Nice, looks like the redirects were correctly processed there
When I click âLOGINâ on your site, I get through the flow and am able to login. Can you see what happens when you try?
Just wondering which login you are clicking, when I am in testing, /login is the page with Netlify identity login.
When logged out, /rates redirects back to / however when I log in the same happens. When logged in as a user with an admin role, I still get redirected to /
If itâs any help to you I can invite you so that you could test it out.
Hey @kylesloper!
Following along here but just jumping in to clarify - when youâre testing locally or on your production site? (or on a deploy-preview / branch-deploy)
â
Jon
Iâm assuming @jonsully you are referring to when I said
If thatâs the case then I meant on my site there are 2 links that say login only one of them will take you too the Netlify Identity login page the other to Netlify CMS. To avoid any confusion Iâll update that now, just to be clear to access the login page is /login
Okay, cool! Just making sure. Iâm not if I mentioned it above or in another thread, but role-based access control in _redirects behaves quite different in environments other than your production site. Weâll want to focus on your production / live site for debugging efforts
Your current rules seem to work for me:
When Iâm logged in, I can get to /rates:
When Iâm not logged in, I cannot get to /rates- only https://moonface.netlify.app/
I did this by creating a Netlify CMS user. So, note that whatever roles are set by creating a Netlify CMS user also seem to grant access to the /rates page, not sure if thatâs intended or not.
Okay I have no idea what or if you did something but it works
Woohoo! I just reformatted what you had for the netlify.toml format
TLDR for future encounterers of this problem:
- check Jon and Slimâs giant thread above for a good pattern/set of rules for RBAC with Netlify Identity
- if _redirects file isnât working for you, being picked up, etc., try instead adding the rules to netlify.toml in the root directory
Thank you so much for your help :))
Hey, for some reason the role based redirects are not working again. No matter if the user is logged in or not, they are always redirected.
My deploy logs tell me that the redirect rules were processed and there are no errors, so Iâm sure itâs just a small error Iâve made.
Git repo if needed: https://github.com/kylesloper/moonface
Netlify site: MOONFACE | Sites for Creatives
When I log in, get a nf_jwt token from Identity in my browser storage, and decode it here, Iâm seeing that it does not have the required roles field:
"exp": 1611707608,
"sub": "fe73ec53-768b-4f83-aa3f-202ad084fe20",
"email": [ redacted :) ],
"app_metadata": {
"provider": "email"
"user_metadata": {}
This should look like:
"exp": 1611707608,
"app_metadata": {
"provider": "email",
"roles": ["rdm", "admin"]
"user_metadata": {}
This is probably why weâre not being redirected to paths that require specific roles to be set. Now that your Identity instance is invite-only, have you updated the roles of the people youâve invited? Youâd do that here: Netlify App and click the user to set the roles.
Updated those roles on every users account
A quick note that even after you update roles, youâll need to log out then back in so the JWT in your browser gets reloaded with the new roles. Does it work after that, @kylesloper?
Yea unfortunately it doesnât.
Seems to be working for me now but I did notice some strange behavior on moonface.netlify.app vs. moonface.ga: I can be âlogged inâ on moonface.netlify.app/login, but not moonface.ga/login, and vice versa (logged in on moonface.ga, but not the Netlify URL).
Weâre in our company all-hands through the rest of the week, but we should be able to dive in next week and get you more details on why this is happening!
In the meantime, can you take a look and see if youâre seeing the correct behavior on at least one domain: either Netlify URL or custom domain?
Sure Iâll do that now.
I think that makes sense actually
. GoTrue is going to respond with a set-cookie directive from whichever domain itâs called at, but your browser is only going to send that cookie back to the server from the same domain. GoTrue will respond from both the .netlify.app subdomain and the custom .ga domain⌠but youâre only going to be logged in on that particular domain.
You can get into some weirdness there since you could technically have two fully separate sessions going in â log in on .net.app and then switch over and login on .ga and now you have the same user logged in from two different domains
but ignoring that for nowâŚ
The _redirects should be followed for that particular domain. If you log in on the .netlify.app domain then attempt to hit the RBACâd pages on .netlify.app, that should work. And vice versa. But if you try to login on .netlify.app then hit the RBACâd pages on .ga, that would fail
I donât actually have an account on Moonface, nor does the auth / login interface appear to load for me so I canât definitively check these things myself, but logically I believe it follows.
It may be simpler to setup a _redirect that forces all traffic to your custom domain, @kylesloper â or at least itâll help eliminate variables. In toml format it should look like:
[[redirects]]
from = "https://moonface.netlify.app/*"
to = "https://moonface.ga/:splat"
status = 302
force = true
Onward!
â
Jon
Cheers @jonsully for your input⌠thatâs actually really interesting to see how GoTrue works via custom domains.
If you would want to do more investigating, It would be very appreciated and I could send you a signup link to your email. PM me your email if your up to it!
Alrighty, letâs do this thing
whatâs currently deployed as far as your netlify.toml goes / what redirects are in place? Whatâs a path on your site that I shouldnât be able to access when logged out but should be able to when logged in?
Just spinning up on context here
Sorry for the spam thatâs about to layout Jen
@kylesloper responded in PM but I want to keep this public for othersâ future learning
The login page is at /login/ with authâs you with roles so that you can access /cockpit and /chat
But I donât actually see anything going wrong here @kylesloper â once you added the roles to my user and I logged out then back in so theyâd be applied, I can now view /cockpit and /chat
Iâm exclusively using the .ga domain but all seems well here
