Next js 14 public folder deploy issue
Hi
I’m working on building my Next.js 14 app, but I’m having trouble with the public folder, which contains images. After building the app, I can’t find the public folder in the .next build directory. As a result, the images are not being found, and I’m getting 404 errors.
I’ve been trying to resolve this issue for a couple of days but haven’t found a solution yet. Can someone help me understand how to properly include and deploy the public folder so that the images are available on the server?
//next.config.js
/** @type {import('next').NextConfig} */
const nextConfig = {
  reactStrictMode: true,
  swcMinify: true,
  i18n: {
    defaultLocale: 'en',
    locales: ['en', 'hi'],
  // images: {
  //   domains: ['co-buy.uk'],
  assetPrefix: 'https://co-buy.uk',
export default nextConfig;
//netlify.toml
[[plugins]]
  package = "@netlify/plugin-nextjs"
[build]
  command = "npm run build"
  publish = "out"
[[redirects]]
  from = "/*"
  to = "/index.html"
  status = 200
[functions]
  [functions.___netlify-server-handler]
    included_files = ["./public/**"]
This is the expected behavior.
You already are and the files already are.
Read the appropriate Next.js documentation:
https://nextjs.org/docs/pages/building-your-application/optimizing/static-assets
Next.js can serve static files, like images, under a folder called public in the root directory. Files inside public can then be referenced by your code starting from the base URL (/).
For example, the file public/avatars/me.png can be viewed by visiting the /avatars/me.png path. The code to display that image might look like:
You do not reference the files in the resulting build with /public/ because they are moved to /
