Netlify site name: learnroadrunner (www.learnroadrunner.com)
GitHub - NoahBres/LearnRoadRunner: Learn Road Runner
Netlify has been failing to build my vuepress site. My site builds locally without issue.
My last successful build was on May. 10 and I have not touched the site since. However, upon picking the project back up today, I am finding that none of my builds have been successful.
I thought it was simply an issue with the dependencies so made a few attempts to fix that. However, the latest deploy was a commit reverting back to the original successful publish. The latest deploy at 5:13 is the commit hash for the same deploy on May. 10. So these two states are identical. However, the build today fails. I am assuming something has changed with the build image since then.
Thank you all for the wonderful product!
Here is the build log for the latest deploy:
5:13:16 PM: Build ready to start
5:13:18 PM: build-image version: 2cee85eb7f808bf3b6e87378c5307f9411f0a332
5:13:18 PM: build-image tag: v3.8.0
5:13:18 PM: buildbot version: 3b0c079a2e52aae070f2433b3231592eec65b71e
5:13:19 PM: Fetching cached dependencies
5:13:19 PM: Failed to fetch cache, continuing with build
5:13:19 PM: Starting to prepare the repo for build
5:13:19 PM: No cached dependencies found. Cloning fresh repo
5:13:19 PM: git clone https://github.com/NoahBres/LearnRoadRunner
5:13:31 PM: Preparing Git Reference refs/heads/master
5:13:33 PM: Parsing package.json dependencies
5:13:33 PM: Different publish path detected, going to use the one specified in the Netlify configuration file: 'docs/.vuepress/dist' versus './docs/.vuepress/dist' in the Netlify UI
5:13:34 PM: Starting build script
5:13:34 PM: Installing dependencies
5:13:34 PM: Python version set to 2.7
5:13:35 PM: Downloading and installing node v14.17.1...
5:13:35 PM: Downloading https://nodejs.org/dist/v14.17.1/node-v14.17.1-linux-x64.tar.xz...
5:13:36 PM: Computing checksum with sha256sum
5:13:36 PM: Checksums matched!
5:13:40 PM: Now using node v14.17.1 (npm v6.14.13)
5:13:40 PM: Started restoring cached build plugins
5:13:40 PM: Finished restoring cached build plugins
5:13:40 PM: Attempting ruby version 2.6.2, read from environment
5:13:42 PM: Using ruby version 2.6.2
5:13:42 PM: Using PHP version 5.6
5:13:42 PM: Started restoring cached node modules
5:13:42 PM: Finished restoring cached node modules
5:13:43 PM: Installing NPM modules using NPM version 6.14.13
5:14:12 PM: npm WARN read-shrinkwrap This version of npm is compatible with lockfileVersion@1, but package-lock.json was generated for lockfileVersion@2. I'll try to do my best with it!
5:14:12 PM: > core-js@2.6.12 postinstall /opt/build/repo/node_modules/babel-runtime/node_modules/core-js
5:14:12 PM: > node -e "try{require('./postinstall')}catch(e){}"
5:14:12 PM: > core-js@3.10.1 postinstall /opt/build/repo/node_modules/core-js
5:14:13 PM: > vuepress@1.8.2 postinstall /opt/build/repo/node_modules/vuepress
5:14:13 PM: > opencollective-postinstall || exit 0
5:14:14 PM: npm WARN optional SKIPPING OPTIONAL DEPENDENCY: fsevents@2.3.2 (node_modules/watchpack/node_modules/fsevents):
5:14:14 PM: npm WARN notsup SKIPPING OPTIONAL DEPENDENCY: Unsupported platform for fsevents@2.3.2: wanted {"os":"darwin","arch":"any"} (current: {"os":"linux","arch":"x64"})
5:14:14 PM: npm WARN optional SKIPPING OPTIONAL DEPENDENCY: fsevents@1.2.13 (node_modules/fsevents):
5:14:14 PM: npm WARN notsup SKIPPING OPTIONAL DEPENDENCY: Unsupported platform for fsevents@1.2.13: wanted {"os":"darwin","arch":"any"} (current: {"os":"linux","arch":"x64"})
5:14:14 PM: added 1319 packages from 575 contributors and audited 1409 packages in 30.615s
5:14:15 PM: 69 packages are looking for funding
5:14:15 PM: run `npm fund` for details
5:14:15 PM: found 94 vulnerabilities (88 moderate, 6 high)
5:14:15 PM: run `npm audit fix` to fix them, or `npm audit` for details
5:14:15 PM: NPM modules installed
5:14:16 PM: Started restoring cached go cache
5:14:16 PM: Finished restoring cached go cache
5:14:16 PM: Installing Go version 1.12
5:14:21 PM: unset GOOS;
5:14:21 PM: unset GOARCH;
5:14:21 PM: export GOROOT='/opt/buildhome/.gimme_cache/versions/go1.12.linux.amd64';
5:14:21 PM: export PATH="/opt/buildhome/.gimme_cache/versions/go1.12.linux.amd64/bin:${PATH}";
5:14:21 PM: go version >&2;
5:14:21 PM: export GIMME_ENV="/opt/buildhome/.gimme_cache/env/go1.12.linux.amd64.env"
5:14:21 PM: go version go1.12 linux/amd64
5:14:21 PM: Installing missing commands
5:14:21 PM: Verify run directory
5:14:22 PM: β
5:14:22 PM: ββββββββββββββββββββββββββββββββββββββββββββββββββββββββββββββββ
5:14:22 PM: Netlify Build
5:14:22 PM: β
5:14:22 PM: β― Version
5:14:22 PM: @netlify/build 12.7.1
5:14:22 PM: β
5:14:22 PM: β― Flags
5:14:22 PM: deployId: 60d2607cff9b8100072a1d00
5:14:22 PM: β
5:14:22 PM: β― Current directory
5:14:22 PM: /opt/build/repo
5:14:22 PM: β
5:14:22 PM: β― Config file
5:14:22 PM: No config file was defined: using default values.
5:14:22 PM: β
5:14:22 PM: β― Context
5:14:22 PM: production
5:14:22 PM: β
5:14:22 PM: 1. Build command from Netlify app
5:14:22 PM: β
5:14:22 PM: $ npm run build
5:14:23 PM: > learn-road-runner@1.0.0 build /opt/build/repo
5:14:23 PM: > vuepress build docs
5:14:23 PM: internal/modules/cjs/loader.js:905
5:14:23 PM: throw err;
5:14:23 PM: ^
5:14:23 PM: Error: Cannot find module 'lru-cache'
5:14:23 PM: Require stack:
5:14:23 PM: - /opt/build/repo/node_modules/@vuepress/shared-utils/lib/extractHeaders.js
5:14:23 PM: - /opt/build/repo/node_modules/@vuepress/shared-utils/lib/index.js
5:14:23 PM: - /opt/build/repo/node_modules/vuepress/lib/checkEnv.js
5:14:23 PM: - /opt/build/repo/node_modules/vuepress/cli.js
5:14:23 PM: at Function.Module._resolveFilename (internal/modules/cjs/loader.js:902:15)
5:14:23 PM: at Function.Module._load (internal/modules/cjs/loader.js:746:27)
5:14:23 PM: at Module.require (internal/modules/cjs/loader.js:974:19)
5:14:23 PM: at require (internal/modules/cjs/helpers.js:92:18)
5:14:23 PM: at Object.<anonymous> (/opt/build/repo/node_modules/@vuepress/shared-utils/lib/extractHeaders.js:5:37)
5:14:23 PM: at Module._compile (internal/modules/cjs/loader.js:1085:14)
5:14:23 PM: at Object.Module._extensions..js (internal/modules/cjs/loader.js:1114:10)
5:14:23 PM: at Module.load (internal/modules/cjs/loader.js:950:32)
5:14:23 PM: at Function.Module._load (internal/modules/cjs/loader.js:790:14)
5:14:23 PM: at Module.require (internal/modules/cjs/loader.js:974:19) {
5:14:23 PM: code: 'MODULE_NOT_FOUND',
5:14:23 PM: requireStack: [
5:14:23 PM: '/opt/build/repo/node_modules/@vuepress/shared-utils/lib/extractHeaders.js',
5:14:23 PM: '/opt/build/repo/node_modules/@vuepress/shared-utils/lib/index.js',
5:14:23 PM: '/opt/build/repo/node_modules/vuepress/lib/checkEnv.js',
5:14:23 PM: '/opt/build/repo/node_modules/vuepress/cli.js'
5:14:23 PM: ]
5:14:23 PM: }
5:14:23 PM: npm ERR! code ELIFECYCLE
5:14:23 PM: npm ERR! errno 1
5:14:23 PM: npm ERR! learn-road-runner@1.0.0 build: `vuepress build docs`
5:14:23 PM: npm ERR! Exit status 1
5:14:23 PM: npm ERR! Failed at the learn-road-runner@1.0.0 build script.
5:14:23 PM: npm ERR! This is probably not a problem with npm. There is likely additional logging output above.
5:14:23 PM: npm ERR! A complete log of this run can be found in:
5:14:23 PM: npm ERR! /opt/buildhome/.npm/_logs/2021-06-22T22_14_23_299Z-debug.log
5:14:23 PM: β
5:14:23 PM: ββββββββββββββββββββββββββββββββββββββββββββββββββββββββββββββββ
5:14:23 PM: "build.command" failed
5:14:23 PM: β
5:14:23 PM: Error message
5:14:23 PM: Command failed with exit code 1: npm run build
5:14:23 PM: β
5:14:23 PM: Error location
5:14:23 PM: In Build command from Netlify app:
5:14:23 PM: npm run build
5:14:23 PM: β
5:14:23 PM: Resolved config
5:14:23 PM: build:
5:14:23 PM: command: npm run build
5:14:23 PM: commandOrigin: ui
5:14:23 PM: environment:
5:14:23 PM: - NODE_ENV
5:14:23 PM: - NODE_VERSION
5:14:23 PM: publish: /opt/build/repo/docs/.vuepress/dist
5:14:23 PM: publishOrigin: ui
5:14:23 PM: functions:
5:14:23 PM: '*': {}
5:14:23 PM: Caching artifacts
5:14:23 PM: Started saving node modules
5:14:23 PM: Finished saving node modules
5:14:23 PM: Started saving build plugins
5:14:23 PM: Finished saving build plugins
5:14:23 PM: Started saving pip cache
5:14:23 PM: Finished saving pip cache
5:14:23 PM: Started saving emacs cask dependencies
5:14:23 PM: Finished saving emacs cask dependencies
5:14:23 PM: Started saving maven dependencies
5:14:23 PM: Finished saving maven dependencies
5:14:23 PM: Started saving boot dependencies
5:14:23 PM: Finished saving boot dependencies
5:14:23 PM: Started saving rust rustup cache
5:14:23 PM: Finished saving rust rustup cache
5:14:24 PM: Started saving go dependencies
5:14:25 PM: Finished saving go dependencies
5:14:29 PM: Build failed due to a user error: Build script returned non-zero exit code: 2
5:14:29 PM: Creating deploy upload records
5:14:29 PM: Failing build: Failed to build site
5:14:29 PM: Failed during stage 'building site': Build script returned non-zero exit code: 2
5:14:29 PM: Finished processing build request in 1m10.871416048s
This specific issue is ameliorated when explicitly installing the lru-cache dependency. However, that simply leads to more errors. I can post those logs if it helps.
