1:05:34 PM: Build ready to start
1:05:36 PM: build-image version: 2dbd444fcdce00cf06325060a8238d5ae3e86774
1:05:36 PM: build-image tag: v3.3.7
1:05:36 PM: buildbot version: d305548225ac57bb00eb5a596b0b8674e76a4681
1:05:36 PM: Fetching cached dependencies
1:05:36 PM: Starting to download cache of 254.9KB
1:05:36 PM: Finished downloading cache in 65.826073ms
1:05:36 PM: Starting to extract cache
1:05:36 PM: Failed to fetch cache, continuing with build
1:05:36 PM: Starting to prepare the repo for build
1:05:37 PM: No cached dependencies found. Cloning fresh repo
1:05:37 PM: git clone https://github.com/Hal-Black/utba-dev1
1:05:38 PM: Preparing Git Reference refs/heads/master
1:05:38 PM: Found Netlify configuration file netlify.toml in site root
1:05:38 PM: Found Netlify configuration file(s). Overriding site configuration
1:05:38 PM: Different build command detected, going to use the one specified in the Netlify configuration file: ‘./stackbit-build.sh’ versus ‘hugo_0.47’ in the Netlify UI
1:05:38 PM: Starting build script
1:05:38 PM: Installing dependencies
1:05:39 PM: Downloading and installing node v10.20.1…
1:05:40 PM: Downloading https://nodejs.org/dist/v10.20.1/node-v10.20.1-linux-x64.tar.xz…
1:05:40 PM:
1:05:40 PM: 42.2%
1:05:40 PM:
1:05:40 PM: ################################## 100.0%
1:05:40 PM: Computing checksum with sha256sum
1:05:40 PM: Checksums matched!
1:05:43 PM: Now using node v10.20.1 (npm v6.14.4)
1:05:43 PM: Attempting ruby version 2.6.2, read from environment
1:05:44 PM: Using ruby version 2.6.2
1:05:44 PM: Using PHP version 5.6
1:05:44 PM: Installing Hugo 0.47
1:05:45 PM: Hugo Static Site Generator v0.47/extended linux/amd64 BuildDate: 2018-08-17T09:29:31Z
1:05:45 PM: Started restoring cached go cache
1:05:45 PM: Finished restoring cached go cache
1:05:45 PM: unset GOOS;
1:05:45 PM: unset GOARCH;
1:05:45 PM: export GOROOT=’/opt/buildhome/.gimme/versions/go1.12.linux.amd64’;
1:05:45 PM: export PATH="/opt/buildhome/.gimme/versions/go1.12.linux.amd64/bin:${PATH}";
1:05:45 PM: go version >&2;
1:05:45 PM: export GIMME_ENV=’/opt/buildhome/.gimme/env/go1.12.linux.amd64.env’;
1:05:45 PM: go version go1.12 linux/amd64
1:05:45 PM: Installing missing commands
1:05:45 PM: Verify run directory
1:05:45 PM: Executing user command: ./stackbit-build.sh
1:05:45 PM: /usr/local/bin/build: line 45: ./stackbit-build.sh: Permission denied
1:05:45 PM: Skipping functions preparation step: no functions directory set
1:05:45 PM: Caching artifacts
1:05:45 PM: Started saving pip cache
1:05:45 PM: Finished saving pip cache
1:05:45 PM: Started saving emacs cask dependencies
1:05:46 PM: Finished saving emacs cask dependencies
1:05:46 PM: Started saving maven dependencies
1:05:46 PM: Finished saving maven dependencies
1:05:46 PM: Started saving boot dependencies
1:05:46 PM: Finished saving boot dependencies
1:05:46 PM: Started saving go dependencies
1:05:46 PM: Finished saving go dependencies
1:05:50 PM: Error running command: Build script returned non-zero exit code: 126
1:05:50 PM: Failing build: Failed to build site
1:05:50 PM: failed during stage ‘building site’: Build script returned non-zero exit code: 126
1:05:50 PM: Finished processing build request in 13.830557606s
