My site is: https://limbus-company-id-creator.netlify.app/.
I keep running into “Module not found“ error when trying to deploy:
10:09:39 PM: Netlify Build
10:09:39 PM: ────────────────────────────────────────────────────────────────
10:09:39 PM:
10:09:39 PM: ❯ Version
10:09:39 PM: @netlify/build 35.1.8
10:09:39 PM:
10:09:39 PM: ❯ Flags
10:09:39 PM: accountId: 63e78bf9fb18ad28195c4f71
10:09:39 PM: baseRelDir: true
10:09:39 PM: buildId: 68e28a1d7a1a6426748951ab
10:09:39 PM: deployId: 68e28a1d7a1a6426748951ad
10:09:39 PM:
10:09:39 PM: ❯ Current directory
10:09:39 PM: /opt/build/repo/id-creator
10:09:39 PM:
10:09:39 PM: ❯ Config file
10:09:39 PM: No config file was defined: using default values.
10:09:39 PM:
10:09:39 PM: ❯ Context
10:09:39 PM: production
10:09:39 PM:
10:09:39 PM: Build command from Netlify app
10:09:39 PM:
10:09:39 PM: $ CI= npm run build && cp _redirects build
10:09:39 PM: > id-creator@0.1.0 build
10:09:39 PM: > react-scripts build
10:09:40 PM: Creating an optimized production build…
10:09:40 PM: Browserslist: caniuse-lite is outdated. Please run:
10:09:40 PM: npx update-browserslist-db@latest
10:09:40 PM: Why you should do it regularly: https://github.com/browserslist/update-db#readme
10:09:41 PM: Failed to compile.
10:09:41 PM:
10:09:41 PM: Module not found: Error: Can’t resolve ‘Utils/IndexDB/indexDB’ in ‘/opt/build/repo/id-creator/src’
10:09:41 PM:
10:09:41 PM: “build.command” failed
10:09:41 PM: ────────────────────────────────────────────────────────────────
10:09:41 PM:
10:09:41 PM: Error message
10:09:41 PM: Command failed with exit code 1: CI= npm run build && cp _redirects build (https://ntl.fyi/exit-code-1)
10:09:41 PM:
10:09:41 PM: Error location
10:09:41 PM: In Build command from Netlify app:
10:09:41 PM: CI= npm run build && cp _redirects build
10:09:41 PM:
10:09:41 PM: Resolved config
10:09:41 PM: build:
10:09:41 PM: base: /opt/build/repo/id-creator
10:09:41 PM: command: CI= npm run build && cp _redirects build
10:09:41 PM: commandOrigin: ui
10:09:41 PM: environment:
10:09:41 PM: - NODE_PATH
10:09:41 PM: - REACT_APP_GOOGLE_CLIENT_ID
10:09:41 PM: - REACT_APP_LOCAL_SAVE_MAX_LEN
10:09:41 PM: - REACT_APP_SERVER_URL
10:09:41 PM: publish: /opt/build/repo/id-creator/build
10:09:41 PM: publishOrigin: ui
10:09:41 PM: Build failed due to a user error: Build script returned non-zero exit code: 2
10:09:41 PM: Failing build: Failed to build site
10:09:42 PM: Finished processing build request in 23.848s
10:09:41 PM: Failed during stage ‘building site’: Build script returned non-zero exit code: 2 (https://ntl.fyi/exit-code-2).
“Utils/IndexDB/indexDB“ is a valid file path, and I have built the project successfully locally on my machine. Can someone help me with this?
