Got an error after successfully installing netlify-cli with yarn, windows(windows 7, 32bit) give an error that netlify isn’t operable or a batch file.
Could you show us exactly what happens when you try to execute it at a command prompt? It is not a command that you can “click” on - you have to run it from Powershell or something similar.
OK. Seems like maybe you don’t have yarn set up correctly to add things to your PATH. I’d be googling that to see if you can get the right way to handle it figured out. This was the first hit I saw, seems promising:
