Hi all
Im trying to deploy my first netlify site. I am using ionic react with firebase.
When i deploy and go to the site with my desktop, all is working fine. When i go to the same link via my phone it says the page is not found. I have
-added a file _redirects with /* /index.html 200 (i downloaded my deploy code and it was there)
-Followed this tutorial: How to Deploy a React Application and did everything in there (enabled the api, set the domain in firebase, added the ionic/cli dependency, …)
-there is an index.html in my deploy code
I dont dare to link my site as this is a test deploy (i took it offline) to try and understand netlify with ionic and i havent yet added all the security for the firebase backend
Build settings:
build log:
7:50:23 PM: Build ready to start
7:50:25 PM: build-image version: 8925038cf853b22d6397cdcb9904ac88b66bb383 (focal)
7:50:25 PM: build-image tag: v4.5.0
7:50:25 PM: buildbot version: f344a535fc9e872014eaaa404a4e12d2d8b86d78
7:50:25 PM: Fetching cached dependencies
7:50:25 PM: Starting to download cache of 230.5MB
7:50:26 PM: Finished downloading cache in 1.144866417s
7:50:26 PM: Starting to extract cache
7:50:35 PM: Finished extracting cache in 9.245002789s
7:50:36 PM: Finished fetching cache in 10.479162417s
7:50:36 PM: Starting to prepare the repo for build
7:50:36 PM: Preparing Git Reference refs/heads/master
7:50:37 PM: Parsing package.json dependencies
7:50:38 PM: Starting build script
7:50:38 PM: Installing dependencies
7:50:38 PM: Python version set to 2.7
7:50:38 PM: Started restoring cached node version
7:50:41 PM: Finished restoring cached node version
7:50:42 PM: v16.13.1 is already installed.
7:50:42 PM: Now using node v16.13.1 (npm v8.1.2)
7:50:42 PM: Started restoring cached build plugins
7:50:42 PM: Finished restoring cached build plugins
7:50:42 PM: Attempting ruby version 2.7.2, read from environment
7:50:44 PM: Using ruby version 2.7.2
7:50:45 PM: Using PHP version 8.0
7:50:45 PM: Started restoring cached node modules
7:50:45 PM: Finished restoring cached node modules
7:50:45 PM: Started restoring cached go cache
7:50:45 PM: Finished restoring cached go cache
7:50:45 PM: go version go1.16.5 linux/amd64
7:50:45 PM: Installing missing commands
7:50:45 PM: Verify run directory
7:50:47 PM:
7:50:47 PM: ────────────────────────────────────────────────────────────────
7:50:47 PM: Netlify Build
7:50:47 PM:
7:50:47 PM: ❯ Version
7:50:47 PM: @netlify/build 20.0.4
7:50:47 PM:
7:50:47 PM: ❯ Flags
7:50:47 PM: baseRelDir: true
7:50:47 PM: buildId: 61abb86f69aa9c0007e72637
7:50:47 PM: deployId: 61abb86f69aa9c0007e72639
7:50:47 PM:
7:50:47 PM: ❯ Current directory
7:50:47 PM: /opt/build/repo
7:50:47 PM:
7:50:47 PM: ❯ Config file
7:50:47 PM: No config file was defined: using default values.
7:50:47 PM:
7:50:47 PM: ❯ Context
7:50:47 PM: production
7:50:47 PM:
7:50:47 PM: 1. Build command from Netlify app
7:50:47 PM:
7:50:47 PM: $ npm run build
7:50:47 PM: > brechtskookboek@0.0.1 build
7:50:47 PM: > ionic build
7:50:48 PM: > react-scripts build
7:50:51 PM: Creating an optimized production build…
7:51:24 PM: Compiled successfully.
7:51:24 PM:
7:51:24 PM: File sizes after gzip:
7:51:24 PM: 248.29 KB build/static/js/4.a2199161.chunk.js
7:51:24 PM: 30.11 KB build/static/js/57.c69a6871.chunk.js
7:51:24 PM: 26.37 KB build/static/js/55.81e9bf33.chunk.js
7:51:24 PM: 10.76 KB build/static/js/10.a2dc05d7.chunk.js
7:51:24 PM: 10.29 KB build/static/js/7.e65696aa.chunk.js
7:51:24 PM: 7.89 KB build/static/js/26.271a7ec5.chunk.js
7:51:24 PM: 7.76 KB build/static/js/main.b96860f6.chunk.js
7:51:24 PM: 7 KB build/static/js/6.2ee63194.chunk.js
7:51:24 PM: 6.01 KB build/static/js/11.2ab68ca3.chunk.js
7:51:24 PM: 5.9 KB build/static/js/49.8d5aca07.chunk.js
7:51:24 PM: 5.55 KB build/static/js/polyfills-dom.ae13af0f.chunk.js
7:51:24 PM: 5.37 KB build/static/js/34.2f841fae.chunk.js
7:51:24 PM: 5.26 KB build/static/js/28.1e037d20.chunk.js
7:51:24 PM: 5.22 KB build/static/js/19.e960177b.chunk.js
7:51:24 PM: 4.74 KB build/static/js/5.599b593b.chunk.js
7:51:24 PM: 4.66 KB build/static/js/31.8329ce63.chunk.js
7:51:24 PM: 4.62 KB build/static/js/14.c85ce645.chunk.js
7:51:24 PM: 4.59 KB build/static/js/32.acc76f57.chunk.js
7:51:24 PM: 4.46 KB build/static/js/33.2496a8b6.chunk.js
7:51:24 PM: 4.35 KB build/static/js/25.a042b699.chunk.js
7:51:24 PM: 4.25 KB build/static/js/8.9a70e3e2.chunk.js
7:51:24 PM: 4.08 KB build/static/js/35.b3700a58.chunk.js
7:51:24 PM: 3.99 KB build/static/js/23.9c2d6951.chunk.js
7:51:24 PM: 3.79 KB build/static/js/36.5e4cb33d.chunk.js
7:51:24 PM: 3.69 KB build/static/css/4.532f36fa.chunk.css
7:51:24 PM: 3.59 KB build/static/js/39.2c8f6ae7.chunk.js
7:51:24 PM: 3.53 KB build/static/js/24.0476210f.chunk.js
7:51:24 PM: 3.45 KB build/static/js/9.e39c5604.chunk.js
7:51:24 PM: 3.41 KB build/static/js/41.21b0e188.chunk.js
7:51:24 PM: 3.41 KB build/static/js/12.945404a3.chunk.js
7:51:24 PM: 3.15 KB build/static/js/51.a61192bc.chunk.js
7:51:24 PM: 3 KB build/static/js/30.6047133a.chunk.js
7:51:24 PM: 2.87 KB build/static/js/38.cc0139ff.chunk.js
7:51:24 PM: 2.8 KB build/static/js/18.958b528e.chunk.js
7:51:24 PM: 2.5 KB build/static/js/16.5b4fc4b7.chunk.js
7:51:24 PM: 2.49 KB build/static/js/27.565cd576.chunk.js
7:51:24 PM: 2.45 KB build/static/js/20.1bc73381.chunk.js
7:51:24 PM: 2.35 KB build/static/js/21.e7a0aa6a.chunk.js
7:51:24 PM: 2.29 KB build/static/js/29.14469869.chunk.js
7:51:24 PM: 2.07 KB build/static/js/53.c7ea70fa.chunk.js
7:51:24 PM: 2.01 KB build/static/js/43.7954b43f.chunk.js
7:51:24 PM: 1.99 KB build/static/js/13.cff733e3.chunk.js
7:51:24 PM: 1.92 KB build/static/js/15.408261f3.chunk.js
7:51:24 PM: 1.92 KB build/static/js/40.dc534173.chunk.js
7:51:24 PM: 1.89 KB build/static/css/main.d0c6a374.chunk.css
7:51:24 PM: 1.73 KB build/static/js/58.bd9ef7ba.chunk.js
7:51:24 PM: 1.71 KB build/static/js/45.d917f372.chunk.js
7:51:24 PM: 1.71 KB build/static/js/47.5744ea6d.chunk.js
7:51:24 PM: 1.69 KB build/static/js/runtime-main.df33dab5.js
7:51:24 PM: 1.6 KB build/static/js/22.07e7bd2a.chunk.js
7:51:24 PM: 1.52 KB build/static/js/50.685f74de.chunk.js
7:51:24 PM: 1.4 KB build/static/js/59.16e3bb47.chunk.js
7:51:24 PM: 1.25 KB build/static/js/17.5249fc89.chunk.js
7:51:24 PM: 1.14 KB build/static/js/48.bcf5e8d6.chunk.js
7:51:24 PM: 964 B build/static/js/56.d32c320e.chunk.js
7:51:24 PM: 775 B build/static/js/46.545dd1b8.chunk.js
7:51:24 PM: 706 B build/static/js/44.aef836fa.chunk.js
7:51:24 PM: 701 B build/static/js/52.148d8834.chunk.js
7:51:24 PM: 688 B build/static/js/37.d1b46d09.chunk.js
7:51:24 PM: 485 B build/static/js/42.c9d8854a.chunk.js
7:51:24 PM: 476 B build/static/js/0.be1c0674.chunk.js
7:51:24 PM: 469 B build/static/js/54.1b8876b1.chunk.js
7:51:24 PM: The project was built assuming it is hosted at /.
7:51:24 PM: You can control this with the homepage field in your package.json.
7:51:24 PM: The build folder is ready to be deployed.
7:51:24 PM: You may serve it with a static server:
7:51:24 PM: npm install -g serve
7:51:24 PM: serve -s build
7:51:24 PM: Find out more about deployment here:
7:51:24 PM: Deployment | Create React App
7:51:24 PM:
7:51:24 PM: (build.command completed in 37.4s)
7:51:24 PM:
7:51:24 PM: ────────────────────────────────────────────────────────────────
7:51:24 PM: 2. Deploy site
7:51:24 PM:
7:51:24 PM: Starting to deploy site from ‘build’
7:51:24 PM: Creating deploy tree
7:51:24 PM: Creating deploy upload records
7:51:25 PM: 0 new files to upload
7:51:25 PM: 0 new functions to upload
7:51:25 PM: Site deploy was successfully initiated
7:51:25 PM:
7:51:25 PM: (Deploy site completed in 234ms)
7:51:25 PM:
7:51:25 PM: ────────────────────────────────────────────────────────────────
7:51:25 PM: Netlify Build Complete
7:51:25 PM:
7:51:25 PM: (Netlify Build completed in 37.8s)
7:51:25 PM: Starting post processing
7:51:25 PM: Post processing - HTML
7:51:25 PM: Post processing - header rules
7:51:25 PM: Post processing - redirect rules
7:51:25 PM: Post processing done
7:51:25 PM: Caching artifacts
7:51:25 PM: Started saving node modules
7:51:25 PM: Finished saving node modules
7:51:25 PM: Started saving build plugins
7:51:25 PM: Finished saving build plugins
7:51:25 PM: Started saving pip cache
7:51:25 PM: Site is live ![]()
7:51:25 PM: Finished saving pip cache
7:51:25 PM: Started saving emacs cask dependencies
7:51:25 PM: Finished saving emacs cask dependencies
7:51:25 PM: Started saving maven dependencies
7:51:25 PM: Finished saving maven dependencies
7:51:25 PM: Started saving boot dependencies
7:51:25 PM: Finished saving boot dependencies
7:51:25 PM: Started saving rust rustup cache
7:51:25 PM: Finished saving rust rustup cache
7:51:25 PM: Started saving go dependencies
7:51:25 PM: Finished saving go dependencies
7:51:25 PM: Build script success
7:52:08 PM: Finished processing build request in 1m42.644068131s
