Hi,
I have a Nuxt 3 site which I deploy on Netlify.
I want to include a private repo (some common libraries) as an NPM dependency direct from GitHub, which is added like so:
npm i org/repo
"dependencies": {
"@org/repo": "git+https://github.com/org/repo"
However, I know when it comes time to deploy, npm i will fail, as the repo is private.
What is the correct way to have Netlify install the private repo when it builds?
I’m not particularly dev-opsy, so I would appreciate a bit of hand-holding!
Thanks,
Dave
Melvin
2
Hi @davestewart,
Thanks for reaching!
I found this Netlify Support Guide:
Could you give that a read and see if it helps?
