My site: https://signwriter.netlify.app/
My mono repo structure:
My netlifytoml:
[build]
base="./code/SignWriter"
command="npm run build"
publish="build"
- npm run build within the /code/SignWriter dir works fine.
- netlify build within the /code/SignWriter dir works fine.
Problem
netlify build at the root throws errors, although it should behave the same because of the base being set to code/SignWriter.
This also leads to a build error when trying to build on netlify servers.
Error when building from /:
Netlify Build
❯ Version
@netlify/build 29.56.0
❯ Flags
accountId: 601535e611dd6b1cd23557d7
dry: false
offline: false
❯ Current directory
/Users/velius/Documents/dev/15-gl2-kessler-schmidt/code/SignWriter
❯ Config file
/Users/velius/Documents/dev/15-gl2-kessler-schmidt/netlify.toml
❯ Context
production
build.command from netlify.toml
$ npm run build
> signwriter@0.0.1 build
> vite build
vite v5.4.11 building SSR bundle for production...
12:00:53 PM [vite-plugin-svelte] src/routes/+layout.svelte:63:32 Properties of objects and arrays are not reactive unless in runes mode. Changes to this property will not cause the reactive statement to update
61: setInitialClassState();
62:
63: $: webManifestLink = pwaInfo ? pwaInfo.webManifest.linkTag : ''
64: </script>
65:
✓ 59 modules transformed.
(node:82998) ExperimentalWarning: CommonJS module /Users/velius/Documents/dev/15-gl2-kessler-schmidt/code/SignWriter/node_modules/tailwindcss/lib/lib/load-config.js is loading ES Module /Users/velius/Documents/dev/15-gl2-kessler-schmidt/code/SignWriter/tailwind.config.js using require().
Support for loading ES Module in require() is an experimental feature and might change at any time
(Use `node --trace-warnings ...` to show where the warning was created)
transforming (214) node_modules/svelte/src/internal/client/dom/legacy/lifecycle.js
PWA v0.21.0
mode generateSW
precache 2 entries (0.00 KiB)
files generated
.svelte-kit/output/server/sw.js
.svelte-kit/output/server/workbox-e3490c72.js
warnings
One of the glob patterns doesn't match any files. Please remove or fix the following: {
"globDirectory": "/Users/velius/Documents/dev/15-gl2-kessler-schmidt/code/SignWriter/.svelte-kit/output",
"globPattern": "**/*.{js,css,html,svg,png,ico,tff}",
"globIgnores": [
"server/**",
"server/sw.js",
"server/workbox-*.js"
"globPattern": "prerendered/**/*.html",
"globIgnores": [
"server/**",
"server/sw.js",
"globPattern": "client/**/*.{js,css,ico,png,svg,webp,webmanifest}",
"globIgnores": [
"server/**",
"server/sw.js",
x Build failed in 1.75s
error during build:
[vite:css] [postcss] Cannot read properties of undefined (reading 'call')
file: /Users/velius/Documents/dev/15-gl2-kessler-schmidt/code/SignWriter/src/app.css:undefined:NaN
at /Users/velius/Documents/dev/15-gl2-kessler-schmidt/code/SignWriter/tailwind.config.js:24:24
at evalModule (/Users/velius/Documents/dev/15-gl2-kessler-schmidt/code/SignWriter/node_modules/jiti/dist/jiti.js:1:247313)
at jiti (/Users/velius/Documents/dev/15-gl2-kessler-schmidt/code/SignWriter/node_modules/jiti/dist/jiti.js:1:245241)
at /Users/velius/Documents/dev/15-gl2-kessler-schmidt/code/SignWriter/node_modules/tailwindcss/lib/lib/load-config.js:56:30
at loadConfig (/Users/velius/Documents/dev/15-gl2-kessler-schmidt/code/SignWriter/node_modules/tailwindcss/lib/lib/load-config.js:58:6)
at getTailwindConfig (/Users/velius/Documents/dev/15-gl2-kessler-schmidt/code/SignWriter/node_modules/tailwindcss/lib/lib/setupTrackingContext.js:71:116)
at /Users/velius/Documents/dev/15-gl2-kessler-schmidt/code/SignWriter/node_modules/tailwindcss/lib/lib/setupTrackingContext.js:100:92
at /Users/velius/Documents/dev/15-gl2-kessler-schmidt/code/SignWriter/node_modules/tailwindcss/lib/processTailwindFeatures.js:46:11
at plugins (/Users/velius/Documents/dev/15-gl2-kessler-schmidt/code/SignWriter/node_modules/tailwindcss/lib/plugin.js:38:69)
at LazyResult.runOnRoot (/Users/velius/Documents/dev/15-gl2-kessler-schmidt/code/SignWriter/node_modules/postcss/lib/lazy-result.js:329:16)
"build.command" failed
Error message
Command failed with exit code 1: npm run build
Error location
In build.command from netlify.toml:
npm run build
Resolved config
build:
base: /Users/velius/Documents/dev/15-gl2-kessler-schmidt/code/SignWriter
command: npm run build
commandOrigin: config
publish: /Users/velius/Documents/dev/15-gl2-kessler-schmidt/code/SignWriter/build
publishOrigin: config
functionsDirectory: /Users/velius/Documents/dev/15-gl2-kessler-schmidt/code/SignWriter/netlify/functions
Successful build when running from /code/Signwriter:
⋊> ~/D/d/15-gl2-kessler-schmidt on c786f7f cd code/SignWriter/ 12:00:55
Now using Node v22.11.0 (npm 10.9.0) ~/.local/share/nvm/v22.11.0/bin/node
⋊> ~/D/d/1/c/SignWriter on c786f7f netlify build 12:03:26
Netlify Build
❯ Version
@netlify/build 29.56.1
❯ Flags
dry: false
offline: false
❯ Current directory
❯ Config file
❯ Context
production
$ npm run build
> vite build
transforming (1) node_modules/@sveltejs/kit/src/runtime/server/index.js12:03:37 PM [vite-plugin-svelte] src/routes/+layout.svelte:63:32 Properties of objects and arrays are not reactive unless in runes mode. Changes to this property will not cause the reactive statement to update
62:
64: </script>
65:
"SupabaseClient" is imported from external module "@supabase/supabase-js" but never used in "src/lib/components/cardItem.svelte" and "src/lib/supabaseUtils.ts".
✓ 254 modules transformed.
(node:83237) [DEP0040] DeprecationWarning: The `punycode` module is deprecated. Please use a userland alternative instead.
(Use `node --trace-deprecation ...` to show where the warning was created)
vite v5.4.11 building for production...
transforming (1) .svelte-kit/generated/client-optimized/nodes/0.js12:03:39 PM [vite-plugin-svelte] src/routes/+layout.svelte:63:32 Properties of objects and arrays are not reactive unless in runes mode. Changes to this property will not cause the reactive statement to update
62:
64: </script>
65:
✓ 346 modules transformed.
.svelte-kit/output/client/_app/version.json 0.03 kB │ gzip: 0.05 kB
.svelte-kit/output/client/registerSW.js 0.14 kB
.svelte-kit/output/client/manifest.webmanifest 0.23 kB
.svelte-kit/output/client/.vite/manifest.json 16.64 kB │ gzip: 1.92 kB
.svelte-kit/output/client/_app/immutable/assets/ProgressBar.c6i8ireL.css 0.28 kB │ gzip: 0.16 kB
.svelte-kit/output/client/_app/immutable/assets/0.ots5YvHz.css 127.34 kB │ gzip: 17.52 kB
.svelte-kit/output/client/_app/immutable/chunks/legacy.CtaTdtmd.js 0.04 kB │ gzip: 0.06 kB
.svelte-kit/output/client/_app/immutable/chunks/index.BFqC5wTN.js 0.05 kB │ gzip: 0.07 kB
.svelte-kit/output/client/_app/immutable/entry/start.3OvpZIvb.js 0.07 kB │ gzip: 0.08 kB
.svelte-kit/output/client/_app/immutable/chunks/disclose-version.Bg9kRutz.js 0.09 kB │ gzip: 0.09 kB
.svelte-kit/output/client/_app/immutable/nodes/6.BkRNxWVr.js 0.12 kB │ gzip: 0.12 kB
.svelte-kit/output/client/_app/immutable/nodes/12.BkRNxWVr.js 0.12 kB │ gzip: 0.12 kB
.svelte-kit/output/client/_app/immutable/chunks/misc.DDK2uyiO.js 0.18 kB │ gzip: 0.17 kB
.svelte-kit/output/client/_app/immutable/chunks/utils.B_Q8R824.js 0.19 kB │ gzip: 0.17 kB
.svelte-kit/output/client/_app/immutable/chunks/stores.CifvDHj0.js 0.29 kB │ gzip: 0.18 kB
.svelte-kit/output/client/_app/immutable/chunks/input.BS3GzRcw.js 0.30 kB │ gzip: 0.21 kB
.svelte-kit/output/client/_app/immutable/chunks/actions.LSM62X63.js 0.30 kB │ gzip: 0.24 kB
.svelte-kit/output/client/_app/immutable/chunks/browser.BaUz-1h7.js 0.31 kB │ gzip: 0.25 kB
.svelte-kit/output/client/_app/immutable/chunks/this.CMljLUwk.js 0.33 kB │ gzip: 0.24 kB
.svelte-kit/output/client/_app/immutable/chunks/if.CVYtOkhb.js 0.42 kB │ gzip: 0.31 kB
.svelte-kit/output/client/_app/immutable/chunks/class.CPj45Nlb.js 0.48 kB │ gzip: 0.23 kB
.svelte-kit/output/client/_app/immutable/chunks/lifecycle.DtVJorDm.js 0.54 kB │ gzip: 0.35 kB
.svelte-kit/output/client/_app/immutable/chunks/html.39sw9nTU.js 0.57 kB │ gzip: 0.40 kB
.svelte-kit/output/client/_app/immutable/chunks/store.KiU9jeEe.js 0.60 kB │ gzip: 0.36 kB
.svelte-kit/output/client/_app/immutable/chunks/_commonjsHelpers.BosuxZz1.js 0.69 kB │ gzip: 0.38 kB
.svelte-kit/output/client/_app/immutable/nodes/1.DuxPEUA0.js 0.71 kB │ gzip: 0.42 kB
.svelte-kit/output/client/_app/immutable/nodes/4.RuO0AtNq.js 1.09 kB │ gzip: 0.63 kB
.svelte-kit/output/client/_app/immutable/chunks/utils.DJ0zP7jS.js 1.09 kB │ gzip: 0.61 kB
.svelte-kit/output/client/_app/immutable/chunks/preload-helper.C1FmrZbK.js 1.14 kB │ gzip: 0.68 kB
.svelte-kit/output/client/_app/immutable/nodes/5.B_DeUELi.js 1.22 kB │ gzip: 0.68 kB
.svelte-kit/output/client/_app/immutable/chunks/ProgressBar.svelte_svelte_type_style_lang.OK0SGqZa.js 1.39 kB │ gzip: 0.67 kB
.svelte-kit/output/client/_app/immutable/nodes/8.DXSgWRzq.js 1.45 kB │ gzip: 0.82 kB
.svelte-kit/output/client/_app/immutable/chunks/render.CbwXIk-o.js 1.67 kB │ gzip: 0.96 kB
.svelte-kit/output/client/_app/immutable/chunks/Icon.JjnP8Wp7.js 1.73 kB │ gzip: 0.94 kB
.svelte-kit/output/client/_app/immutable/chunks/forms.DXL8ZZle.js 1.96 kB │ gzip: 0.94 kB
.svelte-kit/output/client/_app/immutable/chunks/props.BZ_1G8MU.js 1.98 kB │ gzip: 1.01 kB
.svelte-kit/output/client/_app/immutable/chunks/proxy.DOrp7pIm.js 2.10 kB │ gzip: 0.98 kB
.svelte-kit/output/client/_app/immutable/chunks/attributes.B5LQTcST.js 2.20 kB │ gzip: 1.12 kB
.svelte-kit/output/client/_app/immutable/nodes/7.Dhi17Jjs.js 2.31 kB │ gzip: 1.23 kB
.svelte-kit/output/client/_app/immutable/nodes/2.B-bt7u_7.js 2.31 kB │ gzip: 1.20 kB
.svelte-kit/output/client/_app/immutable/chunks/template.DHBgj9iB.js 3.16 kB │ gzip: 1.56 kB
.svelte-kit/output/client/_app/immutable/chunks/each.BSYkRwWU.js 3.19 kB │ gzip: 1.62 kB
.svelte-kit/output/client/_app/immutable/nodes/3.Brt72y7P.js 3.54 kB │ gzip: 1.52 kB
.svelte-kit/output/client/_app/immutable/nodes/9.DTpAlfS1.js 4.00 kB │ gzip: 1.84 kB
.svelte-kit/output/client/_app/immutable/nodes/10.CqiVg1p9.js 4.59 kB │ gzip: 2.31 kB
.svelte-kit/output/client/_app/immutable/chunks/index.CUIl3UGF.js 4.77 kB │ gzip: 2.22 kB
.svelte-kit/output/client/_app/immutable/nodes/11.DT55JB4e.js 5.99 kB │ gzip: 2.81 kB
.svelte-kit/output/client/_app/immutable/entry/app.CckpcZGm.js 7.31 kB │ gzip: 2.96 kB
.svelte-kit/output/client/_app/immutable/chunks/index-client.CjRRMbof.js 13.52 kB │ gzip: 5.54 kB
.svelte-kit/output/client/_app/immutable/chunks/functions.7WSLLGk3.js 19.36 kB │ gzip: 7.50 kB
.svelte-kit/output/client/_app/immutable/chunks/Ripple.DKMXekvJ.js 22.05 kB │ gzip: 5.39 kB
.svelte-kit/output/client/_app/immutable/chunks/entry.B8Bk3H5t.js 29.98 kB │ gzip: 11.78 kB
.svelte-kit/output/client/_app/immutable/chunks/supabaseUtils.D0hIs1KV.js 63.09 kB │ gzip: 21.33 kB
.svelte-kit/output/client/_app/immutable/nodes/0.B-k_p55a.js 130.76 kB │ gzip: 37.83 kB
.svelte-kit/output/client/_app/immutable/chunks/drawView.DIJp2C5W.js 4,758.93 kB │ gzip: 1,437.51 kB
(!) Some chunks are larger than 500 kB after minification. Consider:
- Using dynamic import() to code-split the application
- Use build.rollupOptions.output.manualChunks to improve chunking: https://rollupjs.org/configuration-options/#output-manualchunks
- Adjust chunk size limit for this warning via build.chunkSizeWarningLimit.
✓ built in 12.46s
.svelte-kit/output/server/.vite/manifest.json 7.91 kB
.svelte-kit/output/server/_app/immutable/assets/ProgressBar.c6i8ireL.css 0.28 kB
.svelte-kit/output/server/_app/immutable/assets/_layout.CN2naQyb.css 127.27 kB
.svelte-kit/output/server/entries/pages/_page.ts.js 0.05 kB
.svelte-kit/output/server/entries/pages/home/_page.svelte.js 0.06 kB
.svelte-kit/output/server/entries/pages/stats/_page.svelte.js 0.06 kB
.svelte-kit/output/server/chunks/html.js 0.14 kB
.svelte-kit/output/server/entries/pages/_layout.server.ts.js 0.22 kB
.svelte-kit/output/server/internal.js 0.31 kB
.svelte-kit/output/server/chunks/equality.js 0.33 kB
.svelte-kit/output/server/chunks/client.js 0.38 kB
.svelte-kit/output/server/chunks/public.js 0.39 kB
.svelte-kit/output/server/entries/fallbacks/error.svelte.js 0.52 kB
.svelte-kit/output/server/chunks/stores.js 0.69 kB
.svelte-kit/output/server/entries/pages/_layout.ts.js 0.78 kB
.svelte-kit/output/server/entries/pages/draw/_page.svelte.js 0.83 kB
.svelte-kit/output/server/entries/pages/draw/_id_/_page.svelte.js 1.08 kB
.svelte-kit/output/server/chunks/ProgressBar.svelte_svelte_type_style_lang.js 1.38 kB
.svelte-kit/output/server/entries/pages/settings/account/_page.server.ts.js 1.55 kB
.svelte-kit/output/server/chunks/index3.js 1.58 kB
.svelte-kit/output/server/entries/pages/modules/_id_/lectures/_page.svelte.js 1.66 kB
.svelte-kit/output/server/entries/pages/_page.svelte.js 1.74 kB
.svelte-kit/output/server/chunks/Icon.js 1.76 kB
.svelte-kit/output/server/entries/pages/auth/_page.server.ts.js 1.78 kB
.svelte-kit/output/server/chunks/supabaseUtils.js 2.18 kB
.svelte-kit/output/server/entries/pages/modules/_page.svelte.js 2.23 kB
.svelte-kit/output/server/entries/pages/auth/_page.svelte.js 2.30 kB
.svelte-kit/output/server/chunks/index2.js 2.34 kB
.svelte-kit/output/server/chunks/hooks.server.js 3.21 kB
.svelte-kit/output/server/entries/pages/modules/_id_/lectures/_id_/_page.svelte.js 4.45 kB
.svelte-kit/output/server/entries/pages/settings/_page.svelte.js 4.68 kB
.svelte-kit/output/server/chunks/drawView.js 5.61 kB
.svelte-kit/output/server/chunks/exports.js 6.09 kB
.svelte-kit/output/server/entries/pages/settings/account/_page.svelte.js 6.65 kB
.svelte-kit/output/server/chunks/internal.js 18.15 kB
.svelte-kit/output/server/entries/pages/_layout.svelte.js 19.45 kB
.svelte-kit/output/server/chunks/index.js 29.77 kB
.svelte-kit/output/server/chunks/functions.js 31.34 kB
.svelte-kit/output/server/index.js 91.64 kB
✓ built in 14.61s
PWA v0.21.0
mode generateSW
precache 63 entries (6591.94 KiB)
files generated
Run npm run preview to preview your production build locally.
> Using @sveltejs/adapter-auto
Could not detect a supported production environment. See https://svelte.dev/docs/kit/adapters to learn how to configure your app to run on the platform of your choosing
✔ done
(build.command completed in 16.9s)
Functions bundling
The Netlify Functions setting targets a non-existing directory: netlify/functions
(Functions bundling completed in 1ms)
Netlify Build Complete
(Netlify Build completed in 17.8s)
