1:52:07 AM: build-image version: 50f2c07b4ff67fac131b5b345ef7efb7e0ab9dac (focal)
1:52:07 AM: buildbot version: 3c77419a32191e587913c896861b4b2804c7fa10
1:52:07 AM: Fetching cached dependencies
1:52:07 AM: Failed to fetch cache, continuing with build
1:52:07 AM: Starting to prepare the repo for build
1:52:07 AM: No cached dependencies found. Cloning fresh repo
1:52:07 AM: git clone --filter=blob:none https://github.com/MrShuja/portfolio-react
1:52:07 AM: Preparing Git Reference refs/heads/main
1:52:09 AM: Starting to install dependencies
1:52:09 AM: Python version set to 3.8
1:52:09 AM: Attempting Ruby version 2.7.2, read from environment
1:52:10 AM: Using Ruby version 2.7.2
1:52:10 AM: Started restoring cached go cache
1:52:10 AM: Finished restoring cached go cache
1:52:10 AM: go version go1.19.13 linux/amd64
1:52:11 AM: Using PHP version 8.0
1:52:12 AM: v18.18.2 is already installed.
1:52:12 AM: Now using node v18.18.2 (npm v9.8.1)
1:52:12 AM: Enabling Node.js Corepack
1:52:12 AM: Started restoring cached build plugins
1:52:12 AM: Finished restoring cached build plugins
1:52:12 AM: Started restoring cached corepack dependencies
1:52:12 AM: Finished restoring cached corepack dependencies
1:52:12 AM: No npm workspaces detected
1:52:12 AM: Started restoring cached node modules
1:52:12 AM: Finished restoring cached node modules
1:52:12 AM: Installing npm packages using npm version 9.8.1
1:52:14 AM: Failed during stage “Install dependencies”: dependency_installation script returned non-zero exit code: 1
1:52:14 AM: npm ERR! code ERESOLVE
1:52:14 AM: npm ERR! ERESOLVE could not resolve
1:52:14 AM: npm ERR! While resolving: react-typical@0.1.3
1:52:14 AM: npm ERR! Found: react@18.2.0
1:52:14 AM: npm ERR! node_modules/react
1:52:14 AM: npm ERR! react@“^18.2.0” from the root project
1:52:14 AM: npm ERR! react@“18.2.0” from @react-email/render@0.0.6
1:52:14 AM: npm ERR! node_modules/@react-email/render
1:52:14 AM: npm ERR! @react-email/render@“0.0.6” from react-email@1.9.5
1:52:14 AM: npm ERR! node_modules/react-email
1:52:14 AM: npm ERR! react-email@“^1.9.5” from the root project
1:52:14 AM: npm ERR! 10 more (@testing-library/react, framer-motion, react-dom, …)
1:52:14 AM: npm ERR! Could not resolve dependency:
1:52:14 AM: npm ERR! peer react@“^15.0.0 || ^16.0.0” from react-typical@0.1.3
1:52:14 AM: npm ERR! node_modules/react-typical
1:52:14 AM: npm ERR! react-typical@“^0.1.3” from the root project
1:52:14 AM: npm ERR! Conflicting peer dependency: react@16.14.0
1:52:14 AM: npm ERR! Fix the upstream dependency conflict, or retry
1:52:14 AM: npm ERR! this command with --force or --legacy-peer-deps
1:52:14 AM: npm ERR! to accept an incorrect (and potentially broken) dependency resolution.
1:52:14 AM: npm ERR! For a full report see:
1:52:14 AM: npm ERR! /opt/buildhome/.npm/_logs/2023-10-28T08_52_12_937Z-eresolve-report.txt
1:52:14 AM: npm ERR! A complete log of this run can be found in: /opt/buildhome/.npm/_logs/2023-10-28T08_52_12_937Z-debug-0.log
1:52:14 AM: Error during npm install
1:52:14 AM: Build was terminated: dependency_installation script returned non-zero exit code: 1
1:52:14 AM: Failing build: Failed to install dependencies
B
In progress
1:52:14 AM: Finished processing build request in 6.92s
