We will start failing builds on 11th November 2022 that have the Next.js Runtime plugin versions 4.0.0 to 4.25.0 specified in the project’s package.json. This is in order to mitigate a bug identified in these versions. The builds will break with a message similar to:
Error message
This site cannot be built because it is using an outdated version of the Next.js Runtime: @netlify/plugin-nextjs@4.16.0. Versions greater than 4.26.0 are recommended. To upgrade this plugin, please update its version in “package.json” to the latest version: 4.28.4. If you cannot use a more recent version, please contact Support for guidance.
To fix this update the package.json to the latest version and redeploy the site: "@netlify/plugin-nextjs": "4.28.4"
No action is required if the plugin version is not explicitly specified in package.json.
