I have a lambda function sending email from a contact form using nodemailer. The problem is I have that the lambda function refuses to let me put the call back function inside the transporter.send mail function like in this example.(makeithappen/sendMail.js at 79b9c8f3a7238dc75308f9a69d769d7cda7dd522 · kicholen/makeithappen · GitHub)`
transporter.sendMail({
to: process.env.MAIL_TO,
subject: process.env.SUBJECT + new Date().toLocaleString(),
text: event.body
}, function(error, info) {
if (error) {
callback(error);
} else {
callback(null, {
statusCode: 200,
body: "Ok"
But when I tried to do the same the lambda function continues to run indefinitely even after an email was sent. I want to have the callback function inside the send mail function like in the example so I can send an info or error message back to the client side. Right now I have the callback function outside of the transporter.sendmail function, but now the callback function is being executed quicker than the transporter.sendmail function can be executed.
transporter.sendMail(mailoptions, function (error, info) {
if (error) {
} else {
console.log(`Message sent`, info.messageId)
return callback(null, {
statusCode: 200,
headers: {
"Access-Control-Allow-Origin": "*",
"Access-Control-Allow-Headers": "Content-Type",
"Access-Control-Allow-Methods": "GET, POST, PUT, DELETE",
body: `{"message": "lambda function executed"}`,
Is there something I’m doing wrong when it comes to setting up the lambda?
