Help needed re : usage of environment variable / snippet injection
Hi there,
A very basic question from a newbie….
I have created a basic front end only news reader application with vanilla JS, no frameworks, which fetches news from a third party API and display them on the front end.
Site name is:
https://clabs-newsreader.netlify.app/
I would not want to share the api key, so I have hidden the api key in a config.js file, and then placed it into a script in the HTML, and then created a variable on index.js to use on the call to the API :
//config.js
const config = {
API_KEY: “***********”
HTML
<script src="config.js"></script>
<script src="index.js"></script>
JS
const apikey = config.API_KEY
const topHeadlines = https://content.guardianapis.com/search?api-key=${apikey}&show-fields=thumbnail;
The app works fine locally, however does not when deployed to netlify. Console error is :
index.js:8 Uncaught ReferenceError: config is not defined
I have tried:
  1. setting the apikey as environment variable through netlify UI - does not work
2.added a snippet injection trough netlify UI ( )- does not work either
Am i missing something?
Thanks in advance
Your config.js script returns 404, thus the error.
If there is a link to your config file in your HTML, your API key is not hidden, it’s just moved. Anyone looking for it will be able to find it.
@hrishikesh @gregraven Thanks both!!
I understand config script gives 404 as it is included into a .gitignore
I guess I was just looking for a way to try and hid the apikey, mainly because I am trying to put a portfolio in place & was trying to show that I am also thinking about security of my application…
Any advice for what I am trying to achieve?
Many thanks again!
You’ll have to make use of a Netlify Function to be able to hide your API key. If you use an environment variable in your JS build, it will still show up on your site.
Here’s a simple Netlify function get-headlines.js to get you going:
exports.handler = async (event, context) => {
  const headlines = `https://content.guardianapis.com/search?api-key=${process.env.API_KEY}&show-fields=thumbnail;`
  return {
    statusCode: 200,
    body: headlines
You’ll have to set an environment variable called API_KEY for it to work.
You then fetch it kinda like this (untested)
const response = await fetch('/.netlify/functions/get-headlines, {
  method: 'POST',
  headers: {
    'Content-Type': 'application/json',
}).then((res) => res.json());
console.log(response.body);
For obvious reasons I wouldn’t copy and paste this to use in production. I recommend you read up on Netlify Functions in the docs and browse through the playground a bit
Hi, @0750kosse. We also have a support guide here about how to use Functions to keep your API keys safe:
