I am trying to host my express website on netlify with the help of serverless functions and everything is working well except the images. i have made public directory to store images and my css files. CSS is being applied on my website but i can’t see images which are in same folder as css.
so please help me regarding this issue.
Tell me if you need more info about this issue.
Thanks.
coelmay
December 11, 2021, 9:05pm
2
Hi @shivam1317
Welcome to the Netlify forums
Given the images and CSS are in the same directory, I can’t explain why the images would not load using netlify dev when the CSS does.
Is it possible for you to provide a git repository to inspect/test?
There’s no function code in the repository that you’ve provided.
Due to the redirect that redirects everything to /.netlify/functions/api/:splat it just results in:
Function not found…
Are you able to provide the function code too?
coelmay
December 12, 2021, 9:54am
5
Adding to @nathanmartin ’s comments, there is no build script in the package.json,only a test script (which doesn’t do much).
There isn’t a build or dev command in the netlify.toml, so can you say what command you are passing to netlify dev?
