Netlify function responds with wrong body
site: https://mui-dashboard.netlify.app/
function endpoint: https://mui-dashboard.netlify.app/.netlify/functions/test-profile-artifact
The function in question has the same response even if the input changes:
  1. https://mui-dashboard.netlify.app/.netlify/functions/test-profile-artifact?url=https://199500-23083156-gh.circle-artifacts.com/0/react-profiler-report/karma/Chrome%2084.0.4147.89%20(Mac%20OS%2010.15.6)/1606343869086.json
    x-nf-request-id: 81d3f259-4233-40de-b5c8-bc1a522ed885-11670676
  2. https://mui-dashboard.netlify.app/.netlify/functions/test-profile-artifact?url=https://199500-23083156-gh.circle-artifacts.com/0/react-profiler-report/karma/Chrome%2084.0.4147.89%20(Mac%20OS%2010.15.6)/1606343981057.json
    x-nf-request-id: 81d3f259-4233-40de-b5c8-bc1a522ed885-11670681
The response from the deployed function has the same ETag even though this shouldn’t happen since the ETag is based on the query parameters (which are different)
If I request the same endpoint and parameters locally (using netlify dev) I get different resources as expected.
In addition, the logs for that function are incomplete: Netlify App
It’s taking a very long time to load.
I already added some arbitrary lines to the function so that it gets rebuild. I also cleared the site cache and re-deployed.
Update: Occasionally the responses are actually correct (body as expected, etag as expected, create a log in the netlify UI). Is this caused by the recent AWS outages?
Hi @eps1lon,
It looks like you’ve run into an existing issue. You can see a previous discussion of the issue here. I’ve also added your report to the issue that we are tracking internally.
That said, we’ll update you once we get a fix deployed. Thank you for your patience.
