Hi
Can someone help me fix this error:
Error: module “hugo-future-imperfect-slim” not found; either add it as a Hugo Module or store it in “/opt/build/repo/themes”.: module does not exist.
Thanks!
Hi
Thanks!
hi there, could you post your full build log, please?
Hi perry,
Thanks for your answer.
Sorry, I am a newbie and I am trying to make a site for my pet kuka (a shitzu female).
Can you please tell me what is a full build log? and how can I post it ?
Thanks!
hi kuka’s parent!
Let’s see about getting you online. So you are building a site with hugo, correct? Are you deploying from a github repo? Also, can you tell us your netlify site name?
Hi perry
I´ve solved the problem inserting the files directly without using Github repository.
The site´s name is kuka-uk.netlify.app and is working “5 stars”!
Anyway thanks for your kind comments.
Yay! Glad you got it working, and Kuka is so cute
