https://japan-society.netlify.app/
I’m not sure what is going on but our site starting having build fails last night. I got it to succeed a build once after clearing a cache but after that it keeps failing.
Our IT support says we need to pay for a higher tier Contentful account because our API calls are above 55 per second but I’m also seeing a build error. Any idea if its just I need to pay or there is more wrong even after I upgrade the Contentful plan from free to paid?
9:57:41 AM: Build ready to start
9:57:45 AM: build-image version: 6ac9cdbcc295289dbaea7d39b2f1a3ac25ad3380 (xenial)
9:57:45 AM: build-image tag: release-v3.14.0
9:57:45 AM: buildbot version: 130c63f822e79b73b71cdfefdabcf7970433539d
9:57:45 AM: Fetching cached dependencies
9:57:45 AM: Starting to download cache of 163.9MB
9:57:46 AM: Finished downloading cache in 1.237691529s
9:57:46 AM: Starting to extract cache
9:57:48 AM: Finished extracting cache in 2.302504756s
9:57:48 AM: Finished fetching cache in 3.586962606s
9:57:48 AM: Starting to prepare the repo for build
9:57:49 AM: Preparing Git Reference refs/heads/main
9:57:49 AM: Parsing package.json dependencies
9:57:50 AM: Different functions path detected, going to use the one specified in the Netlify configuration file: 'netlify/functions' versus '' in the Netlify UI
9:57:50 AM: Starting build script
9:57:50 AM: Installing dependencies
9:57:50 AM: Python version set to 2.7
9:57:51 AM: Started restoring cached node version
9:57:52 AM: Finished restoring cached node version
9:57:53 AM: v12.18.0 is already installed.
9:57:53 AM: Now using node v12.18.0 (npm v6.14.4)
9:57:53 AM: Started restoring cached build plugins
9:57:53 AM: Finished restoring cached build plugins
9:57:53 AM: Attempting ruby version 2.7.1, read from environment
9:57:53 AM: Started restoring cached ruby version
9:57:53 AM: Finished restoring cached ruby version
9:57:54 AM: Using ruby version 2.7.1
9:57:55 AM: Using PHP version 5.6
9:57:55 AM: No npm workspaces detected
9:57:55 AM: Started restoring cached node modules
9:57:55 AM: Finished restoring cached node modules
9:57:55 AM: Started restoring cached go cache
9:57:55 AM: Finished restoring cached go cache
9:57:55 AM: go version go1.14.4 linux/amd64
9:57:55 AM: Installing missing commands
9:57:55 AM: Verify run directory
9:57:56 AM:
9:57:56 AM: ────────────────────────────────────────────────────────────────
9:57:56 AM: Netlify Build
9:57:56 AM:
9:57:56 AM: ❯ Version
9:57:56 AM: @netlify/build 27.4.1
9:57:56 AM:
9:57:56 AM: ❯ Flags
9:57:56 AM: baseRelDir: true
9:57:56 AM: buildId: 62d6b7e9e964572f84160789
9:57:56 AM: deployId: 62d6b8551b51aa0009b171b7
9:57:56 AM:
9:57:56 AM: ❯ Current directory
9:57:56 AM: /opt/build/repo
9:57:56 AM:
9:57:56 AM: ❯ Config file
9:57:56 AM: /opt/build/repo/netlify.toml
9:57:56 AM:
9:57:56 AM: ❯ Context
9:57:56 AM: production
9:57:57 AM:
9:57:57 AM: ❯ Loading plugins
9:57:57 AM: - netlify-plugin-cache-nextjs@1.4.0 from Netlify app
9:57:57 AM: - @netlify/plugin-nextjs@1.1.5 from Netlify app
9:57:57 AM:
9:57:57 AM: ❯ Outdated plugins
9:57:57 AM: - @netlify/plugin-nextjs@1.1.5: latest version is 4.12.2
9:57:57 AM: Migration guide: https://ntl.fyi/next-plugin-migration
9:57:57 AM: To upgrade this plugin, please uninstall and re-install it from the Netlify plugins directory (https://app.netlify.com/plugins)
9:57:57 AM:
9:57:57 AM: ────────────────────────────────────────────────────────────────
9:57:57 AM: 1. netlify-plugin-cache-nextjs (onPreBuild event)
9:57:57 AM:
9:57:58 AM: Restored the cached .next folder at the location `.next/cache`
9:57:58 AM:
9:57:58 AM: (netlify-plugin-cache-nextjs onPreBuild completed in 162ms)
9:57:58 AM:
9:57:58 AM: ────────────────────────────────────────────────────────────────
9:57:58 AM: 2. @netlify/plugin-nextjs (onPreBuild event)
9:57:58 AM:
9:57:58 AM:
9:57:58 AM: (@netlify/plugin-nextjs onPreBuild completed in 8ms)
9:57:58 AM:
9:57:58 AM: 3. Build command from Netlify app
9:57:58 AM:
9:57:58 AM: $ next build && next export
9:57:58 AM: Browserslist: caniuse-lite is outdated. Please run:
9:57:58 AM: npx browserslist@latest --update-db
9:57:58 AM: Loaded env from /opt/build/repo/.env.production
9:57:58 AM: info - Creating an optimized production build...
9:58:05 AM: Browserslist: caniuse-lite is outdated. Please run:
9:58:05 AM: npx browserslist@latest --update-db
9:58:05 AM: info - Using external babel configuration from /opt/build/repo/.babelrc
9:58:18 AM: warn - Compiled with warnings
9:58:18 AM: ./node_modules/next/dist/next-server/server/load-components.js
9:58:18 AM: Critical dependency: the request of a dependency is an expression
9:58:18 AM: ./node_modules/next/dist/next-server/server/require.js
9:58:18 AM: ./node_modules/graphql-request/node_modules/node-fetch/lib/index.js
9:58:18 AM: Module not found: Can't resolve 'encoding' in '/opt/build/repo/node_modules/graphql-request/node_modules/node-fetch/lib'
9:58:18 AM: info - Collecting page data...
9:58:20 AM: Warning: You have opted-out of Automatic Static Optimization due to `getInitialProps` in `pages/_app`. This does not opt-out pages with `getStaticProps`
9:58:20 AM: Read more: https://err.sh/next.js/opt-out-auto-static-optimization
10:00:18 AM: info - Generating static pages (0/497)
10:00:26 AM: info - Generating static pages (124/497)
10:00:31 AM: info - Generating static pages (248/497)
10:00:34 AM: Unhandled error during request: ClientError: You have exceeded the rate limit of this Space by making too many API requests within a short timespan. Please wait a moment before trying the request again.: {"response":{"errors":[{"message":"You have exceeded the rate limit of this Space by making too many API requests within a short timespan. Please wait a moment before trying the request again.","extensions":{"contentful":{"code":"RATE_LIMIT_EXCEEDED","requestId":"a6b6b030-ca12-49ad-bf49-8b14851e0005"}}}],"status":429},"request":{"query":"query GET_CATEGORY_SECTION_LIST($limit: Int = 4, $skip: Int = 0, $alias: String!) {\n categorySectionListCollection(limit: 1, where: {category: {urlAlias: $alias}}) {\n total\n skip\n limit\n items {\n category {\n category\n urlAlias\n featuredHtml\n sponsorHtml\n description\n active\n series\n image {\n url\n title\n description\n }\n parent {\n category\n urlAlias\n sponsorHtml\n description\n active\n image {\n url\n title\n description\n }\n }\n }\n categorySectionsCollection(skip: 0, limit: 4) {\n total\n skip\n limit\n items {\n internalName\n title\n link\n maxPostLimit\n contentsCollection(skip: $skip, limit: $limit) {\n total\n skip\n limit\n items {\n __typename\n ... on Sandbox {\n sys {\n publishedAt\n }\n title\n tags\n urlAlias\n featuredNumber\n openGraphImage {\n url\n title\n }\n isHidden\n publishedAt\n subcategoryLabel\n cardRedirect\n galleryCollection(skip: 0, limit: 4) {\n skip\n limit\n items {\n url\n title\n description\n }\n }\n instancesCollection(skip: 0, limit: 10) {\n total\n limit\n skip\n items {\n type\n label\n displayEventButNotOnCalendar\n performanceStartAt\n allDayEventAt\n webcastEndAt\n webcastStartAt\n multiDayEndAt\n multiDayStartAt\n }\n }\n category {\n sys {\n id\n }\n }\n }\n ... on LanguageCenterCources {\n sys {\n publishedAt\n }\n urlAlias\n ctaUrl\n ctaText\n title\n eyecatch {\n title\n description\n contentType\n fileName\n size\n url\n width\n height\n }\n }\n ... on Event {\n title\n urlAlias\n isHidden\n online\n galleryCollection(skip: 0, limit: 4) {\n skip\n limit\n items {\n url\n title\n description\n }\n }\n cta {\n buttonTitle\n url\n }\n subcategoryLabel\n descriptionOnHome\n cardRedirect\n instancesCollection(skip: 0, limit: 10) {\n total\n limit\n skip\n items {\n type\n label\n displayEventButNotOnCalendar\n performanceStartAt\n allDayEventAt\n webcastEndAt\n webcastStartAt\n multiDayEndAt\n multiDayStartAt\n }\n }\n heroImage {\n title\n description\n contentType\n fileName\n size\n url\n width\n height\n }\n category {\n sys {\n id\n }\n }\n }\n }\n }\n }\n }\n }\n }\n}\n","variables":{"alias":"contemporary-japan-global-initiatives-sustainability"}}}
10:00:34 AM: at GraphQLClient.<anonymous> (/opt/build/repo/.next/serverless/pages/[categoryId]/[[...postId]].js:11140:35)
10:00:34 AM: at step (/opt/build/repo/.next/serverless/pages/[categoryId]/[[...postId]].js:11031:23)
10:00:34 AM: at Object.next (/opt/build/repo/.next/serverless/pages/[categoryId]/[[...postId]].js:11012:53)
10:00:34 AM: at fulfilled (/opt/build/repo/.next/serverless/pages/[categoryId]/[[...postId]].js:11003:58)
10:00:34 AM: at processTicksAndRejections (internal/process/task_queues.js:97:5) {
10:00:34 AM: response: { errors: [ [Object] ], status: 429 },
10:00:34 AM: request: {
10:00:34 AM: query: 'query GET_CATEGORY_SECTION_LIST($limit: Int = 4, $skip: Int = 0, $alias: String!) {\n' +
10:00:34 AM: ' categorySectionListCollection(limit: 1, where: {category: {urlAlias: $alias}}) {\n' +
10:00:34 AM: ' total\n' +
10:00:34 AM: ' skip\n' +
10:00:34 AM: ' limit\n' +
10:00:34 AM: ' items {\n' +
10:00:34 AM: ' category {\n' +
10:00:34 AM: ' category\n' +
10:00:34 AM: ' urlAlias\n' +
10:00:34 AM: ' featuredHtml\n' +
10:00:34 AM: ' sponsorHtml\n' +
10:00:34 AM: ' description\n' +
10:00:34 AM: ' active\n' +
10:00:34 AM: ' series\n' +
10:00:34 AM: ' image {\n' +
10:00:34 AM: ' url\n' +
10:00:34 AM: ' title\n' +
10:00:34 AM: ' }\n' +
10:00:34 AM: ' parent {\n' +
10:00:34 AM: ' categorySectionsCollection(skip: 0, limit: 4) {\n' +
10:00:34 AM: ' internalName\n' +
10:00:34 AM: ' link\n' +
10:00:34 AM: ' maxPostLimit\n' +
10:00:34 AM: ' contentsCollection(skip: $skip, limit: $limit) {\n' +
10:00:34 AM: ' __typename\n' +
10:00:34 AM: ' ... on Sandbox {\n' +
10:00:34 AM: ' sys {\n' +
10:00:34 AM: ' publishedAt\n' +
10:00:34 AM: ' tags\n' +
10:00:34 AM: ' featuredNumber\n' +
10:00:34 AM: ' openGraphImage {\n' +
10:00:34 AM: ' isHidden\n' +
10:00:34 AM: ' subcategoryLabel\n' +
10:00:34 AM: ' cardRedirect\n' +
10:00:34 AM: ' galleryCollection(skip: 0, limit: 4) {\n' +
10:00:34 AM: ' instancesCollection(skip: 0, limit: 10) {\n' +
10:00:34 AM: ' type\n' +
10:00:34 AM: ' label\n' +
10:00:34 AM: ' displayEventButNotOnCalendar\n' +
10:00:34 AM: ' performanceStartAt\n' +
10:00:34 AM: ' allDayEventAt\n' +
10:00:34 AM: ' webcastEndAt\n' +
10:00:34 AM: ' webcastStartAt\n' +
10:00:34 AM: ' multiDayEndAt\n' +
10:00:34 AM: ' multiDayStartAt\n' +
10:00:34 AM: ' id\n' +
10:00:34 AM: ' ... on LanguageCenterCources {\n' +
10:00:34 AM: ' ctaUrl\n' +
10:00:34 AM: ' ctaText\n' +
10:00:34 AM: ' eyecatch {\n' +
10:00:34 AM: ' contentType\n' +
10:00:34 AM: ' fileName\n' +
10:00:34 AM: ' size\n' +
10:00:34 AM: ' width\n' +
10:00:34 AM: ' height\n' +
10:00:34 AM: ' ... on Event {\n' +
10:00:34 AM: ' online\n' +
10:00:34 AM: ' cta {\n' +
10:00:34 AM: ' buttonTitle\n' +
10:00:34 AM: ' descriptionOnHome\n' +
10:00:34 AM: ' heroImage {\n' +
10:00:34 AM: '}\n',
10:00:34 AM: variables: { alias: 'contemporary-japan-global-initiatives-sustainability' }
10:00:34 AM: }
10:00:34 AM: }
10:00:34 AM: Error occurred prerendering page "/education/language-center-courses". Read more: https://err.sh/next.js/prerender-error
10:00:34 AM: Error: You have exceeded the rate limit of this Space by making too many API requests within a short timespan. Please wait a moment before trying the request again.: {"response":{"errors":[{"message":"You have exceeded the rate limit of this Space by making too many API requests within a short timespan. Please wait a moment before trying the request again.","extensions":{"contentful":{"code":"RATE_LIMIT_EXCEEDED","requestId":"9e1e5a29-5251-4ff7-b4a7-b48238b12162"}}}],"status":429},"request":{"query":"query getEventList($limit: Int = 1, $skip: Int = 0, $categoryAlias: String!) {\n eventCollection(order: [featuredNumber_ASC], limit: $limit, skip: $skip, where: {category: {urlAlias: $categoryAlias}}) {\n limit\n total\n skip\n items {\n sys {\n id\n publishedAt\n }\n body\n title\n urlAlias\n cardRedirect\n online\n isHidden\n dateHidden\n textUnderGallery\n featuredNumber\n galleryCollection {\n skip\n limit\n items {\n url\n title\n description\n }\n }\n metaDescription\n category {\n category\n sponsorHtml\n description\n urlAlias\n active\n image {\n url\n }\n parent {\n category\n sponsorHtml\n description\n urlAlias\n active\n image {\n url\n }\n }\n }\n cta {\n buttonTitle\n url\n }\n ticketing\n approval\n instancesCollection {\n total\n skip\n limit\n items {\n multiDayEndAt\n multiDayStartAt\n webcastStartAt\n webcastEndAt\n allDayEventAt\n performanceStartAt\n displayEventButNotOnCalendar\n label\n type\n indistinctDate\n }\n }\n descriptionOnHome\n heroImage {\n sys {\n id\n }\n title\n description\n contentType\n fileName\n url\n }\n }\n }\n}\n","variables":{"categoryAlias":"language-center-courses","skip":0,"limit":1}}}
10:00:34 AM: at runMicrotasks (<anonymous>)
10:00:37 AM: info - Generating static pages (372/497)
10:00:44 AM: info - Generating static pages (497/497)
10:00:44 AM: > Build error occurred
10:00:44 AM: Error: Export encountered errors on following paths:
10:00:44 AM: /education/language-center-courses
10:00:44 AM: /education/teacher-and-k-12/contemporary-japan-global-initiatives-sustainability
10:00:44 AM: /education/teacher-and-k-12/junior-fellows-program
10:00:44 AM: /education/teacher-and-k-12/us-japan-relations-teacher-development
10:00:44 AM: at exportApp (/opt/build/repo/node_modules/next/dist/export/index.js:25:1103)
10:00:44 AM: at processTicksAndRejections (internal/process/task_queues.js:97:5)
10:00:44 AM: at async build (/opt/build/repo/node_modules/next/dist/build/index.js:37:212)
10:00:45 AM:
10:00:45 AM: ────────────────────────────────────────────────────────────────
10:00:45 AM: "build.command" failed
10:00:45 AM:
10:00:45 AM: Error message
10:00:45 AM: Command failed with exit code 1: next build && next export (https://ntl.fyi/exit-code-1)
10:00:45 AM:
10:00:45 AM: Error location
10:00:45 AM: In Build command from Netlify app:
10:00:45 AM: next build && next export
10:00:45 AM:
10:00:45 AM: Resolved config
10:00:45 AM: build:
10:00:45 AM: command: next build && next export
10:00:45 AM: commandOrigin: ui
10:00:45 AM: environment:
10:00:45 AM: - ALGOLIA_INDEX_NAME1
10:00:45 AM: - INCOMING_HOOK_BODY
10:00:45 AM: - INCOMING_HOOK_TITLE
10:00:45 AM: - INCOMING_HOOK_URL
10:00:45 AM: - ONEGRAPH_AUTHLIFY_TOKEN
10:00:45 AM: - NEXT_PUBLIC_GRAPHQL_URL
10:00:45 AM: - NEXT_PUBLIC_GRAPHQL_TOKEN
10:00:45 AM: publish: /opt/build/repo/out
10:00:45 AM: publishOrigin: ui
10:00:45 AM: functionsDirectory: /opt/build/repo/netlify/functions
10:00:45 AM: plugins:
10:00:45 AM: - inputs: {}
10:00:45 AM: origin: ui
10:00:45 AM: package: netlify-plugin-cache-nextjs
10:00:45 AM: package: '@netlify/plugin-nextjs'
10:00:45 AM: Caching artifacts
10:00:45 AM: Started saving node modules
10:00:45 AM: Finished saving node modules
10:00:45 AM: Started saving build plugins
10:00:45 AM: Finished saving build plugins
10:00:45 AM: Started saving pip cache
10:00:45 AM: Finished saving pip cache
10:00:45 AM: Started saving emacs cask dependencies
10:00:45 AM: Finished saving emacs cask dependencies
10:00:45 AM: Started saving maven dependencies
10:00:45 AM: Finished saving maven dependencies
10:00:45 AM: Started saving boot dependencies
10:00:45 AM: Finished saving boot dependencies
10:00:45 AM: Started saving rust rustup cache
10:00:45 AM: Finished saving rust rustup cache
10:00:45 AM: Started saving go dependencies
10:00:45 AM: Finished saving go dependencies
10:00:45 AM: Build failed due to a user error: Build script returned non-zero exit code: 2
10:00:45 AM: Creating deploy upload records
10:00:45 AM: Failing build: Failed to build site
10:00:45 AM: Failed during stage 'building site': Build script returned non-zero exit code: 2 (https://ntl.fyi/exit-code-2)
10:00:46 AM: Finished processing build request in 3m0.96105741s
