizely-dxp-react-
server
@remkoj/optimizely-graph-client packages\remkoj\optimizely-graph-client --filter @remkoj/optimizely-graph-client
(Move up and down to reveal more choices)
? Select the site you want to work with frontend apps\frontend --filter frontend
Netlify Build
❯ Version
@netlify/build 29.36.1
❯ Flags
dry: false
offline: false
packagePath: apps\frontend
❯ Current directory
❯ Config file
No config file was defined: using default values.
❯ Context
production
❯ Using Next.js Runtime - v5.0.0
Cleaning up leftover files from previous builds
(Pre cleanup completed in 3ms)
@netlify/plugin-nextjs (onPreBuild event)
(@netlify/plugin-nextjs onPreBuild completed in 12ms)
Build command from Netlify app
$ yarn run build
→ Generating configuration file for website with domain: commerce-frontend.netlify.app
→ Loaded website data, generating TypeScript code.
→ Writing code to: D:\DevrootArco\Arco\Commerce-Frontend\apps\frontend\src\site-config.ts
✔ Done
▲ Next.js 14.1.4
- Environments: .env.local, .env
- Experiments (use at your own risk):
· instrumentationHook
Creating an optimized production build ...
✓ Compiled successfully
✓ Linting and checking validity of types
✓ Collecting page data
Generating static pages (5/7) [== ]
header-cta-store
✓ Generating static pages (7/7)
✓ Collecting build traces
✓ Finalizing page optimization
Route (app) Size First Load JS
┌ ○ /_not-found 881 B 85.5 kB
├ ● /[lang]/[[...path]] 37.8 kB 132 kB
├ └ /en
├ λ /api/auth/[...nextauth] 0 B 0 B
├ λ /api/content/publish 0 B 0 B
├ λ /api/me/[[...path]] 0 B 0 B
├ λ /api/me/consent 0 B 0 B
├ ○ /manifest.webmanifest 0 B 0 B
├ ○ /robots.txt 0 B 0 B
└ ○ /sitemap.xml 0 B 0 B
+ First Load JS shared by all 84.6 kB
├ chunks/1dd3208c-e584ba0092b89950.js 53.4 kB
├ chunks/997-18b0fdbf65c5c120.js 29 kB
└ other shared chunks (total) 2.2 kB
ƒ Middleware 60.6 kB
○ (Static) prerendered as static content
● (SSG) prerendered as static HTML (uses getStaticProps)
λ (Dynamic) server-rendered on demand using Node.js
→ Registering webhook target: https://commerce-frontend.netlify.app/api/content/publish?token=optly-PUBLISH_TOKEN
✔ Webhook already registered, no action needed
(build.command completed in 29.9s)
@netlify/plugin-nextjs (onBuild event)
(@netlify/plugin-nextjs onBuild completed in 2.4s)
Functions bundling
Packaging Functions from apps\frontend\.netlify\functions-internal directory:
- ___netlify-server-handler\___netlify-server-handler.mjs
(Functions bundling completed in 2.1s)
Edge Functions bundling
Packaging Edge Functions from apps\frontend\.netlify\edge-functions directory:
- ___netlify-edge-handler-src-middleware
(Edge Functions bundling completed in 3.9s)
@netlify/plugin-nextjs (onPostBuild event)
@netlify/plugin-nextjs (onEnd event)
(@netlify/plugin-nextjs onEnd completed in 11ms)
Save updated config
(options.onEnd completed in 2ms)
Plugin "@netlify/plugin-nextjs" failed
Error message
Error: Failed publishing static content
Plugin details
Package: @netlify/plugin-nextjs
Version: 5.0.0
Repository: git+https://github.com/netlify/next-runtime-minimal.git
npm link: https://www.npmjs.com/package/@netlify/plugin-nextjs
Report issues: https://github.com/netlify/next-runtime-minimal/issues
Error location
In "onPostBuild" event in "@netlify/plugin-nextjs" from Netlify app and package.json
Resolved config
build:
command: yarn run build
commandOrigin: ui
publish: D:\DevrootArco\Arco\Commerce-Frontend\apps\frontend\.next
publishOrigin: ui
plugins:
- inputs: {}
origin: ui
package: '@netlify/plugin-nextjs'
