Netlify function not working when deployed, but it does on localhost and using netlify dev
Hi all - site is here.
Login with zakum690@gmail.com and test12345 as the password - it’s a test account I’ve created.
The try app temporarily doesn’t work.
I’ve got 3 netlify functions for 3 supermarkets, 2/3 work. I’m having issues with ‘Woolworths’.
When I test the “search” locally with netlify dev, then it works fine - I can see results:
However once deployed, it’s getting stuck here (I think):
Which matches this console.log here:
This is from the browser:
I’m not sure what’s blocking it & it’s definitely not taking 10 real seconds as it takes less than 1 second locally with netlify dev & also it’s pretty much instant with netlify dev --geo=mock
I’ve also tested the fetch URL with postman and it’s working fine - as long as you enter the 2 headers from the screenshot.
Before creating netlify functions, I had to run an express server locally for that domain as I got blocked by cors - but when deployed this solved it on the frontend with redirects:
[[redirects]]
force = true
from = “proxy/*”
status = 200
to = “https://www.woolworths.co.nz/:splat”
const production = process.env.NODE_ENV === “production”;
export const proxy = () => {
return production ? “proxy/” : “http://localhost:3000/”;
Then previously I called it like this:
const url = ${proxy()}api/v1/products?target=search&search=${searchTerm.toLowerCase()}&inStockProductsOnly=false&size=48;`
This is what my server.js used to look like to get around cors issues:
// server.js
import express from "express";
import { createProxyMiddleware } from "http-proxy-middleware";
import cors from "cors";
const app = express();
app.use(
  cors({
    credentials: true,
    origin: "http://localhost:5173",
// Configure the proxy middleware
app.use(
  createProxyMiddleware({
    target: "https://www.woolworths.co.nz/", // The target API server you want to proxy to
    changeOrigin: true, // Modify the Origin header for CORS
    // pathRewrite: {
    //   "^/woolies": "", // Optional: rewrite path to remove /api if needed
    cookieDomainRewrite: {
      // Ensure cookies are correctly set when proxying
      "*": "", // Allows cookies to work across domains
    onProxyReq: (proxyReq, req, res) => {
      // You can manipulate the request here if needed (headers, etc.)
      proxyReq.setHeader("User-Agent", "nala bananas");
      proxyReq.setHeader("x-requested-with", "OnlineShopping.WebApp");
      proxyReq.setHeader("accept", "application/json, text/plain, */*");
      proxyReq.setHeader("accept-language", "en-US,en;q=0.9");
      proxyReq.setHeader("cache-control"), "no-cache";
      proxyReq.setHeader("content-type"), "application/json";
      proxyReq.setHeader("expires", "Sat, 01 Jan 2000 00:00:00 GMT");
    onProxyRes: (proxyRes, req, res) => {
      const allowedOrigin = "http://localhost:5173";
      proxyRes.headers["Access-Control-Allow-Origin"] = allowedOrigin;
      proxyRes.headers["Access-Control-Allow-Credentials"] = "true";
      proxyRes.headers["Access-Control-Allow-Methods"] = "GET,PUT"; // Allow methods
      proxyRes.headers["Access-Control-Allow-Headers"] =
        "Content-Type, Authorization"; // Allow custom headers
// // Basic route to test the server is running
app.get("/", (req, res) => {
  res.send("Proxy Server is running!");
// Start the Express server
const PORT = 3000;
app.listen(PORT, () => {
  console.log(`Proxy server is running on http://localhost:${PORT}`);
However I’m not getting cors issues anymore since it’s run on a server now, hence why I changed it back to the actual URL instead of proxy()
I’m using netlify/functions as my functions directory. I’ve temporarily removed my rewrite rules from netlify.toml just to see if that might have blocked it, but no luck. I’ve also tried the node-fetch package but getting the same problem. Like I said it works 100% locally & have verified I’m on node 20.11.0 which matches:
Build settings if it helps too ("build-only": "vite build")
I believe you should reach out to woolworths.co.nz for help as it’s their server that’s taking time to respond. Based on your code and screenshots it’s clear that the request never completes. As for why, it’s them who could answer, not us. Maybe they’re blocking requests from Netlify.
