Hello!
We’re using Cypress - the netlify-plugin-cypress package - to run some end-to-end tests on deploy previews.
The problem is that we run multiple sites with different content from one codebase. We have site-specific Cypress tests that, when run on a site other than the one they were intended for, fail.
I’d like to use a variable to change the spec
input value, but can’t figure out how to use it in the netlify.toml file.
Example:
Assume we have a site called “example-site”.
We have some universal tests in /cypress/e2e/universal, and some site-specific tests in /cypress/e2e/example-site
In netlify.toml, I’ve tried this:
[context.dev.environment]
CYPRESS_SPECS = "cypress/e2e/universal/*.cy.ts,cypress/e2e/$SITE_NAME/*.cy.ts"
[[context.dev.plugins]]
package = "netlify-plugin-cypress"
[context.dev.plugins.inputs]
enable = false
[context.dev.plugins.inputs.preBuild]
enable = true
configFile = "cypress.config.ts"
record = false
spec = $CYPRESS_SPECS
start = "next dev"
wait-on = 'http://localhost:3000'
But it reads $SITE_NAME literally and looks for tests in /cypress/e2e/universal/ (correct) and /cypress/e2e/$SITE_NAME/ (incorrect)
Any ideas?
