hello I am having trouble deploying my site
it giving me a build errors
with the following errors: failed during stage ‘building site’: Build script returned non-zero exit code: 127
build result
9:16:03 PM: Build ready to start
9:16:05 PM: build-image version: 9cade8af58c2cf3a17a1e9433d2e979149488837
9:16:05 PM: build-image tag: v3.3.5
9:16:05 PM: buildbot version: 2d05064ce3dd2eb95d282a24602ab707dd9581e8
9:16:05 PM: Fetching cached dependencies
9:16:06 PM: Failed to fetch cache, continuing with build
9:16:06 PM: Starting to prepare the repo for build
9:16:06 PM: No cached dependencies found. Cloning fresh repo
9:16:06 PM: git clone git@gitlab.com:jomarcenter-MJM/mjmcreativeworksweb
9:16:07 PM: Preparing Git Reference refs/heads/master
9:16:08 PM: Starting build script
9:16:08 PM: Installing dependencies
9:16:10 PM: Downloading and installing node v10.18.0...
9:16:10 PM: Downloading https://nodejs.org/dist/v10.18.0/node-v10.18.0-linux-x64.tar.xz...
9:16:10 PM:
9:16:10 PM: ################# 83.1%
9:16:10 PM:
9:16:10 PM: ########### 100.0%
9:16:10 PM: Computing checksum with sha256sum
9:16:10 PM: Checksums matched!
9:16:13 PM: Now using node v10.18.0 (npm v6.13.4)
9:16:13 PM: Attempting ruby version 2.6.2, read from environment
9:16:14 PM: Using ruby version 2.6.2
9:16:15 PM: Using PHP version 5.6
9:16:15 PM: Started restoring cached node modules
9:16:15 PM: Finished restoring cached node modules
9:16:15 PM: Installing NPM modules using NPM version 6.13.4
9:16:51 PM: > sharp@0.23.4 install /opt/build/repo/node_modules/sharp
9:16:51 PM: > (node install/libvips && node install/dll-copy && prebuild-install) || (node-gyp rebuild && node install/dll-copy)
9:16:51 PM: info
9:16:51 PM: sharp Downloading https://github.com/lovell/sharp-libvips/releases/download/v8.8.1/libvips-8.8.1-linux-x64.tar.gz
9:16:55 PM: > node-sass@4.13.0 install /opt/build/repo/node_modules/node-sass
9:16:55 PM: > node scripts/install.js
9:16:56 PM: Downloading binary from https://github.com/sass/node-sass/releases/download/v4.13.0/linux-x64-64_binding.node
9:16:56 PM: Download complete
9:16:56 PM: Binary saved to /opt/build/repo/node_modules/node-sass/vendor/linux-x64-64/binding.node
9:16:56 PM: Caching binary to /opt/buildhome/.npm/node-sass/4.13.0/linux-x64-64_binding.node
9:16:57 PM: > core-js@2.6.11 postinstall /opt/build/repo/node_modules/core-js
9:16:57 PM: > node -e "try{require('./postinstall')}catch(e){}"
9:16:57 PM: Thank you for using core-js ( https://github.com/zloirock/core-js ) for polyfilling JavaScript standard library!
9:16:57 PM: The project needs your help! Please consider supporting of core-js on Open Collective or Patreon:
9:16:57 PM: > https://opencollective.com/core-js
9:16:57 PM: > https://www.patreon.com/zloirock
9:16:57 PM: Also, the author of core-js ( https://github.com/zloirock ) is looking for a good job -)
9:16:57 PM: > core-js-pure@3.6.2 postinstall /opt/build/repo/node_modules/core-js-pure
9:16:57 PM: > gatsby-telemetry@1.1.46 postinstall /opt/build/repo/node_modules/gatsby-telemetry
9:16:57 PM: > node src/postinstall.js || true
9:16:58 PM: > cwebp-bin@5.1.0 postinstall /opt/build/repo/node_modules/cwebp-bin
9:16:58 PM: > node lib/install.js
9:16:58 PM: ✔ cwebp pre-build test passed successfully
9:16:58 PM: > mozjpeg@6.0.1 postinstall /opt/build/repo/node_modules/mozjpeg
9:16:59 PM: ✔ mozjpeg pre-build test passed successfully
9:16:59 PM: > pngquant-bin@5.0.2 postinstall /opt/build/repo/node_modules/pngquant-bin
9:16:59 PM: > node lib/install.js
9:16:59 PM: ✔ pngquant pre-build test passed successfully
9:16:59 PM: > gatsby-cli@2.8.23 postinstall /opt/build/repo/node_modules/gatsby/node_modules/gatsby-cli
9:16:59 PM: > node scripts/postinstall.js
9:16:59 PM: > gatsby@2.18.18 postinstall /opt/build/repo/node_modules/gatsby
9:17:00 PM: > node-sass@4.13.0 postinstall /opt/build/repo/node_modules/node-sass
9:17:00 PM: > node scripts/build.js
9:17:00 PM: Binary found at /opt/build/repo/node_modules/node-sass/vendor/linux-x64-64/binding.node
9:17:00 PM: Testing binary
9:17:00 PM: Binary is fine
9:17:00 PM: > catalyst-coin-website@ postinstall /opt/build/repo
9:17:00 PM: > npm rebuild node-sass
9:17:04 PM: > node-sass@4.13.0 install /opt/build/repo/node_modules/node-sass
9:17:04 PM: > node scripts/install.js
9:17:05 PM: node-sass build Binary found at /opt/build/repo/node_modules/node-sass/vendor/linux-x64-64/binding.node
9:17:05 PM: > node-sass@4.13.0 postinstall /opt/build/repo/node_modules/node-sass
9:17:05 PM: > node scripts/build.js
9:17:05 PM: Binary found at /opt/build/repo/node_modules/node-sass/vendor/linux-x64-64/binding.node
9:17:05 PM: Testing binary
9:17:05 PM: Binary is fine
9:17:05 PM: node-sass@4.13.0 /opt/build/repo/node_modules/node-sass
9:17:08 PM: npm
9:17:08 PM: WARN catalyst-coin-website@ No repository field.
9:17:08 PM: npm WARN optional SKIPPING OPTIONAL DEPENDENCY: fsevents@1.2.11 (node_modules/fsevents):
9:17:08 PM: npm
9:17:08 PM: WARN notsup SKIPPING OPTIONAL DEPENDENCY: Unsupported platform for fsevents@1.2.11: wanted {"os":"darwin","arch":"any"} (current: {"os":"linux","arch":"x64"})
9:17:08 PM: npm WARN optional SKIPPING OPTIONAL DEPENDENCY: fsevents@2.1.2 (node_modules/chokidar/node_modules/fsevents):
9:17:08 PM: npm WARN notsup SKIPPING OPTIONAL DEPENDENCY: Unsupported platform for fsevents@2.1.2: wanted {"os":"darwin","arch":"any"} (current: {"os":"linux","arch":"x64"})
9:17:08 PM: added 2271 packages from 1095 contributors and audited 26034 packages in 51.823s
9:17:11 PM: 54 packages are looking for funding
9:17:11 PM: run `npm fund` for details
9:17:11 PM: found 0 vulnerabilities
9:17:11 PM: NPM modules installed
9:17:11 PM: Started restoring cached go cache
9:17:11 PM: Finished restoring cached go cache
9:17:11 PM: unset GOOS;
9:17:11 PM: unset GOARCH;
9:17:11 PM: export GOROOT='/opt/buildhome/.gimme/versions/go1.12.linux.amd64';
9:17:11 PM: export PATH="/opt/buildhome/.gimme/versions/go1.12.linux.amd64/bin:${PATH}";
9:17:11 PM: go version >&2;
9:17:11 PM: export GIMME_ENV='/opt/buildhome/.gimme/env/go1.12.linux.amd64.env';
9:17:11 PM: go version go1.12 linux/amd64
9:17:11 PM: Installing missing commands
9:17:11 PM: Verify run directory
9:17:11 PM: Executing user command: gatsby build
9:17:14 PM: success open and validate gatsby-configs - 0.078s
9:17:15 PM: error Error in "/opt/build/repo/gatsby-node.js": ENOENT: no such file or directory, open './content/docs/master/nav.yml'
9:17:15 PM:
9:17:15 PM: Error: ENOENT: no such file or directory, open './content/docs/master/nav.yml'
9:17:15 PM: - create-docs-pages.js:18 versions.forEach.version
9:17:15 PM: /opt/build/repo/src/actions/create-pages/create-docs-pages.js:18:5
9:17:15 PM:
9:17:15 PM: - Array.forEach
9:17:15 PM:
9:17:15 PM: - create-docs-pages.js:15 Object.<anonymous>
9:17:15 PM: /opt/build/repo/src/actions/create-pages/create-docs-pages.js:15:10
9:17:15 PM:
9:17:15 PM: - v8-compile-cache.js:178 Module._compile
9:17:15 PM: [repo]/[v8-compile-cache]/v8-compile-cache.js:178:30
9:17:15 PM:
9:17:15 PM: - loader.js:789 Object.Module._extensions..js
9:17:15 PM: internal/modules/cjs/loader.js:789:10
9:17:15 PM:
9:17:15 PM: - loader.js:653 Module.load
9:17:15 PM: internal/modules/cjs/loader.js:653:32
9:17:15 PM:
9:17:15 PM: - loader.js:593 tryModuleLoad
9:17:15 PM: internal/modules/cjs/loader.js:593:12
9:17:15 PM:
9:17:15 PM: - loader.js:585 Function.Module._load
9:17:15 PM: internal/modules/cjs/loader.js:585:3
9:17:15 PM:
9:17:15 PM: - loader.js:692 Module.require
9:17:15 PM: internal/modules/cjs/loader.js:692:17
9:17:15 PM:
9:17:15 PM: - v8-compile-cache.js:159 require
9:17:15 PM: [repo]/[v8-compile-cache]/v8-compile-cache.js:159:20
9:17:15 PM:
9:17:15 PM: - create-pages.js:1 Object.<anonymous>
9:17:15 PM: /opt/build/repo/src/actions/create-pages.js:1:87
9:17:15 PM:
9:17:15 PM:
9:17:15 PM:
9:17:15 PM:
9:17:15 PM:
9:17:15 PM: not finished load plugins - 1.109s
9:17:15 PM: Skipping functions preparation step: no functions directory set
9:17:15 PM: Caching artifacts
9:17:15 PM: Started saving node modules
9:17:15 PM: Finished saving node modules
9:17:15 PM: Started saving pip cache
9:17:15 PM: Finished saving pip cache
9:17:15 PM: Started saving emacs cask dependencies
9:17:15 PM: Finished saving emacs cask dependencies
9:17:15 PM: Started saving maven dependencies
9:17:15 PM: Finished saving maven dependencies
9:17:15 PM: Started saving boot dependencies
9:17:15 PM: Finished saving boot dependencies
9:17:15 PM: Started saving go dependencies
9:17:15 PM: Finished saving go dependencies
9:17:19 PM: Error running command: Build script returned non-zero exit code: 1
9:17:19 PM: Failing build: Failed to build site
9:17:19 PM: failed during stage 'building site': Build script returned non-zero exit code: 1
9:17:19 PM: Finished processing build request in 1m14.276711734s
IDK if I missed something or something else
And also I am planning to install forestry CMS on it as well.
