Reduced Test case Git repo: GitHub - brob/netlify-durable-cache-test
Working production function: https://candid-sherbet-49d76c.netlify.app/travel-guide/city/country
Taking the example from the docs here: Get started with functions | Netlify Docs
Using this locally, throws the following error:
TypeError - lambdaFunc[lambdaHandler] is not a function
In production, this works fine.
Locally, i can make the function not throw an error by exporting it with a handler variable, but that triggers the Lambda compatibility and makes context.params not work (nor the exported Config object) because those don’t work in compat mode.
Version for the CLI locally (accessed via netlify -v:
netlify-cli/17.37.1 darwin-arm64 node-v21.0.0
