I am having trouble deploying a react app I have saved at github repository: GitHub - SamMathewson98/Combat-Customs-QC-Retry
I get error codes 1 and 2 during the build stage. I posted my errors below:
8:44:55 AM:
8:44:55 AM: “build.command” failed
8:44:55 AM: ────────────────────────────────────────────────────────────────
8:44:55 AM:
8:44:55 AM: Error message
8:44:55 AM: Command failed with exit code 1: npm install && npm run build (Search results for '"non-zero exit code: 1"' - Netlify Support Forums)
8:44:55 AM:
8:44:55 AM: Error location
8:44:55 AM: In Build command from Netlify app:
8:44:55 AM: npm install && npm run build
8:44:55 AM:
8:44:55 AM: Resolved config
8:44:55 AM: build:
8:44:55 AM: command: npm install && npm run build
8:44:55 AM: commandOrigin: ui
8:44:55 AM: publish: /opt/build/repo/build
8:44:55 AM: publishOrigin: ui
8:44:57 AM: Build failed due to a user error: Build script returned non-zero exit code: 2
8:44:57 AM: Failing build: Failed to build site
8:44:58 AM: Finished processing build request in 46.98s
