How to loading custom fonts
Hi there,
I have a static site developed with Vite using custom fonts. The structure is shown below
and my netlify.toml file looks like
[build]
  base    = ""
  publish = "dist"
  command = "npm run build"
  [build.processing]
    skip_processing = false
  [build.processing.css]
    bundle = true
    minify = false
  [build.processing.js]
    bundle = true
    minify = false
  [build.processing.html]
    pretty_urls = true
  [build.processing.images]
    compress = true
Styles, JavaScript and images are transferred over cloudfront.net and correctly loaded. However the fonts are not.
In my css file they are still referred with the local path (i.e., @font-face{font-family:onest;font-weight:700; src:url(assets/fonts/onest/OnestBold1602-hint.woff) ....)
How can I load my custom fonts?
Thanks,
Sig
Hi, to add a custom font to your Netlify project, you can follow these steps:
  1. Include your font files in your project directory (e.g. assets/fonts directory)
  2. In your CSS or SASS files, use the @font-face rule to specify your custom font:
@font-face {
  font-family: '300';
  font-display: fallback;
  src: url('/assets/fonts/NotoSans-Light.woff2') format('woff2');
  1. Use the custom font in your CSS by referring to the font-family example:
body {
  font-family: var(--font_300);
  1. In your netlify.toml, you can set a caching rule for your font files:
[[headers]]
  for = "/assets/fonts/*"
  [headers.values]
    cache-control = '''
    public,
    max-age=31536000'''
A similar user in the forums mentioned this:
Thanks for the reply. However, adding the headers in my netlify.toml doesn’t seem to fix the issue.
My CSS file looks like
@font-face {
    font-family: 'onest';
    font-weight: bold;
    src: url('assets/fonts/onest/Onest-Bold.woff') format('woff');
@font-face {
    font-weight: normal;
    src: url('assets/fonts/onest/Onest-Regular.woff') format('woff');
and the configuration file
[[headers]]
  [headers.values]
    cache-control = '''
    public,
    max-age=31536000'''
Now, in the console I have the following errors
change that to true and remove everything else after that.
also remove this:
and lastly,
change that to /assets/fonts/onest/Onest-Bold.woff
Thanks, fonts are now properly loaded.
