The first I noticed was that I did not need to add or invite any user under the identity tab, my github connected user and e-mail had been added automatically.
After clicking the link on the e-mail, I was redirected to my site and the token was appended to the end of the URL. So I was not prompted to set up a new password in Netlify’s CMS as suggested by the tutorial.
I contacted the creator and he mentioned that the issue was most probably related to Netlify, therefore my cry for help.
Heya @drodol and sorry to be slow to get back to you!
I think you are not including the netlify-identity-widget in your main /index.html - that’s what’s required for those links to “just work”. If you can’t do that for some reason, you can likely insert /admin/ before the token’s URL and it will work for you, but that’s pretty clunky to do repeatedly if you’ll have collaborators (since they’ll all have to do it too).
