Hi everyone,
I get an error while publishing my express app on netlify. The error snippets is here:
10:11:01 AM: Build ready to start
10:11:04 AM: build-image version: b0258b965567defc4a2d7e2f2dec2e00c8f73ad6
10:11:04 AM: build-image tag: v3.4.1
10:11:04 AM: buildbot version: 8c957a6d09a03023cea4239847cc73a9cb64eeb7
10:11:04 AM: Building without cache
10:11:04 AM: Starting to prepare the repo for build
10:11:04 AM: No cached dependencies found. Cloning fresh repo
10:11:04 AM: git clone https://github.com/blockjoin/joedu-nodejs-app
10:11:05 AM: Preparing Git Reference refs/heads/master
10:11:07 AM: Different functions path detected, going to use the one specified in the Netlify configuration file: ‘functions’ versus ‘’ in the Netlify UI
10:11:07 AM: Starting build script
10:11:07 AM: Installing dependencies
10:11:07 AM: Python version set to 2.7
10:11:09 AM: v12.18.0 is already installed.
10:11:10 AM: Now using node v12.18.0 (npm v6.14.4)
10:11:10 AM: Started restoring cached build plugins
10:11:10 AM: Finished restoring cached build plugins
10:11:10 AM: Attempting ruby version 2.7.1, read from environment
10:11:13 AM: Using ruby version 2.7.1
10:11:13 AM: Using PHP version 5.6
10:11:13 AM: 5.2 is already installed.
10:11:13 AM: Using Swift version 5.2
10:11:13 AM: Started restoring cached node modules
10:11:13 AM: Finished restoring cached node modules
10:11:14 AM: Installing NPM modules using NPM version 6.14.4
10:11:20 AM: npm WARN deprecated mkdirp-promise@5.0.1: This package is broken and no longer maintained. ‘mkdirp’ itself supports promises now, please switch to that.
10:11:22 AM: npm WARN deprecated multicodec@0.5.7: stable api reached
10:11:22 AM: npm WARN deprecated request@2.88.2: request has been deprecated, see https://github.com/request/request/issues/3142
10:11:23 AM: npm WARN deprecated har-validator@5.1.5: this library is no longer supported
10:11:41 AM: > bufferutil@4.0.1 install /opt/build/repo/node_modules/bufferutil
10:11:41 AM: > node-gyp-build
10:11:41 AM: > keccak@3.0.1 install /opt/build/repo/node_modules/keccak
10:11:41 AM: > node-gyp-build || exit 0
10:11:41 AM: > secp256k1@4.0.2 install /opt/build/repo/node_modules/secp256k1
10:11:42 AM: > utf-8-validate@5.0.2 install /opt/build/repo/node_modules/utf-8-validate
10:11:42 AM: > node-gyp-build
10:11:42 AM: > web3@1.3.0 postinstall /opt/build/repo/node_modules/web3
10:11:42 AM: > node angular-patch.js
10:11:43 AM: npm WARN Joedu_W3@1.0.0 No repository field.
10:11:43 AM: npm WARN optional SKIPPING OPTIONAL DEPENDENCY: fsevents@1.2.13 (node_modules/watchpack-chokidar2/node_modules/fsevents):
10:11:43 AM: npm WARN notsup SKIPPING OPTIONAL DEPENDENCY: Unsupported platform for fsevents@1.2.13: wanted {“os”:“darwin”,“arch”:“any”} (current: {“os”:“linux”,“arch”:“x64”})
10:11:43 AM: npm WARN optional SKIPPING OPTIONAL DEPENDENCY: fsevents@2.1.3 (node_modules/fsevents):
10:11:43 AM: npm WARN notsup SKIPPING OPTIONAL DEPENDENCY: Unsupported platform for fsevents@2.1.3: wanted {“os”:“darwin”,“arch”:“any”} (current: {“os”:“linux”,“arch”:“x64”})
10:11:43 AM: added 823 packages from 573 contributors and audited 828 packages in 28.651s
10:11:44 AM: 26 packages are looking for funding
10:11:44 AM: run npm fund for details
10:11:44 AM: found 1 low severity vulnerability
10:11:44 AM: run npm audit fix to fix them, or npm audit for details
10:11:45 AM: NPM modules installed
10:11:45 AM: Started restoring cached go cache
10:11:45 AM: Finished restoring cached go cache
10:11:46 AM: go version go1.14.4 linux/amd64
10:11:46 AM: Installing missing commands
10:11:46 AM: Verify run directory
10:11:48 AM:
10:11:48 AM: ┌─────────────────────────────┐
10:11:48 AM: │ Netlify Build │
10:11:48 AM: └─────────────────────────────┘
10:11:48 AM:
10:11:48 AM: ❯ Version
10:11:48 AM: @netlify/build 3.3.5
10:11:48 AM:
10:11:48 AM: ❯ Flags
10:11:48 AM: deployId: 5f61ba85d6bec462759d7f17
10:11:48 AM: mode: buildbot
10:11:48 AM:
10:11:48 AM: ❯ Current directory
10:11:48 AM: /opt/build/repo
10:11:48 AM:
10:11:48 AM: ❯ Config file
10:11:48 AM: /opt/build/repo/netlify.toml
10:11:48 AM:
10:11:48 AM: ❯ Context
10:11:48 AM: production
10:11:50 AM:
10:11:50 AM: ┌────────────────────────────────────┐
10:11:50 AM: │ 1. build.command from netlify.toml │
10:11:50 AM: └────────────────────────────────────┘
10:11:50 AM:
10:11:50 AM: $ CI= npm run build
10:11:50 AM: > Joedu_W3@1.0.0 build /opt/build/repo
10:11:50 AM: > netlify-lambda build src
10:11:51 AM: netlify-lambda: Building functions
10:11:55 AM: ModuleNotFoundError: Module not found: Error: Can’t resolve ‘electron’ in ‘/opt/build/repo/node_modules/swarm-js/node_modules/got’
at /opt/build/repo/node_modules/webpack/lib/Compilation.js:925:10
10:11:55 AM: at /opt/build/repo/node_modules/webpack/lib/NormalModuleFactory.js:401:22
10:11:55 AM: at /opt/build/repo/node_modules/webpack/lib/NormalModuleFactory.js:130:21
10:11:55 AM: at /opt/build/repo/node_modules/webpack/lib/NormalModuleFactory.js:224:22
10:11:55 AM: at /opt/build/repo/node_modules/neo-async/async.js:2830:7
10:11:55 AM: at /opt/build/repo/node_modules/neo-async/async.js:6877:13
10:11:55 AM: at /opt/build/repo/node_modules/webpack/lib/NormalModuleFactory.js:214:25
10:11:55 AM: at /opt/build/repo/node_modules/enhanced-resolve/lib/Resolver.js:213:14
10:11:55 AM: at /opt/build/repo/node_modules/enhanced-resolve/lib/Resolver.js:285:5
10:11:55 AM: at eval (eval at create (/opt/build/repo/node_modules/tapable/lib/HookCodeFactory.js:33:10), :13:1)
10:11:55 AM: at /opt/build/repo/node_modules/enhanced-resolve/lib/UnsafeCachePlugin.js:44:7
10:11:55 AM: at eval (eval at create (/opt/build/repo/node_modules/tapable/lib/HookCodeFactory.js:33:10), :25:1)
10:11:55 AM: at /opt/build/repo/node_modules/enhanced-resolve/lib/DescriptionFilePlugin.js:67:43
10:11:55 AM: resolve ‘electron’ in ‘/opt/build/repo/node_modules/swarm-js/node_modules/got’
10:11:55 AM: Parsed request is a module
10:11:55 AM: using description file: /opt/build/repo/node_modules/swarm-js/node_modules/got/package.json (relative path: .)
10:11:55 AM: resolve as module
10:11:55 AM: /opt/build/repo/node_modules/swarm-js/node_modules/got/node_modules doesn’t exist or is not a directory
/opt/build/repo/node_modules/swarm-js/node_modules/node_modules doesn’t exist or is not a directory
/opt/build/repo/node_modules/node_modules doesn’t exist or is not a directory
/opt/build/node_modules doesn’t exist or is not a directory
/opt/node_modules doesn’t exist or is not a directory
looking for modules in /opt/build/repo/node_modules/swarm-js/node_modules
10:11:55 AM: using description file: /opt/build/repo/node_modules/swarm-js/package.json (relative path: ./node_modules)
10:11:55 AM: using description file: /opt/build/repo/node_modules/swarm-js/package.json (relative path: ./node_modules/electron)
10:11:55 AM: no extension
10:11:55 AM: /opt/build/repo/node_modules/swarm-js/node_modules/electron doesn’t exist
10:11:55 AM: using description file: /opt/build/repo/package.json (relative path: ./node_modules)
10:11:55 AM: using description file: /opt/build/repo/package.json (relative path: ./node_modules/electron)
10:11:55 AM: /opt/build/repo/node_modules/electron doesn’t exist
.wasm
10:11:55 AM: /opt/build/repo/node_modules/swarm-js/node_modules/electron.wasm doesn’t exist
.wasm
10:11:55 AM: /opt/build/repo/node_modules/electron.wasm doesn’t exist
.mjs
10:11:55 AM: /opt/build/repo/node_modules/swarm-js/node_modules/electron.mjs doesn’t exist
.mjs
10:11:55 AM: /opt/build/repo/node_modules/electron.mjs doesn’t exist
.js
10:11:55 AM: /opt/build/repo/node_modules/swarm-js/node_modules/electron.js doesn’t exist
.js
10:11:55 AM: /opt/build/repo/node_modules/electron.js doesn’t exist
.json
10:11:55 AM: /opt/build/repo/node_modules/swarm-js/node_modules/electron.json doesn’t exist
.json
10:11:55 AM: /opt/build/repo/node_modules/electron.json doesn’t exist
.ts
10:11:55 AM: /opt/build/repo/node_modules/swarm-js/node_modules/electron.ts doesn’t exist
.ts
10:11:55 AM: /opt/build/repo/node_modules/electron.ts doesn’t exist
as directory
as directory
npm ERR! code ELIFECYCLE
10:11:55 AM: npm ERR! errno 1
10:11:55 AM: npm ERR! Joedu_W3@1.0.0 build: netlify-lambda build src
10:11:55 AM: npm ERR! Exit status 1
10:11:55 AM: npm ERR! Failed at the Joedu_W3@1.0.0 build script.
10:11:55 AM: npm ERR! This is probably not a problem with npm. There is likely additional logging output above.
10:11:55 AM: npm ERR! A complete log of this run can be found in:
10:11:55 AM: npm ERR! /opt/buildhome/.npm/_logs/2020-09-16T07_11_55_240Z-debug.log
10:11:55 AM:
10:11:55 AM: ┌─────────────────────────────┐
10:11:55 AM: │ “build.command” failed │
10:11:55 AM: └─────────────────────────────┘
10:11:55 AM:
10:11:55 AM: Error message
10:11:55 AM: Command failed with exit code 1: CI= npm run build
10:11:55 AM:
10:11:55 AM: Error location
10:11:55 AM: In build.command from netlify.toml:
10:11:55 AM: CI= npm run build
10:11:55 AM:
10:11:55 AM: Resolved config
10:11:55 AM: build:
10:11:55 AM: command: CI= npm run build
10:11:55 AM: commandOrigin: config
10:11:55 AM: functions: /opt/build/repo/functions
10:11:55 AM: publish: /opt/build/repo/dist
10:11:55 AM: Caching artifacts
10:11:55 AM: Started saving node modules
10:11:55 AM: Finished saving node modules
10:11:55 AM: Started saving build plugins
10:11:55 AM: Finished saving build plugins
10:11:55 AM: Started saving pip cache
10:11:55 AM: Finished saving pip cache
10:11:55 AM: Started saving emacs cask dependencies
10:11:55 AM: Finished saving emacs cask dependencies
10:11:55 AM: Started saving maven dependencies
10:11:55 AM: Finished saving maven dependencies
10:11:55 AM: Started saving boot dependencies
10:11:55 AM: Finished saving boot dependencies
10:11:55 AM: Started saving go dependencies
10:11:55 AM: Finished saving go dependencies
10:11:59 AM: Error running command: Build script returned non-zero exit code: 1
10:11:59 AM: Failing build: Failed to build site
10:11:59 AM: Failed during stage ‘building site’: Build script returned non-zero exit code: 1
10:11:59 AM: Finished processing build request in 55.11118327s
I set the Build command as CI= npm run build but i get this error again.
how can i fix this?
thank you,
