The following URL procedure worked in V4 runtime, but did not work when tested in V5 runtime.
Should we assume that this feature is not yet implemented?
Note that the _headers file was placed under the .next directory.
You need to specify the headers in your next config as a standard Next.js site.
Hi, hrishikesh.
Thanks for answering.
I understand about the standard Header. So what about the BASIC authentication provided by Netlify?
I have set it up using the instructions in the following URL.
I have the _header file placed under the .next directory for a specific Branch Build.
Is there any way to do something similar to this with V5 runtime?
You will have to do just like you’d do it natively with Next.js on any other platform, for example: How To Add HTTP Basic Auth to Next.js - Vance Lucas
Or you can also use Netlify Edge Functions.
Thanks again for answering my question.
Um, I still need to change my method.
I will try to come up with a system that works for my product. Thank you.
