Update: I moved the index.html to the root folder and that loads. Unfortunately, the app is still not booting up. It’s loading the index page but not booting the app. Nice.
the build says “site is live” but the site doesn’t load. It’s a plain react app–not using create-react-app. Is there anything special I need to do to have netlify load the site? Currently, I launch it locally using npm run start. Do I need to create some metadata describing how to start the app?
Page Not Found
Looks like you’ve followed a broken link or entered a URL that doesn’t exist on this site.
2:17:20 PM: Build ready to start
2:17:22 PM: build-image version: b0258b965567defc4a2d7e2f2dec2e00c8f73ad6
2:17:22 PM: build-image tag: v3.4.1
2:17:22 PM: buildbot version: e1f4178b0d9779ebad1b11d5b54739f82fed3c22
2:17:22 PM: Building without cache
2:17:22 PM: Starting to prepare the repo for build
2:17:22 PM: No cached dependencies found. Cloning fresh repo
2:17:23 PM: Preparing Git Reference refs/heads/master
2:17:24 PM: No build command found, continuing to publishing
2:17:24 PM: Starting to deploy site from ‘/’
2:17:24 PM: Creating deploy tree
2:17:24 PM: Creating deploy upload records
2:17:24 PM: 0 new files to upload
2:17:24 PM: 0 new functions to upload
2:17:24 PM: Starting post processing
2:17:24 PM: Post processing - HTML 2:17:24 PM: Post processing - header rules 2:17:24 PM: Post processing - redirect rules
2:17:24 PM: Post processing done
2:17:24 PM: Site is live
2:17:24 PM: Finished processing build request in 2.679841394s
I think we need some more information. What is your build directory (usually its public)? How are you deploying the site (through the cli, or wired up to a git repo)?
Just from looking at those logs, I see **2:17:24 PM: No build command found, continuing to publishing**. In your repo what do you have as your npm run build command in your package.json?
Here’s my package.js build: “build”: “node_modules/.bin/webpack --mode production”
I’m using npm run build as my build command. here’s my webpack config.
5:01:21 PM: WARNING in asset size limit: The following asset(s) exceed the recommended size limit (244 KiB).
5:01:21 PM: This can impact web performance.
5:01:21 PM: Assets:
5:01:21 PM: index_bundle.js (1.08 MiB)
5:01:21 PM: css/style.css (997 KiB)
5:01:21 PM: WARNING in entrypoint size limit: The following entrypoint(s) combined asset size exceeds the recommended limit (244 KiB). This can impact web performance.
5:01:21 PM: Entrypoints:
5:01:21 PM: main (2.05 MiB)
5:01:21 PM:
5:01:21 PM: WARNING in webpack performance recommendations:
5:01:21 PM: You can limit the size of your bundles by using import() or require.ensure to lazy load some parts of your application.
5:01:21 PM: For more info visit Code Splitting | webpack
I decided to use create-react-app and now I’m getting this:
9:10:09 PM: Treating warnings as errors because process.env.CI = true.
9:10:09 PM: Most CI servers set it automatically.
9:10:09 PM:
9:10:09 PM: Failed to compile.
9:10:09 PM:
9:10:09 PM: ./src/components/Map.js
9:10:09 PM: Line 11:7: ‘mapStyles’ is assigned a value but never used no-unused-vars
9:10:09 PM: Line 47:13: ‘arr’ is constant no-const-assign
9:10:09 PM: Line 117:26: img elements must have an alt prop, either with meaningful text, or an empty string for decorative images jsx-a11y/alt-text
9:10:09 PM: ./src/screens/room/TextContainer.js
9:10:09 PM: Line 15:33: The href attribute requires a valid value to be accessible. Provide a valid, navigable address as the href value. If you cannot provide a valid href, but still need the element to resemble a link, use a button and change it with appropriate styles. Learn more: https://github.com/evcohen/eslint-plugin-jsx-a11y/blob/master/docs/rules/anchor-is-valid.md jsx-a11y/anchor-is-valid
9:10:09 PM: ./src/components/MenuWrapper.jsx
9:10:09 PM: Line 15:58: Expected to return a value at the end of arrow function array-callback-return
9:10:09 PM: Line 20:55: Expected ‘!==’ and instead saw ‘!=’ eqeqeq
9:10:09 PM: ./src/screens/Login.js
9:10:09 PM: Line 16:19: ‘errorCode’ is assigned a value but never used no-unused-vars
9:10:09 PM: Line 17:19: ‘errorMessage’ is assigned a value but never used no-unused-vars
9:10:09 PM: Line 49:46: Using target=“_blank” without rel=“noopener noreferrer” is a security risk: see https://mathiasbynens.github.io/rel-noopener react/jsx-no-target-blank
9:10:09 PM: ./src/screens/Home.js
9:10:09 PM: Line 27:5: React Hook useEffect has missing dependencies: ‘GeoFirestore’, ‘auth.currentUser.uid’, and ‘db’. Either include them or remove the dependency array react-hooks/exhaustive-deps
9:10:09 PM: Line 33:45: Unexpected mix of ‘&&’ and ‘||’ no-mixed-operators
9:10:09 PM: Line 34:44: Unexpected mix of ‘&&’ and ‘||’ no-mixed-operators
9:10:09 PM: Line 137:19: Redundant alt attribute. Screen-readers already announce img tags as an image. You don’t need to use the words image, photo, or picture (or any specified custom words) in the alt prop jsx-a11y/img-redundant-alt
9:10:09 PM: ./src/screens/Map.js
9:10:09 PM: Line 2:10: ‘ResponsiveImage’ is defined but never used no-unused-vars
9:10:09 PM: Line 2:27: ‘ResponsiveImageSize’ is defined but never used no-unused-vars
9:10:09 PM: ./src/App.js
9:10:09 PM: Line 47:15: ‘isAnonymous’ is assigned a value but never used no-unused-vars
9:10:09 PM: Line 92:59: Expected to return a value at the end of arrow function array-callback-return
9:10:09 PM: Line 97:59: Expected ‘!==’ and instead saw ‘!=’ eqeqeq
9:10:09 PM: npm ERR! code ELIFECYCLE
9:10:09 PM: npm ERR! errno 1
9:10:09 PM: npm ERR! enhuff@0.1.0 build: react-scripts build
9:10:09 PM: npm ERR! Exit status 1
9:10:09 PM: npm ERR! Failed at the enhuff@0.1.0 build script.
9:10:09 PM: npm ERR! This is probably not a problem with npm. There is likely additional logging output above.
9:10:09 PM: npm ERR! A complete log of this run can be found in:
9:10:09 PM: npm ERR! /opt/buildhome/.npm/_logs/2020-09-06T01_10_09_687Z-debug.log
9:10:09 PM:
9:10:09 PM: ┌─────────────────────────────┐
9:10:09 PM: │ “build.command” failed │
9:10:09 PM: └─────────────────────────────┘
9:10:09 PM:
9:10:09 PM: Error message
9:10:09 PM: Command failed with exit code 1: npm run build
9:10:09 PM:
9:10:09 PM: Error location
9:10:09 PM: In Build command from Netlify app:
9:10:09 PM: npm run build
9:10:09 PM:
9:10:09 PM: Resolved config
I finally fixed the problem and managed to optimize a few things. “All warnings are treated as errors” was the culprit. In my package.json file, I added CI=false. Until I fix some of the warnings, this will do. Thanks
