'gatsby build' works locally but not on Netlify
I can’t seem to figure out why my Gatsby application works on my machine but won’t deploy to Netlify.
Here are the build logs
10:54:03 PM: Build ready to start
10:54:05 PM: build-image version: 3571f0130496395a23bffe9820bc78b4f73a6234
10:54:05 PM: build-image tag: v3.7.0
10:54:05 PM: buildbot version: bd229cb35229750ceaca8bc031fa7f526aef77de
10:54:05 PM: Building without cache
10:54:05 PM: Starting to prepare the repo for build
10:54:05 PM: No cached dependencies found. Cloning fresh repo
10:54:05 PM: git clone
10:54:08 PM: Preparing Git Reference refs/heads/main
10:54:11 PM: Starting build script
10:54:11 PM: Installing dependencies
10:54:11 PM: Python version set to 2.7
10:54:12 PM: v12.18.0 is already installed.
10:54:12 PM: Now using node v12.18.0 (npm v6.14.4)
10:54:13 PM: Started restoring cached build plugins
10:54:13 PM: Finished restoring cached build plugins
10:54:13 PM: Attempting ruby version 2.7.1, read from environment
10:54:14 PM: Using ruby version 2.7.1
10:54:14 PM: Using PHP version 5.6
10:54:14 PM: Started restoring cached node modules
10:54:14 PM: Finished restoring cached node modules
10:54:15 PM: Installing NPM modules using NPM version 6.14.4
10:55:05 PM: > sharp@0.25.4 install /opt/build/repo/node_modules/sharp-cli/node_modules/sharp
10:55:05 PM: > (node install/libvips && node install/dll-copy && prebuild-install --runtime=napi) || (node-gyp rebuild && node install/dll-copy)
10:55:07 PM: info sharp Downloading https://github.com/lovell/sharp-libvips/releases/download/v8.9.1/libvips-8.9.1-linux-x64.tar.gz
10:55:09 PM: > sharp@0.20.8 install /opt/build/repo/node_modules/sharp
10:55:09 PM: > (node install/libvips && node install/dll-copy && prebuild-install) || (node-gyp rebuild && node install/dll-copy)
10:55:11 PM: info sharp Detected globally-installed libvips v8.6.2
10:55:11 PM: info sharp Building from source via node-gyp
10:55:15 PM: make: Entering directory ‘/opt/build/repo/node_modules/sharp/build’
10:55:15 PM: TOUCH Release/obj.target/libvips-cpp.stamp
10:55:15 PM: CXX(target) Release/obj.target/sharp/src/common.o
10:55:17 PM: In file included from ../src/common.cc:27:0:
10:55:17 PM: ../src/common.h:82:16: error: ‘Handle’ is not a member of ‘v8’
10:55:17 PM: bool HasAttr(v8::Handle<v8: :Object> obj, std::string attr);
10:55:17 PM: ^
10:55:17 PM: ../src/common.h:82:37: error: expected primary-expression before ‘>’ token
10:55:17 PM: bool HasAttr(v8::Handle obj, std::string attr);
10:55:17 PM: ^
10:55:17 PM: ^
10:55:17 PM: ../src/common.cc:609:1: error: expected ‘}’ at end of input
10:55:17 PM: } // namespace sharp
10:55:17 PM: ^
10:55:17 PM: sharp.target.mk:158: recipe for target ‘Release/obj.target/sharp/src/common.o’ failed
10:55:17 PM: make: *** [Release/obj.target/sharp/src/common.o] Error 1
10:55:17 PM: make: Leaving directory ‘/opt/build/repo/node_modules/sharp/build’
10:55:17 PM: gyp ERR! build error
10:55:17 PM: gyp ERR! stack Error: make failed with exit code: 2
10:55:17 PM: gyp ERR! stack at ChildProcess.onExit (/opt/buildhome/.nvm/versions/node/v12.18.0/lib/node_modules/npm/node_modules/node-gyp/lib/build.js:194:23)
10:55:17 PM: gyp ERR! stack at ChildProcess.emit (events.js:315:20)
10:55:17 PM: gyp ERR! stack at Process.ChildProcess._handle.onexit (internal/child_process.js:275:12)
10:55:17 PM: gyp ERR! System Linux 4.19.112+
10:55:17 PM: gyp ERR! command “/opt/buildhome/.nvm/versions/node/v12.18.0/bin/node” “/opt/buildhome/.nvm/versions/node/v12.18.0/lib/node_modules/npm/node_modules/node-gyp/bin/node-gyp.js” “rebuild”
10:55:17 PM: gyp ERR! cwd /opt/build/repo/node_modules/sharp
10:55:17 PM: gyp ERR! node -v v12.18.0
10:55:17 PM: gyp ERR! node-gyp -v v5.1.0
10:55:17 PM: gyp ERR! not ok
10:55:19 PM: npm WARN optional SKIPPING OPTIONAL DEPENDENCY: fsevents@1.2.13 (node_modules/fsevents):
10:55:19 PM: npm WARN notsup SKIPPING OPTIONAL DEPENDENCY: Unsupported platform for fsevents@1.2.13: wanted {“os”:“darwin”,“arch”:“any”} (current: {“os”:“linux”,“arch”:“x64”})
10:55:19 PM: npm ERR! code ELIFECYCLE
10:55:19 PM: npm ERR! errno 1
10:55:19 PM: npm ERR! sharp@0.20.8 install: (node install/libvips && node install/dll-copy && prebuild-install) || (node-gyp rebuild && node install/dll-copy)
10:55:19 PM: npm ERR! Exit status 1
10:55:19 PM: npm ERR! Failed at the sharp@0.20.8 install script.
10:55:19 PM: npm ERR! This is probably not a problem with npm. There is likely additional logging output above.
10:55:19 PM: npm ERR! A complete log of this run can be found in:
10:55:19 PM: npm ERR! /opt/buildhome/.npm/_logs/2021-03-19T03_55_19_460Z-debug.log
10:55:19 PM: Error during NPM install
10:55:19 PM: Build was terminated: Build script returned non-zero exit code: 1
10:55:19 PM: Failing build: Failed to build site
10:55:19 PM: Failed during stage ‘building site’: Build script returned non-zero exit code: 1
10:55:19 PM: Finished processing build request in 1m14.640104165s
Build settings
Base directory - Not set
Build command - gatsby build
Publish directory - public
Here is the complete log with all errors - I removed a large portion of the initial post due to repeated errors. Thanks in advance!!
10:54:05 PM: git clone GitHub - MrNoIce/Blog
10:55:17 PM: In file included from …/src/common.cc:27:0:
10:55:17 PM: …/src/common.h:82:16: error: ‘Handle’ is not a member of ‘v8’
10:55:17 PM: ^
10:55:17 PM: …/src/common.h:82:37: error: expected primary-expression before ‘>’ token
10:55:17 PM: ^
10:55:17 PM: …/src/common.h:82:39: error: ‘obj’ was not declared in this scope
10:55:17 PM: ^
10:55:17 PM: …/src/common.h:82:56: error: expected primary-expression before ‘attr’
10:55:17 PM: bool HasAttr(v8:: Handle<v8:: Object> obj, std::string attr);
10:55:17 PM: ^
10:55:17 PM: …/src/common.h:82:60: error: expression list treated as compound expression in initializer [-fpermissive]
10:55:17 PM: ^
10:55:17 PM: …/src/common.h:83:25: error: ‘Handle’ is not a member of ‘v8’
10:55:17 PM: std::string AttrAsStr(v8::Handle<v8: :Object> obj, std::string attr);
10:55:17 PM: ^
10:55:17 PM: …/src/common.h:83:46: error: expected primary-expression before ‘>’ token
10:55:17 PM: ^
10:55:17 PM: …/src/common.h:83:48: error: ‘obj’ was not declared in this scope
10:55:17 PM: ^
10:55:17 PM: …/src/common.h:83:65: error: expected primary-expression before ‘attr’
10:55:17 PM: ^
10:55:17 PM: …/src/common.h:84:44: error: ‘Handle’ is not a member of ‘v8’
10:55:17 PM: template v8::Local AttrAs(v8::Handle<v8:: Object> obj, std::string attr) {
10:55:17 PM: ^
10:55:17 PM: …/src/common.h:84:65: error: expected primary-expression before ‘>’ token
10:55:17 PM: template v8::Local AttrAs(v8::Handle<v8: :Object> obj, std::string attr) {
10:55:17 PM: ^
10:55:17 PM: …/src/common.h:84:67: error: ‘obj’ was not declared in this scope
10:55:17 PM: ^
10:55:17 PM: …/src/common.h:84:84: error: expected primary-expression before ‘attr’
10:55:17 PM: ^
10:55:17 PM: …/src/common.h:84:37: warning: variable templates only available with -std=c++14 or -std=gnu++14
10:55:17 PM: ^
10:55:17 PM: …/src/common.h:84:90: error: expected ‘;’ before ‘{’ token
10:55:17 PM: ^
10:55:17 PM: …/src/common.h:87:33: error: ‘Handle’ is not a member of ‘v8’
10:55:17 PM: template T AttrTo(v8::Handle<v8: :Object> obj, std::string attr) {
10:55:17 PM: ^
10:55:17 PM: …/src/common.h:87:54: error: expected primary-expression before ‘>’ token
10:55:17 PM: ^
10:55:17 PM: …/src/common.h:87:56: error: ‘obj’ was not declared in this scope
10:55:17 PM: ^
10:55:17 PM: …/src/common.h:87:73: error: expected primary-expression before ‘attr’
10:55:17 PM: ^
10:55:17 PM: …/src/common.h:87:26: warning: variable templates only available with -std=c++14 or -std=gnu++14
10:55:17 PM: ^
10:55:17 PM: …/src/common.h:87:79: error: expected ‘;’ before ‘{’ token
10:55:17 PM: ^
10:55:17 PM: …/src/common.h:90:33: error: ‘Handle’ is not a member of ‘v8’
10:55:17 PM: template T AttrTo(v8::Handle<v8: :Object> obj, int attr) {
10:55:17 PM: ^
10:55:17 PM: …/src/common.h:90:54: error: expected primary-expression before ‘>’ token
10:55:17 PM: ^
10:55:17 PM: …/src/common.h:90:56: error: ‘obj’ was not declared in this scope
10:55:17 PM: ^
10:55:17 PM: …/src/common.h:90:61: error: expected primary-expression before ‘int’
10:55:17 PM: ^
10:55:17 PM: ^
10:55:17 PM: …/src/common.h:90:71: error: expected ‘;’ before ‘{’ token
10:55:17 PM: template T AttrTo(v8: :Handle<v8: :Object> obj, int attr) {
10:55:17 PM: ^
10:55:17 PM: …/src/common.h:96:5: error: ‘Handle’ is not a member of ‘v8’
10:55:17 PM: v8::Handle<v8: :Object> input, std::vector<v8::Local<v8: :Object>> &buffersToPersist);
10:55:17 PM: ^
10:55:17 PM: …/src/common.h:96:26: error: expected primary-expression before ‘>’ token
10:55:17 PM: v8::Handle<v8: :Object> input, std::vector<v8::Local<v8:: Object>> &buffersToPersist);
10:55:17 PM: ^
10:55:17 PM: …/src/common.h:96:28: error: ‘input’ was not declared in this scope
10:55:17 PM: ^
10:55:17 PM: …/src/common.h:96:70: error: expected primary-expression before ‘&’ token
10:55:17 PM: v8::Handle<v8:: Object> input, std::vector<v8::Local<v8: :Object>> &buffersToPersist);
10:55:17 PM: ^
10:55:17 PM: …/src/common.h:96:71: error: ‘buffersToPersist’ was not declared in this scope
10:55:17 PM: v8::Handle<v8:: Object> input, std:: vector<v8::Local<v8: :Object>> &buffersToPersist);
10:55:17 PM: ^
10:55:17 PM: …/src/common.h:96:87: error: expression list treated as compound expression in initializer [-fpermissive]
10:55:17 PM: v8::Handle<v8:: Object> input, std::vector<v8: :Local<v8: :Object>> &buffersToPersist);
10:55:17 PM: ^
10:55:17 PM: …/src/common.cc:34:20: error: redefinition of ‘bool sharp::HasAttr’
10:55:17 PM: bool HasAttr(v8::Handle<v8:: Object> obj, std::string attr) {
10:55:17 PM: ^
10:55:17 PM: …/src/common.h:82:8: note: ‘bool sharp::HasAttr’ previously defined here
10:55:17 PM: ^
10:55:17 PM: …/src/common.cc:34:16: error: ‘Handle’ is not a member of ‘v8’
10:55:17 PM: bool HasAttr(v8::Handle<v8: :Object> obj, std::string attr) {
10:55:17 PM: ^
10:55:17 PM: …/src/common.cc:34:37: error: expected primary-expression before ‘>’ token
10:55:17 PM: ^
10:55:17 PM: …/src/common.cc:34:39: error: ‘obj’ was not declared in this scope
10:55:17 PM: bool HasAttr(v8::Handle obj, std::string attr) {
10:55:17 PM: ^
10:55:17 PM: …/src/common.cc:34:56: error: expected primary-expression before ‘attr’
10:55:17 PM: ^
10:55:17 PM: …/src/common.cc:37:29: error: redefinition of ‘std::__cxx11::string sharp::AttrAsStr’
10:55:17 PM: std::string AttrAsStr(v8::Handle<v8: :Object> obj, std::string attr) {
10:55:17 PM: ^
10:55:17 PM: …/src/common.h:83:15: note: ‘std::__cxx11::string sharp::AttrAsStr’ previously declared here
10:55:17 PM: std::string AttrAsStr(v8::Handle<v8:: Object> obj, std::string attr);
10:55:17 PM: ^
10:55:17 PM: …/src/common.cc:37:25: error: ‘Handle’ is not a member of ‘v8’
10:55:17 PM: std::string AttrAsStr(v8::Handle<v8:: Object> obj, std::string attr) {
10:55:17 PM: ^
10:55:17 PM: …/src/common.cc:37:46: error: expected primary-expression before ‘>’ token
10:55:17 PM: ^
10:55:17 PM: …/src/common.cc:37:48: error: ‘obj’ was not declared in this scope
10:55:17 PM: ^
10:55:17 PM: …/src/common.cc:37:65: error: expected primary-expression before ‘attr’
10:55:17 PM: ^
10:55:17 PM: …/src/common.cc:43:9: error: redefinition of ‘sharp::InputDescriptor* sharp::CreateInputDescriptor’
10:55:17 PM: v8::Handle<v8:: Object> input, std::vector<v8::Local<v8:: Object>> &buffersToPersist
10:55:17 PM: ^
10:55:17 PM: …/src/common.h:95:20: note: ‘sharp::InputDescriptor* sharp::CreateInputDescriptor’ previously defined here
10:55:17 PM: InputDescriptor* CreateInputDescriptor(
10:55:17 PM: ^
10:55:17 PM: …/src/common.cc:43:5: error: ‘Handle’ is not a member of ‘v8’
10:55:17 PM: ^
10:55:17 PM: …/src/common.cc:43:26: error: expected primary-expression before ‘>’ token
10:55:17 PM: ^
10:55:17 PM: …/src/common.cc:43:28: error: ‘input’ was not declared in this scope
10:55:17 PM: ^
10:55:17 PM: …/src/common.cc:43:70: error: expected primary-expression before ‘&’ token
10:55:17 PM: ^
10:55:17 PM: …/src/common.cc:43:71: error: ‘buffersToPersist’ was not declared in this scope
10:55:17 PM: ^
10:55:17 PM: …/src/common.cc:609:1: error: expected ‘}’ at end of input
10:55:17 PM: ^
Hi, @jakescott. I’m getting the same error, even without using Netlify, so this isn’t anything related to our service. There is an issue with the site’s code and that will need to be resolved before the build at Netlify will succeed.
Your repo is public and this allowed me to tested it on a clean Ubuntu 20.04 VM and I get the same error there:
$ nvm use 12.18.
$ npm install
npm WARN read-shrinkwrap This version of npm is compatible with lockfileVersion@1, but package-lock.json was generated for lockfileVersion@2. I'll try to do my best with it!
npm WARN deprecated browserslist@1.7.7: Browserslist 2 could fail on reading Browserslist >3.0 config used in other tools.
npm WARN deprecated babel-eslint@8.2.6: babel-eslint is now @babel/eslint-parser. This package will no longer receive updates.
npm WARN deprecated babel-preset-es2015@6.24.1: 🙌  Thanks for using Babel: we recommend using babel-preset-env now: please read https://babeljs.io/env to update!
npm WARN deprecated bfj-node4@5.3.1: Switch to the `bfj` package for fixes and new features!
npm WARN deprecated cheerio-select-tmp@0.1.1: Use cheerio-select instead
npm WARN deprecated chokidar@1.7.0: Chokidar 2 will break on node v14+. Upgrade to chokidar 3 with 15x less dependencies.
npm WARN deprecated core-js@2.6.12: core-js@<3 is no longer maintained and not recommended for usage due to the number of issues. Please, upgrade your dependencies to the actual version of core-js@3.
npm WARN deprecated debug@4.1.1: Debug versions >=3.2.0 <3.2.7 || >=4 <4.3.1 have a low-severity ReDos regression when used in a Node.js environment. It is recommended you upgrade to 3.2.7 or 4.3.1. (https://github.com/visionmedia/debug/issues/797)
npm WARN deprecated extract-text-webpack-plugin@1.0.1: Deprecated. Please use https://github.com/webpack-contrib/mini-css-extract-plugin
npm WARN deprecated core-js@1.2.7: core-js@<3 is no longer maintained and not recommended for usage due to the number of issues. Please, upgrade your dependencies to the actual version of core-js@3.
npm WARN deprecated fsevents@1.2.13: fsevents 1 will break on node v14+ and could be using insecure binaries. Upgrade to fsevents 2.
npm WARN deprecated gatsby-image@1.0.55: This package has been deprecated in favor of gatsby-plugin-image. The migration guide can be found here: https://www.gatsbyjs.com/docs/reference/release-notes/image-migration-guide/.
npm WARN deprecated graphql-import@0.7.1: GraphQL Import has been deprecated and merged into GraphQL Tools, so it will no longer get updates. Use GraphQL Tools instead to stay up-to-date! Check out https://www.graphql-tools.com/docs/migration-from-import for migration and https://the-guild.dev/blog/graphql-tools-v6 for new changes.
npm WARN deprecated gulp-util@3.0.8: gulp-util is deprecated - replace it, following the guidelines at https://medium.com/gulpjs/gulp-util-ca3b1f9f9ac5
npm WARN deprecated har-validator@5.1.5: this library is no longer supported
npm WARN deprecated hoek@5.0.4: This version has been deprecated in accordance with the hapi support policy (hapi.im/support). Please upgrade to the latest version to get the best features, bug fixes, and security patches. If you are unable to upgrade at this time, paid support is available for older versions (hapi.im/commercial).
npm WARN deprecated items@2.1.2: This module has been deprecated in accordance with the hapi support policy (hapi.im/support). Please upgrade to the latest version of hapi to get the best features, bug fixes, and security patches. If you are unable to upgrade at this time, paid support is available for older versions (hapi.im/commercial).
npm WARN deprecated joi@12.0.0: This version has been deprecated in accordance with the hapi support policy (hapi.im/support). Please upgrade to the latest version to get the best features, bug fixes, and security patches. If you are unable to upgrade at this time, paid support is available for older versions (hapi.im/commercial).
npm WARN deprecated hoek@4.2.1: This version has been deprecated in accordance with the hapi support policy (hapi.im/support). Please upgrade to the latest version to get the best features, bug fixes, and security patches. If you are unable to upgrade at this time, paid support is available for older versions (hapi.im/commercial).
npm WARN deprecated pkg-resolve@0.1.14: Not maintained anymore.
npm WARN deprecated popper.js@1.16.1: You can find the new Popper v2 at @popperjs/core, this package is dedicated to the legacy v1
npm WARN deprecated postcss-cssnext@2.11.0: 'postcss-cssnext' has been deprecated in favor of 'postcss-preset-env'. Read more at https://moox.io/blog/deprecating-cssnext/
npm WARN deprecated redux-devtools-core@0.2.1: Package moved to @redux-devtools/app.
npm WARN deprecated redux-devtools-instrument@1.10.0: Package moved to @redux-devtools/instrument.
npm WARN deprecated remotedev-serialize@0.1.9: Package moved to @redux-devtools/serialize.
npm WARN deprecated request@2.88.2: request has been deprecated, see https://github.com/request/request/issues/3142
npm WARN deprecated resolve-url@0.2.1: https://github.com/lydell/resolve-url#deprecated
npm WARN deprecated sw-precache@5.2.1: Please migrate to Workbox: https://developers.google.com/web/tools/workbox/guides/migrations/migrate-from-sw
npm WARN deprecated sw-toolbox@3.6.0: Please migrate to Workbox: https://developers.google.com/web/tools/workbox/guides/migrations/migrate-from-sw
npm WARN deprecated topo@2.0.2: This version has been deprecated in accordance with the hapi support policy (hapi.im/support). Please upgrade to the latest version to get the best features, bug fixes, and security patches. If you are unable to upgrade at this time, paid support is available for older versions (hapi.im/commercial).
npm WARN deprecated urix@0.1.0: Please see https://github.com/lydell/urix#deprecated
npm WARN deprecated joi@9.0.0-0: This version has been deprecated in accordance with the hapi support policy (hapi.im/support). Please upgrade to the latest version to get the best features, bug fixes, and security patches. If you are unable to upgrade at this time, paid support is available for older versions (hapi.im/commercial).
> sharp@0.25.4 install /home/username/tmp/Blog/node_modules/sharp-cli/node_modules/sharp
> sharp@0.20.8 install /home/username/tmp/Blog/node_modules/sharp
info sharp Downloading https://github.com/lovell/sharp-libvips/releases/download/v8.6.1/libvips-8.6.1-linux-x64.tar.gz
prebuild-install WARN install No prebuilt binaries found (target=12.18.0 runtime=node arch=x64 platform=linux)
make: Entering directory '/home/username/tmp/Blog/node_modules/sharp/build'
../src/common.h:82:20: error: ‘Handle’ is not a member of ‘v8’
   82 |   bool HasAttr(v8::Handle<v8::Object> obj, std::string attr);
../src/common.h:82:39: error: ‘obj’ was not declared in this scope
../src/common.h:82:56: error: expected primary-expression before ‘attr’
../src/common.h:82:60: error: expression list treated as compound expression in initializer [-fpermissive]
../src/common.h:83:29: error: ‘Handle’ is not a member of ‘v8’
   83 |   std::string AttrAsStr(v8::Handle<v8::Object> obj, std::string attr);
../src/common.h:83:46: error: expected primary-expression before ‘>’ token
../src/common.h:83:48: error: ‘obj’ was not declared in this scope
../src/common.h:83:65: error: expected primary-expression before ‘attr’
../src/common.h:84:48: error: ‘Handle’ is not a member of ‘v8’
   84 |   template<typename T> v8::Local<T> AttrAs(v8::Handle<v8::Object> obj, std::string attr) {
../src/common.h:84:65: error: expected primary-expression before ‘>’ token
../src/common.h:84:67: error: ‘obj’ was not declared in this scope
../src/common.h:84:84: error: expected primary-expression before ‘attr’
../src/common.h:84:37: warning: variable templates only available with ‘-std=c++14’ or ‘-std=gnu++14’
../src/common.h:84:89: error: expected ‘;’ before ‘{’ token
../src/common.h:87:37: error: ‘Handle’ is not a member of ‘v8’
   87 |   template<typename T> T AttrTo(v8::Handle<v8::Object> obj, std::string attr) {
../src/common.h:87:54: error: expected primary-expression before ‘>’ token
../src/common.h:87:56: error: ‘obj’ was not declared in this scope
../src/common.h:87:73: error: expected primary-expression before ‘attr’
../src/common.h:87:26: warning: variable templates only available with ‘-std=c++14’ or ‘-std=gnu++14’
../src/common.h:87:78: error: expected ‘;’ before ‘{’ token
../src/common.h:90:37: error: ‘Handle’ is not a member of ‘v8’
   90 |   template<typename T> T AttrTo(v8::Handle<v8::Object> obj, int attr) {
../src/common.h:90:54: error: expected primary-expression before ‘>’ token
../src/common.h:90:56: error: ‘obj’ was not declared in this scope
../src/common.h:90:61: error: expected primary-expression before ‘int’
../src/common.h:90:70: error: expected ‘;’ before ‘{’ token
../src/common.h:96:9: error: ‘Handle’ is not a member of ‘v8’
   96 |     v8::Handle<v8::Object> input, std::vector<v8::Local<v8::Object>> &buffersToPersist);
../src/common.h:96:26: error: expected primary-expression before ‘>’ token
../src/common.h:96:28: error: ‘input’ was not declared in this scope
../src/common.h:96:70: error: expected primary-expression before ‘&’ token
../src/common.h:96:71: error: ‘buffersToPersist’ was not declared in this scope
../src/common.h:96:87: error: expression list treated as compound expression in initializer [-fpermissive]
../src/common.cc:34:8: error: redefinition of ‘bool sharp::HasAttr’
   34 |   bool HasAttr(v8::Handle<v8::Object> obj, std::string attr) {
../src/common.h:82:8: note: ‘bool sharp::HasAttr’ previously defined here
../src/common.cc:34:20: error: ‘Handle’ is not a member of ‘v8’
../src/common.cc:34:37: error: expected primary-expression before ‘>’ token
../src/common.cc:34:39: error: ‘obj’ was not declared in this scope
../src/common.cc:34:56: error: expected primary-expression before ‘attr’
../src/common.cc:37:15: error: redefinition of ‘std::string sharp::AttrAsStr’
   37 |   std::string AttrAsStr(v8::Handle<v8::Object> obj, std::string attr) {
../src/common.h:83:15: note: ‘std::string sharp::AttrAsStr’ previously declared here
../src/common.cc:37:29: error: ‘Handle’ is not a member of ‘v8’
../src/common.cc:37:46: error: expected primary-expression before ‘>’ token
../src/common.cc:37:48: error: ‘obj’ was not declared in this scope
../src/common.cc:37:65: error: expected primary-expression before ‘attr’
../src/common.cc:42:20: error: redefinition of ‘sharp::InputDescriptor* sharp::CreateInputDescriptor’
   42 |   InputDescriptor* CreateInputDescriptor(
../src/common.h:95:20: note: ‘sharp::InputDescriptor* sharp::CreateInputDescriptor’ previously defined here
   95 |   InputDescriptor* CreateInputDescriptor(
../src/common.cc:43:9: error: ‘Handle’ is not a member of ‘v8’
   43 |     v8::Handle<v8::Object> input, std::vector<v8::Local<v8::Object>> &buffersToPersist
../src/common.cc:43:26: error: expected primary-expression before ‘>’ token
../src/common.cc:43:28: error: ‘input’ was not declared in this scope
../src/common.cc:43:70: error: expected primary-expression before ‘&’ token
../src/common.cc:43:71: error: ‘buffersToPersist’ was not declared in this scope
make: *** [sharp.target.mk:136: Release/obj.target/sharp/src/common.o] Error 1
make: Leaving directory '/home/username/tmp/Blog/node_modules/sharp/build'
gyp ERR! stack Error: `make` failed with exit code: 2
gyp ERR! stack     at ChildProcess.onExit (/home/username/.nvm/versions/node/v12.18.0/lib/node_modules/npm/node_modules/node-gyp/lib/build.js:194:23)
gyp ERR! System Linux 5.4.0-66-generic
gyp ERR! command "/home/username/.nvm/versions/node/v12.18.0/bin/node" "/home/username/.nvm/versions/node/v12.18.0/lib/node_modules/npm/node_modules/node-gyp/bin/node-gyp.js" "rebuild"
gyp ERR! cwd /home/username/tmp/Blog/node_modules/sharp
gyp ERR! not ok
npm WARN @material-ui/core@1.5.1 requires a peer of react@^16.3.0 but none is installed. You must install peer dependencies yourself.
npm WARN @material-ui/core@1.5.1 requires a peer of react-dom@^16.3.0 but none is installed. You must install peer dependencies yourself.
npm WARN react-event-listener@0.6.6 requires a peer of react@^16.3.0 but none is installed. You must install peer dependencies yourself.
npm WARN @material-ui/icons@1.1.1 requires a peer of react@^16.3.0 but none is installed. You must install peer dependencies yourself.
npm WARN @material-ui/icons@1.1.1 requires a peer of react-dom@^16.3.0 but none is installed. You must install peer dependencies yourself.
npm WARN acorn-jsx@5.3.1 requires a peer of acorn@^6.0.0 || ^7.0.0 || ^8.0.0 but none is installed. You must install peer dependencies yourself.
npm WARN eslint-plugin-graphql@2.1.1 requires a peer of graphql@^0.12.0 || ^0.13.0 but none is installed. You must install peer dependencies yourself.
npm WARN friendly-errors-webpack-plugin@1.7.0 requires a peer of webpack@^2.0.0 || ^3.0.0 || ^4.0.0 but none is installed. You must install peer dependencies yourself.
npm WARN react-instantsearch-native@5.7.0 requires a peer of react-native@>= 0.32.0 but none is installed. You must install peer dependencies yourself.
npm WARN notsup SKIPPING OPTIONAL DEPENDENCY: Unsupported platform for fsevents@1.2.13: wanted {"os":"darwin","arch":"any"} (current: {"os":"linux","arch":"x64"})
npm ERR! errno 1
npm ERR! sharp@0.20.8 install: `(node install/libvips && node install/dll-copy && prebuild-install) || (node-gyp rebuild && node install/dll-copy)`
npm ERR!
npm ERR!     /home/username/.npm/_logs/2021-03-22T04_46_58_280Z-debug.log
So, there is an issue building your site on Ubuntu, which is the OS the build image uses. You will need to resolve this error above before the build at Netlify will succeed.
If you want to test this build in our build image, you can do so using the instructions found here:
If there are other questions, please let us know.
@luke Thank you so much for your response! After many attempts to change my dependancies, I realized I needed to use a different version of node. I was able to replicate it locally once I changed the node version to reflect what netlify was using. I passed in the NODE_VERSION variable that I needed inside of netlify and everything worked!
Hey there, @jakescott!
So glad to hear you got it working. Thank you for sharing your steps with us.
I’m running into what seems to be this same issue, except in my case I updated node to match the version listed in the build log on my machine, updated the code, rebuilt locally (successfully), and pushed. However, the build still fails on netlify. Any help would be appreciated. I’m on node 18.17.1 (npm 9.6.7).
hi, which site are you writing in about? Please share the site Id/name.
Hopefully this is the correct info: ID: 01HAN2H9EVV10EW32KY2BM2DB2, name: phenomenal-pasca-992b74. This is my portfolio site that I’ve been migrating to netlify from Gatsby Cloud since it’s shutting down.
You’re using an outdated Node Gyp version:
Try uprading to the latest one.
Deploy details | Deploys | phenomenal-pasca-992b74 | Netlify
How do I upgrade node-gyp? The instructions online are diving a bit deeper into node than I’m comfortable with.
You’ll mention it explicitly in your yarn.lock or package.json (whichever one you already use) with a version set.
…indicates the latest version should be 9.4.0
so in package.json it would be in the dependencies section (not devDependencies!), and look like this:
"node-gyp": 9.4.0,
I did not test this but that has lined up with advice for other customers, and I trust you to troubleshoot from there in case I mis-specified the syntax :slight_smile:
node-gyp is not listed in my package.json, only in package-lock.json. I added the line you mentioned like so
"dependencies": {
    "@formspree/react": "^2.4.1",
    "@fortawesome/fontawesome-svg-core": "^6.4.0",
    "@fortawesome/free-solid-svg-icons": "^6.4.0",
    "@fortawesome/react-fontawesome": "^0.2.0",
    "gatsby": "^4.4.0",
    "gatsby-plugin-image": "^2.4.0",
    "gatsby-plugin-netlify": "^5.1.0",
    "gatsby-plugin-sharp": "^4.4.0",
    "gatsby-remark-embed-video": "^3.1.4",
    "gatsby-remark-images": "^6.4.0",
    "gatsby-source-filesystem": "^4.4.0",
    "gatsby-transformer-remark": "^5.0.0",
    "gatsby-transformer-sharp": "^4.4.0",
    "outdated": "^0.1.1",
    "react": "^17.0.2",
    "react-dom": "^17.0.2",
    "react-responsive": "^9.0.2",
    "react-slick": "^0.29.0",
    "slick-carousel": "^1.8.1",
    "node-gyp": "9.4.0"
But it still fails to build on netlify. In the log it seems to still see the old version:
Also I don’t know if this is relevant but the build log mentions a very old version of npm compared to the one mentioned in the initialization log.
Initialization log:
Build log:
Have you tried a rebuild without cache? We otherwise cache your dependencies from the last successful build.
I tried the Clear cache and deploy site option listed in the Deploys menu:
Doesn’t seem to change anything, build still fails.
Hey @Twads9816, I’ve asked the devs to check this.
Hey @Twads9816,
Thanks for reporting this issue to us. We actually found a bug in our build system in the way we added the node_modules/.bin directory to the user execution PATH at build time, you can read more about it here - Changes to the way executables from installed node_modules are exposed at build time.
We’re in the process of rolling out this change/fix to our customers, but meanwhile I’ve went ahead and added your account to the rollout already. Could you test out a build a let us know if that works for you?
Thanks!
Build works. Thank you and thank you to your team, I really appreciate the help.
Hey guys, was this fix rolled out actually? :sweat_smile: I have found my builds fail because of the same reason (I believe). It is a website based on Gridsome which is basically not supported anymore so the website requires the older Node/npm versions. The builds started to fail at some recent point (the last successful build was on the new year’s eve 2025 basically). No dependencies changed so maybe some corresponding Netlify image updates are the culprit?
This is an issue from 2023 and there are high changes it might not be related anymore. Please share your details so we can check further.
