Netlify site name: silver-swan-97c645
Build Log:
5:12:49 PM: Failed during stage ‘building site’: Build script returned non-zero exit code: 2 (Search results for '"non-zero exit code: 2"' - Netlify Support Forums)
5:12:45 PM: Netlify Build
5:12:45 PM: ────────────────────────────────────────────────────────────────
5:12:45 PM:
5:12:45 PM: ❯ Version
5:12:45 PM: @netlify/build 29.12.1
5:12:45 PM:
5:12:45 PM: ❯ Flags
5:12:45 PM: baseRelDir: true
5:12:45 PM: buildId: 649b0a645170cd0afec38fc1
5:12:45 PM: deployId: 649b0a645170cd0afec38fc3
5:12:45 PM: tracing:
5:12:45 PM: enabled: ‘false’
5:12:45 PM: host: 10.65.15.197
5:12:45 PM: parentSpanId: 58ce790e47fd89e1
5:12:45 PM: traceFlags: ‘01’
5:12:45 PM: traceId: 08ec24069947b8ed0d3b99340dec3b88
5:12:45 PM:
5:12:45 PM: ❯ Current directory
5:12:45 PM: /opt/build/repo/my-app
5:12:45 PM:
5:12:45 PM: ❯ Config file
5:12:45 PM: No config file was defined: using default values.
5:12:45 PM:
5:12:45 PM: ❯ Context
5:12:45 PM: production
5:12:45 PM:
5:12:45 PM: Build command from Netlify app
5:12:45 PM:
5:12:45 PM: $ npm run build
5:12:46 PM: > my-app@0.1.0 build
5:12:46 PM: > react-scripts build
5:12:47 PM: Creating an optimized production build…
5:12:47 PM: Browserslist: caniuse-lite is outdated. Please run:
5:12:47 PM: npx update-browserslist-db@latest
5:12:47 PM: Why you should do it regularly: GitHub - browserslist/update-db: CLI tool to update caniuse-lite to refresh target browsers from Browserslist config
5:12:48 PM: Failed to compile.
5:12:48 PM:
5:12:48 PM: Module not found: Error: Can’t resolve ‘…/images/gallery/1.jpg’ in ‘/opt/build/repo/my-app/src/components’
5:12:48 PM:
5:12:48 PM: build.command failed
5:12:48 PM: ────────────────────────────────────────────────────────────────
5:12:48 PM:
5:12:48 PM: Error message
5:12:48 PM: Command failed with exit code 1: npm run build (Search results for '"non-zero exit code: 1"' - Netlify Support Forums)
5:12:48 PM:
5:12:48 PM: Error location
5:12:48 PM: In Build command from Netlify app:
5:12:48 PM: npm run build
5:12:48 PM:
5:12:48 PM: Resolved config
5:12:48 PM: build:
5:12:48 PM: base: /opt/build/repo/my-app
5:12:48 PM: command: npm run build
5:12:48 PM: commandOrigin: ui
5:12:48 PM: publish: /opt/build/repo/my-app/build
5:12:48 PM: publishOrigin: ui
5:12:48 PM: Build failed due to a user error: Build script returned non-zero exit code: 2
5:12:49 PM: Failing build: Failed to build site
5:12:49 PM: Finished processing build request in 27.631s
Building Settings:
Code:
Appreciate your help, thanks! ![]()
