Until just now we’ve been using Gatsby Cloud to build our Gatsby JS site which then deploys to Netlify. However, with the recent decision to move Gatsby Cloud into Netlify, we’re now in a position where the build fails every time.
It builds without issue on Gatsby Cloud. The same repository fails to build on Netlify with an error of:
Build failed due to a user error: Build script returned non-zero exit code: 2
For context, we use Prismic as the CMS and the site is currently on Gatsby v2 (it’s not possible to upgrade at the moment).
We have a staging version of Prismic and a live version of Prismic. The site builds fine when using the data from the staging version of Prismic but fails on the live version.
I wonder if you could please help me figure out why the site is failing each time when using the live CMS data?
The site is called: ‘leafy-torrone-d97831’. Below is the deploy log. My thoughts are that because the live site has more pages, images etc that it’s timing out or using too much memory. Would upgrading resolve this issue?
