hi there, the error is undeniably this:
3:38:57 AM: ERROR Failed to compile with 1 errors10:38:57 AM
3:38:57 AM: This relative module was not found:
3:38:57 AM: * ../components/ClimateVideo.vue in ./src/router/index.js
3:38:57 AM: ERROR Build failed with errors.
usually, if a project builds locally but does not deploy correctly like this it is due to a case sensitivity issue:
does this apply here?
It did start work again after I deleted the ClimateVideo component in the router, but I still can’t get it to make sense, since I am doing this with a lot of components.
My guess is, I must have done something wrong when routerlinking it to a different component, but I have still not found any errors yet.
if you have other build errors, please feel free to post them again!
