6:03:53 PM: build-image version: 73f16e520fdddf409be6f578c8c2c8941bdf32d3 (focal)
6:03:53 PM: buildbot version: aae36d37bb0728ee6dc52d97c5e1b5b83720773e
6:03:53 PM: Fetching cached dependencies
6:03:53 PM: Failed to fetch cache, continuing with build
6:03:53 PM: Starting to prepare the repo for build
6:03:54 PM: No cached dependencies found. Cloning fresh repo
6:03:54 PM: git clone --filter=blob:none https://github.com/MohammedHegazy/Support_for_public_services
6:03:54 PM: Preparing Git Reference refs/heads/main
6:03:55 PM: Custom publish path detected. Proceeding with the specified path: βsupport-services/distβ
6:03:56 PM: Starting to install dependencies
6:03:56 PM: Python version set to 3.8
6:03:56 PM: Attempting Ruby version 2.7.2, read from environment
6:03:57 PM: Using Ruby version 2.7.2
6:03:57 PM: Started restoring cached go cache
6:03:57 PM: Finished restoring cached go cache
6:03:58 PM: Installing Go version 1.19.13 (requested 1.19.x)
6:04:03 PM: go version go1.19.13 linux/amd64
6:04:04 PM: Using PHP version 8.0
6:04:05 PM: Downloading and installing node v18.18.0β¦
6:04:05 PM: Downloading https://nodejs.org/dist/v18.18.0/node-v18.18.0-linux-x64.tar.xzβ¦
6:04:05 PM: Computing checksum with sha256sum
6:04:05 PM: Checksums matched!
6:04:08 PM: Now using node v18.18.0 (npm v9.8.1)
6:04:08 PM: Enabling Node.js Corepack
6:04:08 PM: Started restoring cached build plugins
6:04:08 PM: Finished restoring cached build plugins
6:04:08 PM: Started restoring cached corepack dependencies
6:04:08 PM: Finished restoring cached corepack dependencies
6:04:08 PM: No npm workspaces detected
6:04:08 PM: Started restoring cached node modules
6:04:08 PM: Finished restoring cached node modules
6:04:08 PM: Installing npm packages using npm version 9.8.1
6:04:13 PM: npm WARN deprecated consolidate@0.15.1: Please upgrade to consolidate v1.0.0+ as it has been modernized with several long-awaited fixes implemented. Maintenance is supported by Forward Email at https://forwardemail.net ; follow/watch GitHub - ladjs/consolidate: Template engine consolidation library for node.js for updates and release changelog
6:04:13 PM: npm WARN deprecated stable@0.1.8: Modern JS already guarantees Array#sort() is a stable sort, so this library is deprecated. See the compatibility table on MDN: Array.prototype.sort() - JavaScript | MDN
6:04:16 PM: npm WARN deprecated w3c-hr-time@1.0.2: Use your platformβs native performance.now() and performance.timeOrigin.
npm WARN deprecated popper.js@1.16.1: You can find the new Popper v2 at @popperjs/core, this package is dedicated to the legacy v1
6:04:18 PM: added 1364 packages, and audited 1365 packages in 10s
6:04:18 PM: 129 packages are looking for funding
6:04:18 PM: run npm fund
for details
6:04:18 PM: found 0 vulnerabilities
6:04:18 PM: npm packages installed
6:04:19 PM: Install dependencies script success
6:04:19 PM: Starting build script
6:04:20 PM: Detected 1 framework(s)
6:04:20 PM: vue at version 5.0.8
6:04:20 PM: Section completed: initializing
6:04:22 PM: β
6:04:22 PM: Netlify Build
6:04:22 PM: ββββββββββββββββββββββββββββββββββββββββββββββββββββββββββββββββ
6:04:22 PM: β
6:04:22 PM: β― Version
6:04:22 PM: @netlify/build 29.21.1
6:04:22 PM: β
6:04:22 PM: β― Flags
6:04:22 PM: baseRelDir: true
6:04:22 PM: buildId: 650b09d84c2d9a0099944541
6:04:22 PM: deployId: 650b09d84c2d9a0099944543
6:04:22 PM: β
6:04:22 PM: β― Current directory
6:04:22 PM: /opt/build/repo/support-services
6:04:22 PM: β
6:04:22 PM: β― Config file
6:04:22 PM: No config file was defined: using default values.
6:04:22 PM: β
6:04:22 PM: β― Context
6:04:22 PM: production
6:04:22 PM: β
6:04:22 PM: Build command from Netlify app
6:04:22 PM: β
6:04:22 PM: $ npm run build
6:04:22 PM: > support-services@0.1.0 build
6:04:22 PM: > vue-cli-service build
6:04:23 PM: All browser targets in the browserslist configuration have supported ES module.
6:04:23 PM: Therefore we donβt build two separate bundles for differential loading.
6:04:23 PM: - Building for productionβ¦
6:40:03 PM: Build exceeded maximum allowed runtime
Thank you soo much I really appreciate it
