Next.js build fails with command not found errors
Hi,
I’m having trouble deploying my Next.js site on Netlify. The build fails with errors like rm: command not found, mkdir: command not found and gimme: command not found.
I haven’t made any changed to the build configuration, everything was working as expected until now.
I tried deleting and recreating the website, redeploying it without cache, but the issue persists.
I configured the Netlify site using the online UI and I’m using Next.js 13.
Site settings
Netlify site name: https://passliss.netlify.app/
Build settings
Runtime: Next.js
Base directory: Passliss Web/passliss
Build command: npm run build
Publish directory: Passliss Web/passliss/.next
Deploy log visibility: Logs are public
Build status: Active
Branches and deploy contexts
Production branch: vNext
Branch deploys: Deploy only the production branch
Deploy Previews: Any pull request against your production branch / branch deploy branches
Build image selection
Build image: Ubuntu Focal 20.04 (default)
Log
Here is the deploy log:
9:09:04 AM: build-image version: a89f4ad50402ec92ae85e9b83fc50dcfb293df2e (focal)
9:09:04 AM: buildbot version: a89f4ad50402ec92ae85e9b83fc50dcfb293df2e
9:09:04 AM: Fetching cached dependencies
9:09:04 AM: Failed to fetch cache, continuing with build
9:09:04 AM: Starting to prepare the repo for build
9:09:04 AM: No cached dependencies found. Cloning fresh repo
9:09:04 AM: git clone --filter=blob:none https://github.com/Leo-Corporation/Passliss
9:09:05 AM: Preparing Git Reference refs/heads/vNext
9:09:05 AM: Parsing package.json dependencies
9:09:06 AM: Different publish path detected, going to use the one specified in the Netlify configuration file: 'Passliss Web/passliss/.next' versus '.next' in the Netlify UI
9:09:07 AM: Starting to install dependencies
9:09:07 AM: Attempting Ruby version 2.7.2, read from environment
9:09:07 AM: Using Ruby version 2.7.2
9:09:08 AM: Using PHP version 8.0
9:09:09 AM: v16.19.1 is already installed.
9:09:09 AM: Now using node v16.19.1 (npm v8.19.3)
9:09:09 AM: Enabling Node.js Corepack
9:09:09 AM: Started restoring cached build plugins
9:09:09 AM: Finished restoring cached build plugins
9:09:09 AM: Started restoring cached corepack dependencies
9:09:09 AM: Finished restoring cached corepack dependencies
9:09:09 AM: No npm workspaces detected
9:09:09 AM: Started restoring cached node modules
9:09:09 AM: Finished restoring cached node modules
9:09:09 AM: Installing npm packages using npm version 8.19.3
9:09:12 AM: npm WARN deprecated sourcemap-codec@1.4.8: Please use @jridgewell/sourcemap-codec instead
9:09:12 AM: npm WARN deprecated rollup-plugin-terser@7.0.2: This package has been deprecated and is no longer maintained. Please use @rollup/plugin-terser
9:09:24 AM: added 753 packages, and audited 754 packages in 14s
9:09:24 AM: 133 packages are looking for funding
9:09:24 AM:   run `npm fund` for details
9:09:24 AM: found 0 vulnerabilities
9:09:24 AM: npm packages installed
9:09:24 AM: /opt/build/env_store/.env: line 12: export: `Web/passliss/node_modules/.bin:/opt/buildhome/.nvm/versions/node/v16.19.1/bin:/opt/buildhome/.rvm/gems/ruby-2.7.2/bin:/opt/buildhome/.rvm/gems/ruby-2.7.2@global/bin:/opt/buildhome/.rvm/rubies/ruby-2.7.2/bin:/home/linuxbrew/.linuxbrew/bin:/opt/buildhome/.envman:/opt/buildhome/.swiftenv/bin:/opt/buildhome/.swiftenv/shims:/opt/buildhome/.php:/opt/buildhome/.binrc/bin:/opt/buildhome/.deno/bin:/usr/local/rvm/bin:/usr/local/sbin:/usr/local/bin:/usr/sbin:/usr/bin:/sbin:/bin:/opt/buildhome/.cask/bin:/opt/buildhome/.gimme/bin:/opt/buildhome/.dotnet/tools:/opt/buildhome/.dotnet:/opt/buildhome/.cargo/bin:/opt/buildhome/.rvm/bin': not a valid identifier/opt/buildhome/python3.8/bin/activate: line 67: basename: command not found
9:09:24 AM: Python version set to 3.8
9:09:24 AM: Started restoring cached go cache
9:09:24 AM: /opt/build-bin/install: line 915: rm: command not found
9:09:24 AM: /opt/build-bin/install: line 917: dirname: command not found
9:09:24 AM: Failed during stage 'Install dependencies': dependency_installation script returned non-zero exit code: 1
9:09:24 AM: /opt/build-bin/install: line 917: mkdir: command not found
9:09:24 AM: /opt/build-bin/install: line 918: mv: command not found
9:09:24 AM: Finished restoring cached go cache
9:09:24 AM: /opt/build-bin/install: line 792: gimme: command not found
9:09:24 AM: Failed to resolve Go version '1.19.5'
9:09:24 AM: Build was terminated: dependency_installation script returned non-zero exit code: 1
9:09:24 AM: Failing build: Failed to install dependencies
9:09:24 AM: Finished processing build request in 20.521s
Hi @leo-p,
Welcome! Would you mind sharing the command or script which npm run build is executing?
Gr,
Andy
Sure, npm run build executes next build.
Hmm ok, that’s not what I expected. I was wondering where the rm dirname mkdir mv and gimme commands where comming from.
Could you tell me what the script dependency_installation does or is it part of a module?
Gr,
Andy
dependency_installation script is not made by me, but I think it restores all the build dependencies that Netlify provides by default.
However, it might be related to restoring Go dependencies, which I’m not using.
After this it goes wrong. Have you tried to trigger Clear cache and retry?
Yes, tried it, still does nothing, same errors:
12:18:12 PM: build-image version: f16fe5e1d2fb705a244177206285638af584a46c (focal)
12:18:12 PM: buildbot version: f16fe5e1d2fb705a244177206285638af584a46c
12:18:12 PM: Building without cache
12:18:12 PM: Starting to prepare the repo for build
12:18:12 PM: No cached dependencies found. Cloning fresh repo
12:18:12 PM: git clone --filter=blob:none https://github.com/Leo-Corporation/Passliss
12:18:12 PM: Preparing Git Reference refs/heads/vNext
12:18:13 PM: Parsing package.json dependencies
12:18:14 PM: Different publish path detected, going to use the one specified in the Netlify configuration file: 'Passliss Web/passliss/.next' versus '.next' in the Netlify UI
12:18:14 PM: Starting to install dependencies
12:18:14 PM: Attempting Ruby version 2.7.2, read from environment
12:18:15 PM: Using Ruby version 2.7.2
12:18:15 PM: Started restoring cached go cache
12:18:15 PM: Finished restoring cached go cache
12:18:15 PM: Installing Go version 1.19.5 (requested 1.19.5)
12:18:20 PM: go version go1.19.5 linux/amd64
12:18:20 PM: Using PHP version 8.0
12:18:21 PM: v16.19.1 is already installed.
12:18:21 PM: Now using node v16.19.1 (npm v8.19.3)
12:18:21 PM: Enabling Node.js Corepack
12:18:22 PM: Started restoring cached build plugins
12:18:22 PM: Finished restoring cached build plugins
12:18:22 PM: Started restoring cached corepack dependencies
12:18:22 PM: Finished restoring cached corepack dependencies
12:18:22 PM: No npm workspaces detected
12:18:22 PM: Started restoring cached node modules
12:18:22 PM: Finished restoring cached node modules
12:18:22 PM: Installing npm packages using npm version 8.19.3
12:18:25 PM: npm WARN deprecated rollup-plugin-terser@7.0.2: This package has been deprecated and is no longer maintained. Please use @rollup/plugin-terser
12:18:25 PM: npm WARN deprecated sourcemap-codec@1.4.8: Please use @jridgewell/sourcemap-codec instead
12:18:33 PM: added 753 packages, and audited 754 packages in 11s
12:18:33 PM: 133 packages are looking for funding
12:18:33 PM:   run `npm fund` for details
12:18:33 PM: found 0 vulnerabilities
12:18:33 PM: npm packages installed
12:18:34 PM: /opt/build/env_store/.env: line 13: export: `Web/passliss/node_modules/.bin:/opt/buildhome/.nvm/versions/node/v16.19.1/bin:/opt/buildhome/.gimme/versions/go1.19.5.linux.amd64/bin:/opt/buildhome/.rvm/gems/ruby-2.7.2/bin:/opt/buildhome/.rvm/gems/ruby-2.7.2@global/bin:/opt/buildhome/.rvm/rubies/ruby-2.7.2/bin:/home/linuxbrew/.linuxbrew/bin:/opt/buildhome/.envman:/opt/buildhome/.swiftenv/bin:/opt/buildhome/.swiftenv/shims:/opt/buildhome/.php:/opt/buildhome/.binrc/bin:/opt/buildhome/.deno/bin:/usr/local/rvm/bin:/usr/local/sbin:/usr/local/bin:/usr/sbin:/usr/bin:/sbin:/bin:/opt/buildhome/.cask/bin:/opt/buildhome/.gimme/bin:/opt/buildhome/.dotnet/tools:/opt/buildhome/.dotnet:/opt/buildhome/.cargo/bin:/opt/buildhome/.rvm/bin': not a valid identifier/opt/buildhome/python3.8/bin/activate: line 67: basename: command not found
12:18:34 PM: Python version set to 3.8
12:18:34 PM: Install dependencies script success
12:18:34 PM: Starting build script
12:18:34 PM: /opt/build-bin/build: line 38: cd: too many arguments
12:18:34 PM: Using stage install dependencies
12:18:35 PM: Detected 0 framework(s)
12:18:35 PM: Section completed: initializing
12:18:35 PM: /opt/build-bin/build: line 47: date: command not found
12:18:35 PM: /opt/build-bin/build: line 92: which: command not found
12:18:36 PM: ​
12:18:36 PM:   Netlify Build
12:18:36 PM: ────────────────────────────────────────────────────────────────
12:18:36 PM: ​
12:18:36 PM: ❯ Version
12:18:36 PM:   @netlify/build 29.7.1
12:18:36 PM: ​
12:18:36 PM: ❯ Flags
12:18:36 PM:   baseRelDir: true
12:18:36 PM:   buildId: 641c356be9abc11244d8748a
12:18:36 PM:   deployId: 641c356be9abc11244d8748c
12:18:36 PM: ​
12:18:36 PM: ❯ Current directory
12:18:36 PM:   /opt/build/repo/Passliss Web/passliss
12:18:36 PM: ​
12:18:36 PM: ❯ Config file
12:18:36 PM:   No config file was defined: using default values.
12:18:36 PM: ​
12:18:36 PM: ❯ Context
12:18:36 PM:   production
12:18:36 PM: ​
12:18:37 PM: Failed during stage 'building site': Build script returned non-zero exit code: 2
12:18:36 PM: ❯ Installing plugins
12:18:36 PM:    - @netlify/plugin-nextjs@4.32.2
12:18:36 PM: ​
12:18:36 PM:   Dependencies installation error
12:18:36 PM: ​
12:18:36 PM:   Error message
12:18:36 PM:   Error while installing dependencies in /opt/build/repo/Passliss Web/passliss/.netlify/plugins/
12:18:36 PM: ​​
12:18:36 PM:   Resolved config
12:18:36 PM:   build:
12:18:36 PM:     base: /opt/build/repo/Passliss Web/passliss
12:18:36 PM:     command: npm run build
12:18:36 PM:     commandOrigin: ui
12:18:36 PM:     publish: /opt/build/repo/Passliss Web/passliss/.next
12:18:36 PM:     publishOrigin: ui
12:18:36 PM:   plugins:
12:18:36 PM:     - inputs: {}
12:18:36 PM:       origin: ui
12:18:36 PM:       package: '@netlify/plugin-nextjs'
12:18:37 PM: /opt/build-bin/build: line 47: date: command not found
12:18:37 PM: Caching artifacts
12:18:37 PM: Started saving node modules
12:18:37 PM: /opt/build-bin/run-build-functions.sh: line 839: rm: command not found
12:18:37 PM: /opt/build-bin/run-build-functions.sh: line 841: dirname: command not found
12:18:37 PM: /opt/build-bin/run-build-functions.sh: line 841: mkdir: command not found
12:18:37 PM: /opt/build-bin/run-build-functions.sh: line 842: mv: command not found
12:18:37 PM: Finished saving node modules
12:18:37 PM: Started saving build plugins
12:18:37 PM: Finished saving build plugins
12:18:37 PM: Started saving corepack cache
12:18:37 PM: Finished saving corepack cache
12:18:37 PM: Started saving pip cache
12:18:37 PM: Finished saving pip cache
12:18:37 PM: Started saving emacs cask dependencies
12:18:37 PM: Finished saving emacs cask dependencies
12:18:37 PM: Started saving maven dependencies
12:18:37 PM: Finished saving maven dependencies
12:18:37 PM: Started saving boot dependencies
12:18:37 PM: Finished saving boot dependencies
12:18:37 PM: Started saving rust rustup cache
12:18:37 PM: Finished saving rust rustup cache
12:18:37 PM: /opt/build-bin/run-build-functions.sh: line 789: chmod: command not found
12:18:37 PM: Started saving go dependencies
12:18:37 PM: Finished saving go dependencies
12:18:37 PM: /opt/build-bin/run-build-functions.sh: line 795: rm: command not found
12:18:37 PM: /opt/build-bin/run-build-functions.sh: line 796: mkdir: command not found
12:18:37 PM: /opt/build-bin/run-build-functions.sh: line 797: mv: command not found
12:18:37 PM: /opt/build-bin/run-build-functions.sh: line 815: rm: command not found
12:18:37 PM: /opt/build-bin/run-build-functions.sh: line 816: rm: command not found
12:18:37 PM: /opt/build-bin/run-build-functions.sh: line 830: rm: command not found
12:18:37 PM: Build failed due to a user error: Build script returned non-zero exit code: 2
12:18:37 PM: Failing build: Failed to build site
12:18:37 PM: Finished processing build request in 25.422s
Logs: Netlify App
You do have the plugin @netlify/plugin-nextjs installed?
Yes, Netlify automatically detected it was a Next.js site and installed the plugin. It used to work before; I haven’t made any changes in the configuration.
Maybe try adding @netlify/plugin-nextjs to your devDependencies,
and add the following to your netlify.toml:
[[plugins]]
  package = "@netlify/plugin-nextjs"
Hi @leo-p & @andylemaire this could have been caused by a migration we are making. I have rolled back the changes please try and let me know if it works.
I have already added this to the netlify.toml file
I retried to clear cache and deploy, still getting the same errors:
12:34:12 PM: build-image version: f16fe5e1d2fb705a244177206285638af584a46c (focal)
12:34:12 PM: buildbot version: f16fe5e1d2fb705a244177206285638af584a46c
12:34:12 PM: Building without cache
12:34:12 PM: Starting to prepare the repo for build
12:34:12 PM: No cached dependencies found. Cloning fresh repo
12:34:12 PM: git clone --filter=blob:none https://github.com/Leo-Corporation/Passliss
12:34:13 PM: Preparing Git Reference refs/heads/vNext
12:34:13 PM: Parsing package.json dependencies
12:34:15 PM: Different publish path detected, going to use the one specified in the Netlify configuration file: 'Passliss Web/passliss/Passliss Web/passliss/.next' versus '.next' in the Netlify UI
12:34:15 PM: Starting to install dependencies
12:34:15 PM: Using PHP version 8.0
12:34:15 PM: Python version set to 3.8
12:34:15 PM: Started restoring cached go cache
12:34:15 PM: Finished restoring cached go cache
12:34:15 PM: Installing Go version 1.19.5 (requested 1.19.5)
12:34:20 PM: go version go1.19.5 linux/amd64
12:34:21 PM: v16.19.1 is already installed.
12:34:21 PM: Now using node v16.19.1 (npm v8.19.3)
12:34:21 PM: Enabling Node.js Corepack
12:34:21 PM: Started restoring cached build plugins
12:34:21 PM: Finished restoring cached build plugins
12:34:21 PM: Started restoring cached corepack dependencies
12:34:21 PM: Finished restoring cached corepack dependencies
12:34:21 PM: No npm workspaces detected
12:34:21 PM: Started restoring cached node modules
12:34:21 PM: Finished restoring cached node modules
12:34:21 PM: Installing npm packages using npm version 8.19.3
12:34:24 PM: npm WARN deprecated sourcemap-codec@1.4.8: Please use @jridgewell/sourcemap-codec instead
12:34:24 PM: npm WARN deprecated rollup-plugin-terser@7.0.2: This package has been deprecated and is no longer maintained. Please use @rollup/plugin-terser
12:34:33 PM: added 753 packages, and audited 754 packages in 11s
12:34:33 PM: 133 packages are looking for funding
12:34:33 PM:   run `npm fund` for details
12:34:33 PM: found 0 vulnerabilities
12:34:33 PM: npm packages installed
12:34:33 PM: /opt/build/env_store/.env: line 13: export: `Web/passliss/node_modules/.bin:/opt/buildhome/.nvm/versions/node/v16.19.1/bin:/opt/buildhome/.gimme/versions/go1.19.5.linux.amd64/bin:/opt/buildhome/python3.8/bin:/home/linuxbrew/.linuxbrew/bin:/opt/buildhome/.envman:/opt/buildhome/.swiftenv/bin:/opt/buildhome/.swiftenv/shims:/opt/buildhome/.php:/opt/buildhome/.binrc/bin:/opt/buildhome/.deno/bin:/usr/local/rvm/bin:/usr/local/sbin:/usr/local/bin:/usr/sbin:/usr/bin:/sbin:/bin:/opt/buildhome/.cask/bin:/opt/buildhome/.gimme/bin:/opt/buildhome/.dotnet/tools:/opt/buildhome/.dotnet:/opt/buildhome/.cargo/bin': not a valid identifier/opt/buildhome/.rvm/scripts/rvm: line 12: uname: command not found
12:34:33 PM: /opt/buildhome/.rvm/scripts/rvm: line 29: ps: command not found
12:34:33 PM: Attempting Ruby version 2.7.2, read from environment
12:34:33 PM: /opt/build-bin/install: line 487: rvm: command not found
12:34:33 PM: Failed during stage 'Install dependencies': dependency_installation script returned non-zero exit code: 1
12:34:33 PM: /opt/build-bin/install: line 508: rvm: command not found
12:34:33 PM: Failed to install Ruby version '2.7.2'
12:34:33 PM: Build was terminated: dependency_installation script returned non-zero exit code: 1
12:34:33 PM: Failing build: Failed to install dependencies
12:34:34 PM: Finished processing build request in 21.382s
Logs: Netlify App
Right, can you retry the build again?
It works! Thank you for your help!
yay! Thanks so much for confirming you found your solution. (:
