Help with CORS problem with Edge Functions
Hello,
I’m trying to make an Axios request from localhost to a netlify Edge Function and I get “Origin is not allowed by Access-Control-Allow-Origin. Status code: 200” error.
I have the following netlify.toml
[[headers]]
  for = "/*"
    [headers.values]
    Access-Control-Allow-Origin = "*"
[[edge_functions]]
    function = "login"
    path = "/login"
If I test it locally by running “netlify dev”, the header is set and it works. But if I build it, it doesn’t work.
This is my netlify build: https://uilens-api.netlify.app/login
Can you help? Thank you!
Hey @cerpow
You’ll need to add the Access-Control-Allow-Origin header to the function return.
E.G.
export default async () => {
  return new Response("OK", {
    headers: {
      'Allow-Access-Control-Origin': '*'
Awesome! That worked!
It’s actually Access-Control-Allow-Origin but worked.
How can I set the header to res.json?
Thank you!
Do you mean the Content-Type header?
I mean context, sorry, it’s actually the same:
return ctx.json(
		{ message: 'hello'},
			headers: {
				'Access-Control-Allow-Origin': '*',
I believe this is what you are looking for.
export default async (req, ctx) => {
  let res = ctx.json({ msg: "hello" })
  res.headers.append('Allow-Access-Control-Origin', '*')
  return res
Yes, thank you very much!
