@netlify/edge-bundler and next-dev edge functions causing type errors
Netlify generated files (from running netlify dev) causing type errors when running NextJS app.
Files might have something to do with next-dev edge function. Is there a way to disable this?
Said files are:
- netlify-cli/node_modules/@netlify/edge-bundler/deno/config.ts:7:10 (globally installed package)
- .netlify/edge-functions/edge-shared/utils.ts
Here is the complete error:
Found 2 errors.
    at async file:///home/kyljmn/.asdf/installs/nodejs/16.10.0/.npm/lib/node_modules/netlify-cli/node_modules/@netlify/edge-bundler/deno/config.ts:7:10
Could not load edge function at '/home/kyljmn/Documents/work/metrobank-next/.netlify/edge-functions/next-dev/index.js'
TypeError: TS2345 [ERROR]: Argument of type 'URL' is not assignable to parameter of type 'string'.
    return Response.redirect(url, 308)
    at file:///home/kyljmn/Documents/work/metrobank-next/.netlify/edge-functions/edge-shared/utils.ts:266:30
    at file:///home/kyljmn/Documents/work/metrobank-next/.netlify/edge-functions/edge-shared/utils.ts:271:30
Using netlify-cli version 12.10.0, however, I’ve downgraded to some previous versions (11.x.x. and 10.x.x) finally got it to work at 6.9.28 but the netlify function I need (different from the said edge function causing the error) doesn’t work as expected in that version.
do you have deno installed on your system?
Got the same error, realised I hadn’t installed deno, installed deno via homebrew, error disappeared afterwards.
Hi @p.aarseth :wave:t6: thanks so much for sharing your solution!
Thanks @p.aarseth worked after installing deno!
