HmacSHA256 encryption happens in angular local, but when built to netlify it does not happen
Hello there,
I have a resort booking application which has front end Angular and back-end Zoho creator. I have used edge functions in Netlify to link API from Zoho.
I’m facing issues when building.
This is the website link: https://vanavihari-ng.netlify.app/#/sign-in
I need encryption for the integration of the payment gateway Billdesk
it works in angular, but when building it fails.
The backend is Zoho creator
Frontend is angular 16, node 18
crypto.js “@types/crypto-js”: “^4.2.2”,
Can anyone tell me what is the exact issue? Let me know if you need more info.
Thank you in advance for your help
Thank you,
Balachandiran
TenSketch
The same error is mentioned here without a solution:
Hi, @TenSketch. Did you import it using the method described here?
Quoting:
  • Imports of Node built-in modules must be prefixed with node:, for example import { randomBytes } from "node:crypto".
